Question about ACE Dimplex (r) Compact Electric Fireplace (DFP36430) Heater
Hello, I have a Diplex Elec. (Optiflame) Fireplace in my RV. It has operated very well for a long time, however, the motor drive on the flame effect rod now creates a bit of noise at any speed, clicking, grinding, etc....Where can I go to find a replacement motor drive for this rod? I would appreciate the assist. I will be making the repairs myself.
3 Suggested Answers
SOURCE: motor in dimplex fire/heater not turning
Hello. It could be possible that a piece or some of the foil that gives the flame effect has fallen down on the motor, that creates the heat. This could be causing the noise. I would not think this is an electrics problem.
I would ensure the electric fire is disconnected from any power supply and either open the heater myself or get a electrical specialist to have a look. Then you will see exactly what is happening. A piece of foil may be visible which is catching the motor.
If you decide to tackle the problem yourself write down how to put the heater back together as you take each part out. These parts would be covers etc. It can easily get confusing. That is important.
Posted on May 19, 2009
  • 4736 Answers
SOURCE: the flame effect isn't working.
You can either purchase one from DimPlex or online from Granger Electric.
Posted on Feb 02, 2011
Dimplex dakota heater is working but flame effect is not its led I think not bulbs.
Says you can turn it on and off? Did you knock the switch?
Can I operate the flame effect on the fire without the heat?
All our Optiflame and Opti-myst fires can be operated on a flame-effect only setting, as can the flickering flame effect on our freestanding bar fires.
Is the flame effect expensive to run?
No, to run the flame effect involves powering light bulbs and a small electric motor and in most cases costs no more than a couple of pence an hour. Some of our fires have LED lamps fitted which are even more energy efficient.
Some have bulbs, some have LED.
Example calculations:
Using UK standard average price of electricity of 14p/kWh (source: Energy Saving Trust Feb 2015)
Optiflame LED flame effect only (eg Danesbury) = 0.1p every hour
Optiflame conventional bulb, effect only (eg Cheriton) = 2p every hour
Opti-myst, flame effect only (eg Oakhurst) = 3p every hour
Opti-V single screen = 0.5p every hour
2kW fan heater, on constantly (no thermostat) = 28p every hour
Optiflame lightbulbs for sale. Remove the coals and check for bulbs.
https://store.gdcgroup.co.uk/dimplex/products/index.htm?product_code=FP03022
Dec 23, 2015 | Dimplex Heating & Cooling
Tip
Flame Electric Fireplace Electric Fireplace Heat
Fireplaces have become the heart of the home, a warm place to gather with friends and family. Fireplaces turn any blank wall into a gorgeous focal point. A fireplace fits any decor and is a stylish addition to any room. Electric fireplace logs have improved greatly over the past few years and now days can look so good that they can fool people into believing that they are looking at a real fire, something which is especially true when you have crackling effect of fireplace logs, which aim to imitate the sound of a real fire.
Even though electric fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. If you need a fireplace to heat your home you may want to consider a gas fireplace for better efficiency. If you need a fireplace for more decorative purposes a cheap electric burning unit might better suit your needs. The electric fireplace has experienced a quantum leap from those electric logs with reflective tin foil drums that adorned the hearth while the lava lamps were in vogue. An electric fireplace can add a great deal to a home, in terms of both form and function, and are also very effective at heating up a room.
Electric fireplace heaters simulate the look of a fireplace, but don't actually burn gas or wood like a traditional fireplace. Electric fireplace inserts simply fit into existing fireplaces and provide an artificial fire that creates the warmth and ambiance you want with just a flip of a switch. A modern electric fireplace insert does not require any type of venting system and many units are portable.
Even though these fireplaces do not generate flame, most provide the effect of a fire, which ranges from an orange light shined through plastic logs to simulate the appearance of coals burning, to an elaborate flame projection on the doors of some of the free-standing models. They plug into the wall, and can run on a "flame only" setting, or can be used as a heater, typically with 4,500–5,000 BTU (4,700–5,300 kJ), that can heat a 400 sq ft (37 m2) room. Since there is no real flame or combustion taking place, electric fireplace heaters release no toxic fumes or dangerous gases.
Everyone knows that a fireplace is about more than heat, especially when you're looking at a real fire, when one of the most entrancing things about it is the fact that you can see real flames. Most electric logs use a standard 110 volt power source, and come with various levels of flame of brightness. By choosing a really good set of electric fireplace logs, and particularly those which have a crackling effect and real flames, you can be assured that your fireplace will not be simply a unit in the room to make the room feel warm, but will be something that you enjoy looking at as well.
Electric fireside inserts are also a good option if there are issues with your hearth which make them a hazard with wood burning fires. Electric fireplace log inserts typically include an electric fireplace log set and an ember bed, and inserts are incredibly easy to install. Electric fireplace inserts are safe and clean. Most importantly whether you choose a modern electric fireplace or any other type make sure it will be most cost effective and suitable for its purpose in your home.
http://www.fixya.com/support/r3710316-portable_heat_flame_electric_fireplace
on Dec 24, 2009 | Heating & Cooling
Fire was working fine, then flame effect stopped. Heater still works on both settings, but no flame effect. Tried new bulbs, but still no flame effects, any ideas?
If it is not the bulbs, it is often a melted switch or circuit board.
You can obtain technical support for your stove here:
Dimplex Technical specialists:
1-888-346-7539
Monday - Friday
8:00 a.m. - 4:30 p.m. EST
Jan 05, 2013 | Dimplex Compact Electric Flame Stove...
Flame effect electric fire loud clicking noise
You need a new synchronous motor. This is the small motor which turns the flame effect rod. They are notorious for becoming noisy.
Nov 06, 2012 | ACE Dimplex (r) Compact Electric Fireplace...
Have a SHB 20LC Focal Point fire with Optiflame Elite that has the flame effect motor not working and requires a new motor as indicated by a technician, but he has said that he can not source a motor. Can...
I have exactly the same problem, light effect just went out tonight. Trying to work out if it is the motor or that little tiny cream box fixed to the terminals inside. If I take it out the lights come on. Just about to see if the motor is working, just that box that has gone.
Aug 05, 2010 | Dimplex Compact Electric Flame Stove...
Noisy optiflame motor on dimplex cheriton fire
If you are referring to the motor of the flame effect, these are called synchronous motors (commonly used in microwave turntables. Any syncronous motor should do as a replacement, but check whether you need a 12v model or a 240v model. This information should be found on the label on the back of the old motor.
Nov 30, 2009 | Dryers
Charmglow electric fireplace . no light for flame effect
the fan is working. I do not have the flame effect fixed. I find this web site difficult to get any help from.... seems to go around in a circle. Just tell me if it can be fixed.. I want to know about the bulb (?) or whatever makes the flame effect. Nothing seems to be able to take apart , if not do you have a website I can get to for a new one.....thanks....
Mar 25, 2009 | Fire Sense Georgetown Electric Fireplace
Motor in dimplex fire/heater not turning
Feb 02, 2009 | ACE Dimplex (r) Compact Electric Fireplace...
Heating & Cooling Logo
180 people viewed this question
Top ACE Heating & Cooling Experts
Andrew Taylor
Andrew Taylor
Tim Whalen
Mack Baxter
Are you an ACE Heating and Cooling Expert? Answer questions, earn points and help others
