Question about Brother XL-5700 Mechanical Sewing Machine
The pressue foot will not stay down? - Brother XL-5700 Mechanical Sewing Machine
I have a viking designer 1. When I put the embroidery arm on the pressed foot will not stay down. But does stay down when regular sewing arm is attached.
When embroidering, the presser foot hovers above the fabric a few millimeters. The machine does this automatically.
May 04, 2015 | Sewing Machines
When I sew, the stitching is loose with large loops on the underside of the fabric making the bobbin thread slide out easily. How do I fix that?
Lift the pressue foot off the fabric. Hold the thread spool with one hand and lightly pull the thread hanging out the back of the needle. This should seat the tread into your top tension discs properly. Now try sewing again. If it still throws loops, you either do not have your machine threaded correctly or your tension on top is set to zero.
Sep 01, 2014 | Bernina Sewing Machines
Why won't my presser foot drop down?
There's a screw that connects the two together, it probably fell out
Aug 13, 2014 | Sewing Machines
Singer 9015
Sounds like the linkage between the lifter and foot is caput. If you open the case, you void the warranty.
May 22, 2014 | Singer Sewing Machines
Singer SM MN 93234--pressure foot lifter won't stay lifted, falls down. What to do?
sorry can't help you there may be you need it check by a sewing machine mechanic may be a screw is lose and need to be tight.
Apr 14, 2014 | Singer 7422
The pressure foot won't go all the way down
take off side plate and loosen pressure ft screw . it should snap down. make sure the foot stays align wit the needle. u want the foot slot with needle in ctr.
Oct 20, 2012 | Juki TL-98Q
Brother XL-5130 machine...cannot get it to darn or embroidery work. I covered feed dogs with the plastic cover but cannot find a lever to put down the feet. With presser foot lever down (no feet and not...
You probably do not have lever to put the feed dogs down. That's why you have a cover. To free style embroider or darn you don't need a foot but the presser foot has to be down and as you run the machine, YOU will be doing the stitching by moving your fabric back and forth. This is usually done with a wooden embroidery hoop so that your fabric stays taught. I have done it on jeans without a hoop. Hope this helps.
May 18, 2010 | Brother XL-5130 Mechanical Sewing Machine
Lights turn on but foot pedal stays dead. Needle
If you know someone who is savvy in the mysteries of electricity, ask them to test the foot pedal to see if it is working and the socket on the machine to see if it is receiving power.
If you need a new foot control pedal - check the Internet for best prices - you will need the machine's model number.
If you take the machine to a dealer for service, ask what it will cost before making the trip.
The bench rate for just looking at the machine may not be worth it.
Oct 21, 2009 | White Sewing Sewing Machines
Viking Designer 1 presser foot will not stay down
The foot should come up slightly above the fabric when in embroidery mode. If not, the fabric could not move.
The foot should come up the same distance that it would if you were to put the foot in the pivot position while sewing. If it is coming up more than that, then you have a problem and will need to see and authorized technician.
Apr 19, 2009 | Husqvarna Designer I
Brother XL-5700 Mechanical Sewing Machine Logo
18 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
