Question about HP Photosmart 375 InkJet Printer
Paper feed will not grab paper, tells me to load paper or there is a paper jam.
    Guru:
  • 317 Answers
If paper is jam open the printer and remove it
if the problem still remain then take printer to printer shop
Posted on Jan 02, 2011
Paper Jam when paper loads into machine from paper tray about 2 inches in when printing. Then it tells me there is no paper, load more paper? All the while I am hearing a sort of screaching sound when it...
It probably needs to be cleaned. There may be bits of paper stuck in the mechanism. In addition, if the printer is old or has been used a lot, the rubber on the feed rollers may need to be cleaned and roughed up a little bit to grab the paper more firmly when feeding it through. Also, when you load paper, don't load too much, and flip the sheets in the ream before you insert the paper to allow air to get between the sheets, making it easier to feed a page.
Nov 19, 2017 | Brother MFC7360N AllInOne Laser Printer
My Kodak printer wont grab the paper in the paper tray
Amandasplace:
There is a sensor that is located where the front edge of the paper sits when you load paper. If you take all of the paper out of the feed tray and use a flashlight to look in the throat of the paper feed area, you should see a small piece of plastic (in the shape of a blade) sticking up. If you do not see that sensor flag it may be broken off, or there may be a small piece of paper jammed against the sensor flag, keeping it from moving downward when you load the paper tray. That can happen if you pull a mis-fed piece of paper out of the machine in the opposite direction that the paper normally travels when printing. When you load the paper in the machine, it pushes that sensor flag down, telling the machine that there is paper loaded. either the sensor flag is broken off or there is something jamming the paper sensor, keeping it from being pushed down by the paper.
Nov 23, 2012 | Kodak ESP Office 2150 All-in-one Printer
I can't get the paper feed to work properly. Printer is telling me to load paper when it is full of paper Printer is asking me to clear paper jam when there is no paper jam Printer is just not...
Leading cause of paper jams is debris/foreign objects that accidentally fell into the paper feed area. Please follow steps below to fix the problem:
1. Remove the sheets of paper from the feeder.
2. Grab a flashlight and look inside the feeder for any debris or foreign objects.
3. If you're willing and physically able, you may also turn the printer over. Any debris should just freely roll out from the feeder.
4. If feeder is clear, place the printer back on the table, open the printer cover and remove the cartridges.
5. Check the cartridge area for any obstructions/debris in the cartridge carrier's path or the paper path.
6. If cartridge area is clear, close the cover.
7. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
8. When the printer turns on, reinsert the cartridges and load some paper. Try to print again.
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Aug 15, 2011 | Lexmark X5470 All-In-One InkJet Printer
Paper Jam
Usually with lexmarks its the sensor in there, it either has something going across it
Ths other thing it can be is the pinch roller that is in there if you can clean it with a qtip and achohol
Aug 13, 2009 | Lexmark X5150 All-In-One InkJet Printer
Not grabbing paper
Try cleaning the rollers again and fan the paper. When you clean the rollers, use alcohol and a lint free cloth. Don't put too many sheets in the feed tray.
Feb 04, 2009 | Canon PIXMA MP170 All-In-One InkJet...
Paper goes crooked the jams
both wheels are not grabbing , they need to be cleaned
Oct 15, 2008 | Lexmark X1150 All-In-One InkJet Printer
Paper Out or Not Loaded Correctly (E-03) - BUT have paper in it!
Hi, please check if there is any foreign objects that was stuck when it try to grabs mulitple pages. Then power cycle your printer. Make sure also that the left edge guide or platen lever is seated correctly as the paper is loaded perfectly in the feeder and try printing. If issue still present it only means that the sensor that responsible in grabing papers in the paper feeding section is damage or the mechanism that holds the paper was get damage when the printer feed multiple paper at the same time. You may need to call the printer manufacturer and ask for service.
Tirzo
May 04, 2008 | Epson Stylus CX6000 All-In-One InkJet...
Paper completely jammed
check if there is a little paper that stuck on it that causes a paper jam
Mar 09, 2008 | Canon PIXMA MP210 Photo All-In-One Printer
Printing
Placing one sheet at atime is worse usually as these units feed off a minimum level. Keep them topped up to at least no less than 10 sheets. The printers sound like the have a paper feeding issue. Could be a jam. Open unit, check for paper jam. Cheers lilacgerry xxx
Sep 13, 2007 | Canon PIXMA MP180 All-In-One InkJet...
Out of Paper. Load Paper Error
Check
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00265823&cc=nz&lc=en&dlc=en&product=422000&dlc=en&lang=en
HP PSC 1600 and 2350 Series - Paper Jam or Paper Feed Problems"
When the all-in-one detects a paper jam, the following message appears: Paper jam: Press OK to continue . The computer might display the following message: There is a paper jam (or misfeed). Clear the jam and press the Enter, Resume or OK button on the HP PSC. This document will assist in correcting paper-feed problems such as paper jamming, print slanting, and multiple pages feeding into the all-in-one. s.gif Clearing paper jams
Jul 28, 2006 | HP PSC 2355 All-In-One InkJet Printer
HP Photosmart 375 InkJet Printer Logo
144 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
