Trying to hook up dbx cx3 preamp to audiosource eq eight\11 and kenwood km991 dont have manual for preamp need help on what plugs in where
  • Anonymous Apr 01, 2014
    The preamp says dc9v on it.
  • 8,197 Answers
You can get the manual for the cx3 on the link below.
http://www.dbxpro.com/product_downloads/Owner_Manuals/cx3-mkII_Manual.pdf
Good Luck
Posted on Jan 02, 2011
How to hook up a DBX 231 to an Onkyo P301
you will need 4 1/4 inch male to rca male cables, use tape monitor (tape out to line in on eq, line out from eq to tape in on receiver, make sure both buttons that control line level on the back of the 231 are set for -20dbv press tape monitor to use eq, turn off to bypass it.
Mar 06, 2014 | DBX Audio Players & Recorders
AUDIOSOURCE EQ EIGHT REPAIR MANUAL
all of the level light's stay on and I got a hum and not music
Aug 31, 2012 | AudioSource Eq Eight/ Series Ii Graphic...
Looking to hook up an audiosource EQ100 to an a sony cass deck
Simply place it in line with the analog input. Or install it in a Tape Loop on your integrated amp/receiver and attach your tape deck to ITS tape Loop.
Ins to Outs
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec, Line-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play , Line-Out.
Be advised, using analog processors on digital-capable multichannel elcetronics will only work for analog 2-channel sources.
Mar 05, 2011 | AudioSource EQ-100 Home Equalizer
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
Bose 901 Active EQ Loop
There's good news and bad news. The bad news is that a multichannel receiver with Bose 901's will only sound right in STEREO on stereo analog material. For one thing, the other speakers around the room are not designed to recieve its Active Equalization and for another, if you engage your Tape Monitor you will not be able to play digital sources. Tape Monitor is for analog stereo material only and on my receiver it disables any digital inputs.
The good news. I have a setup similar to what I think you're trying to do and it works great!
A separate stereo amp for the 901's was my solution. I run a Carver AV-406 (5-channel amp) for my 901's in Front, 2 Subwoofers and the Rear Surround channel, with the Active EQ between the receiver Front L&R Outputs and the 901's amp channels. My receiver controls everything and just drives the Center and Surround speakers. You could get by with just a stereo amp for the 901's. A Carver M-200 is a good efficient amplifier that would have you cooking just fine (2x100W).
Run the dbx and BSR in tandem with each through the tape monitor loop on the receiver but be advised you can only use them on analog source stero material. However, you can still employ the various DSP options to spread the sound around the room.
At my PC workstation across the room I have a stack of analog processors and sources including dbx 3bx-ds, dbx 120x-ds, BSR Spatial Enhancer, BBE 462 Sonic Maximizer, SS-525x EQ, Carver C-9, dbx-224x, JVC cassette deck, Dual 1249 Turntable running through a Garrard MRM-101 Preamp, Pioneer PDR-509 CD Recorder and the Media Center PC stereo analog channels all running through a dbx 400x Program Route Selector (a godsend) which is attached to my ONE TAPE MONITOR on my Pioneer VSX-36TX Receiver. Of course, I have some of my analog processors running in tandem, too, since the 224x only has three processor and three tape loops.
For listening/recording anything 2-channel analog I engage the stack through the Tape Monitor. For everything else I turn the Tape Monitor off. The nice thing about the stack being separate is that I can doodle with recording and use headphones while the TV/DVD/Blu-Ray do something else.
Jan 10, 2009 | Onkyo TX-SR705 Receiver
No clue how to connect my equalizer
FOR EXAMPLE IF YOU WER HOOKING IT TO A CD PLAYER,, YOU WOULD PLUG RCA JACKS IN THE LINE OUT ON THE CD PLAYER,, THEN PLUG THEM IN THE EQ WERE IT SAYS LINE IN OR AUDIO IN,,THEN TAKE SOME RCA JACKS PLUG IN THE EQ TO AUDIO OUT, THEN TO YOUR RECIEVER,, IN CD ,,AND VISE VERSA ,,WETHER ITS A TV OR PHONO,, ANYTHING,,
Sep 25, 2008 | AudioSource EQ-100 Home Equalizer
Pioneer spec 1 and spec 2 hook up with RG 2 processor and audiosource eq 1
preamp out---------to equalizer in-------------equalizer out----to amplifier in-----------amplifier out----------to loudspeakers.
Jun 12, 2008 | Pioneer Audio Players & Recorders
Connect a kenwood amplifer to a graphic equalizer
There are several ways to hook up a EQ to amp. If you have a tape monitor unused, you can plug tape-in of amp to 'out' of EQ.
Plug tape out of amp to 'in' of EQ (both channels). When you engage monitor on amp, EQ will work.
May 28, 2008 | Audio Players & Recorders
Hooking it up!
If the amp has PreIn PreOut connections, then thats the best way to go. Home theatre amps however, have 5 InOuts, and this makes it hard. You can use the tape loop. Hook up the rec out on amp to inputs on EQ, and output of EQ to tape in an amp, then engage the tape monitor function whilst ensuring that the rec selector has the source you wish to use the EQ for.
Nov 08, 2007 | AudioSource EQ-200 Home Equalizer
136 people viewed this question
 Grubhead
Grubhead
