Question about Plantronics Voyager PRO Bluetooth Headset
I ordered planronics Voyager Pro headset. I got a a day back. First day it worked fine with my PC but now when i on it, blue and red light are blinking alternately and doesn't stops clinking. It connects and then disconnects.
    Prodigy:
    An expert who has answered 500 questions.
  • 537 Answers
I can only think that this is not paired up, by the blinking pattern it sounds like it needs to be repaired back up.
Below is the link for the Explorer 320 User's Guide, which may help you.
Plantronics Explorer 320 User's Guide
Good luck from Headsets Direct!
Posted on Nov 10, 2011
Plantronics Voyager Pro bluetooth headset seems to be stuck in pairing mode. The lights flash red and blue, my motorola droid will show paired but not connect ed. If it does connect at all it will drop...
You want to turn off the power to your headset and turn off your phone. Remove for 30 seconds the battery from the phone and reconnect. Then follow the pairing instructions found on pages 4-5 in this link for the Plantronics Voyager Pro+.
Sep 01, 2011 | Plantronics Voyager PRO Bluetooth Headset
I lost my ear piece for my Plantronics Voyager 500A so I am trying to pair a new earpiece. How do I do this?
1. On the base, press and hold both speak volume fine adjust buttons until the blue talk/on line indicator light and red power indicator light (on the front of unit) start to flash.
2. On the headset, press and hold the listen volume adjust + button and call control button until the status indicator flashes red and blue.
3. Pairing is complete when the talk/on line indicator on base illuminates solidly, and the status indicator light on headset flashes blue.
Important: Make sure your headset is not connected to any other Bluetooth device when attempting to pair.
Jul 13, 2011 | Plantronics Voyager 500A Deskphone Adapter...
Voyager pro / can't turn off, can't re pair, light flashes red blue red blue
Had the same problem. Light just flashed blue and red. I decided to put the headset on the charger while it was flashing and after about 30mins of being left on the charger it started working normally again. Hope this works for you.
Jun 04, 2011 | Plantronics Voyager PRO Bluetooth Headset
MY VOYAGER PRO .. LIGHT FLASHES BLUE RED BLUE RED ... CAN'T TURN OFF, CAN'T RESET, CAN'T RE PARE
If you manually turn the headset off, make sure that it is by itself, no other phones in the area, no WiFi hotspots. Once this is done make sure that there is not a bluetooth already installed on the phone itself, if there is, delete it. Make sure that the headset has a full charge. Try the pairing again. If this still won't work, you can try Plantronics Tech service line 800-544-4660.
Here are two links that may be helpful:
Plantronics Voyager Plus User's Guide
Plantronics Voyager Plus Pairing Instructions
THE CHARGING LIGHT DOESN'T COME ON. I CHARGE IT DAILY BUT WENT ON A TRIP FOR 5 DAYS AND WHEN I RETURNED THE LIGHT WON'T COME ON...RED OR BLUE.
Per Plantronics: The Voyager Pro is not a moisture resistant headset. So if you have worn the headset during work outs or outside in excessive heat it could cause it to fail.The only solution is to have the headset replaced if still under Plantronics one year warranty.
May 23, 2011 | Plantronics Voyager PRO Bluetooth Headset
I connected my plantronics voyager pro to my blackberry bold and they connected fine (never asked for passcode) but there is a continual beep in the back round that makes the sound of the other call be...
Try to re-pair the headset to your phone to make sure that it has a good connection. Before running through the pairing process, be sure to totally delete the headset from the Blackberry's menu. You may want the headset turned off for this process.
Once you make your Blackberry discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Plantronics Voyager Pro Pairing Instructions
May 02, 2011 | Plantronics Voyager PRO Bluetooth Headset
I bought the plantronics voyager pro bluetooth headset two months ago and now it's dead. It's been working great for two months. When it's plugged into the wall for charging the red light is illuminated....
One thing you can try is to power down and then power the headset back up. The instructions are on the link below for the Plantronics Voyager Pro, particularly the page "Listen To The Voice."
Plantronics Voyager Pro User's Guide
If that doesn't help, then you have a bad processor in the headset. It's still under warranty so contact Plantronics at 800-544-4660 x5 x5538 for warranty service.
Apr 28, 2011 | Plantronics Voyager PRO Bluetooth Headset
I cannot connect my Plantronics Voyager Pro to my iPhone 4.
Once you make your iPhone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Jan 25, 2011 | Plantronics Voyager PRO Bluetooth Headset
I have a samsung rogue and I all I hear is mostly static with the Plantronics Voyager PRO
Make sure that it has a good connection, try to re-pair the headset to your phone. Before running through the pairing process, be sure to totally delete the headset from the phone's menu. You may want the headset turned off for this process.
Once you make your cell phone discoverable, then put the Plantronics Voyager Pro headset into pairing mode by holding the power button until the headset flashes red and blue. Here is the link below for the Voyager Pro pairing instructions.
Dec 25, 2010 | Plantronics Voyager PRO Bluetooth Headset
Cant set to my phone
Dec 13, 2010 | Plantronics Voyager PRO Bluetooth Headset
Plantronics Voyager PRO  Bluetooth Headset Logo
79 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
Ed Nelson
Ed Nelson
shaun taylor
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
