Question about Aiwa HT-DV90 System
The problem comes when Im using my HT-DV90 as amplifier for my new LCD TV (LG 42LE5500). It's connected to Video2-digital. The sound is quite satisfying and it works fine until I skip to the next song or the next TV channel - then the soung goes off. I can reactivate it by changing input to any other and turning back to Video2. After that everything is OK until next song or channel change. I have other input source on Video1-digitaland it works fine.
2 Suggested Answers
vpaaf
  • 115 Answers
SOURCE: aiwa ht-dv90
Not good protection is a special circuit in side the machine.. You will need to get the machine repaired at a service center. You circuit board has over loaded.
Posted on Oct 09, 2009
Lg tv 42le5500 restart when start use netcast youtube app
There is a mismatch of communication due to different formats. If you have followed guidelines contained in the operation manuals of both devices, this might require attention by a qualified service technician.
Jul 12, 2012 | LG 42LE5500 42 in. TV
When viewing TV with DTV, the sound will occasionally mute right after the clipping in a program. Just like the function that protects the speakers from loud sounds. (This function is OFF) The sound comes...
Just try connecting the input to another TV and check whether the same problem comes. If it does, the problem is with the input. If not, the signal strength is not good enough to the microcontroller IC to switch off the mute. Normally when the signal is missing or weak, audio mute gets operated.
Jul 12, 2012 | LG 42le5300
Lg 42le5500 lcd turns on but no picture
Check whether the back light is working or not. The problem sounds to be a back light related. If CCFL lamps have defect or back light inverter board is faulty, this kind of problem can occur. But if this is the problem, there sill be sound output from the TV. Only picture will be out.
Jun 27, 2012 | LG Televison & Video
My aiwa dvd player HT-DV90 won`t stay turned, in the screen shows PROTECT and turns off ...
Check the speakers one by one, maybe one of them are damaged and make the device going on protection
Aug 26, 2011 | Aiwa HT-DV90 System
How do i get surround sound while watching regular tv
If the TV audio originates at a SAT or Cable Box, treat it like any other external digital audio source.
Mar 06, 2011 | Aiwa HT-DV90 System
I can't get tv to send sound to sound system
Having browsed the user manual I wonder if you plugged in the Sony BDV T57 Home Theatre System while the Polaroid FLM-2632 tv was powered down via the optical cable .
Then powered up the Sony BDV T57 Home Theatre System first and then powered up the Polaroid FLM-2632 tv
Maybe the Polaroid FLM-2632 TV has to detect that the Sony BDV T57 Home Theatre System is connected and powered up when the Polaroid FLM-2632 powers up. To activate its digital audio out ????
The note part about only being available only under HDTV (cable/air) mode. Might be the cause of your hassle also ?
DIRECTLY FROM THE USER MANUAL
source from
http://tv.manualsonline.com/manuals/mfg/polaroid/polaroid_flm_flm2632.html
? Connecting to Audio Receiver:
Use an audio cable to connect the audio receiver's audio LINE IN jacks to LCD TV's
AUDIO OUT jacks. ? Connecting to Digital 5.1 Sound System:
METHOD A:
Use an optical cable to connect the audio amplifier's OPTICAL IN jacks to LCD TV's
OPTICAL OUT jacks.
METHOD B:
Use a coaxial cable to connect the audio amplifier's COAXIAL IN jacks to LCD TV's
COAXIAL OUT jacks.
Note: Above mentioned function is only available under HDTV (cable/air) mode.
? Connect all AC power sources, before turning on the power switch of the LCD TV or
other connected equipment.
? Press the button on the remote to turn on the LCD TV."
May 25, 2017 | Polaroid FLM-2632 Television
How do i connect aiwa speakers with 26
LG does not have direct speaker connectors. You will have to use the audio out RCA jacks on the set through RCA cables into a seperate amplifier. Hope this helps.
Oct 14, 2009 | LG 26LH20 LCD TV
Hi i have just purchased a second hand ht-dv90,the problem is it will only play one dvd film that i have and will not play any of the others ,any ideas on what the problem is.i dont fancy watching the same...
Hi, sounds like a zone issue. Check the zone on the one works and I'm sure you will find it different to the others. Not sure if there is a slution there as will have to change the zoning on it.
Regards
Jul 24, 2009 | Aiwa HT-DV90 System
No sound from surround sound whilst tv on
YOU HAVE TO TURN VOLUME OFF ONTV AND PUT YOUR SURROUND SOUND ON AUX THATS HOW MINE WORKS
Jan 24, 2009 | Samsung HT-Q100 System
Connections
Follow these; 1-Get an Xbox 360 HD cable (see the picture1 below) 2-Connect the red and white plugs to one of your amplifier's empty inputs. 3-Connect the VGA plug to the LCD directly By following these instructions you'll be able to get surround sound from your amplifier as long as you keep it turned on. 2nd solution could be that; (if you have some other equipments connected to the amplifier such as dvd, cd, etc.) 1-Get the above-mentioned HD Cable and get a VGA to S-Video adapter (a small piece of equipment) 2-Do the same thing as mentioned in the 2nd above 3-This time, you're gonna select a VIDEO INPUT (video1, video2,etc.) on your amplifier's input selector. Affix the VGA plug of your HD cable to the S-Video adapter, and connect it to an empty S-Video input slot at the back side of the amp. 4-Get a simple RCA cable or a digital coax cable (up to you) to make a connection between the "monitor out" slot of the amp. and the "video in" slot of the LCD. It's important that which video input you've selected in your amp. to make this connection. For instance, if you choose "VIDEO 1", you will have to connect all plugs (Audio and Video) via VIDEO 1 slots. Good luck
Apr 17, 2007 | Pioneer VSX-D510 Receiver
Aiwa HT-DV90 System Logo
42 people viewed this question
Top Aiwa Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you an Aiwa Audio Player and Recorder Expert? Answer questions, earn points and help others
