Question about Beverage-Air Beverage Air ''Prestige Plus'' 74 cu. ft Solid 6 - 1/2 Door Reach-in Refrigerator - Top Mount Compr...
Model #ER74las 3-door cooler Running to cold How do you adjust temp
  • Beverage-Air Master
  • 1,165 Answers
Http://www.beverage-air.com/Main.aspx?pid=31&tab=32
check out their web site. It has lots of manual for what you are looking for. Hope this helps
Posted on Jan 15, 2011
Wine temp on Haier wine cooler BC112G went to LL, opened up and some champagnes frozen, other wines very cold, condensation all over door, how do you fix this error?
The error is likely caused by a bad temperature sensor. The control board may still be Okay.
Replacing both of them is recommended.
Check this link for parts: http://www.partstore.com/Model/HAIER+AMERICA+TRADING/Haier/BC112G.aspx
Dec 31, 2010 | Haier BC112G Wine Cooler
I have a GE(PSS26MSTSS) Profile refrigerator. The temperature in the all the bins is much cooler than the set temperature. The food is freezing in those drawers. Is the damper that controls the air from...
thats because when you open the door ALL the cold air rushes out.(the bins stop this effect)use a thermometer in the middle bin and adjust the running temp accordingly,this will also stop your lettuce from freezing.
Nov 15, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
My wine cooler stopped cooling and running
What model # do you have? Is there anything working at all like lights, fans, or displays?
Sep 07, 2010 | Emerson (025806803716) Wine Cooler
Freezer door left open for 3 days lots of melted, refrozen ice in freezer motor seems to be running a lot more now
ice is not a good insulator,defrost the whole machine and dry out thoroughly,then start up as if new.....
Jul 08, 2010 | Maytag MTF2155GRW Top Freezer Refrigerator
Hi My freezer is working great however my refridgerator side seems to be a tad warm, I have tried to clean the compressor and even turn it to cooler settings , this unit is only 1 year old
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
Jun 01, 2010 | Refrigerators
LG Bottom freezer refrigerator Model LFC21760 does not cool
Sep 28, 2009 | Refrigerators
Freezer works fine but fridge side stays at about 45 degrees
First, I think it’s important to know that the Ref side has no cooling coils, it’s basically a box and the cold air in the freezer is blown over by a fan through a channel into the Ref side. This channel has a door which regulates how much cold air goes through. You probably have two control knobs in the Ref side, one controls the temp with numbers 1-9, 9 being the coldest. This temp control tells the compressor how long to run. The other control is for that little door and it may have letters A-E, E being the coldest. If you set it on E (coldest) then this will close that little door and keep most the cold air in the freezer.
Now, why is that cold air not getting over to the Ref side?
1. The little door is not open.
check your control setting. You should be able to feel air coming through the channel on the Ref side.
2. The fan in the freezer is not working.
You can hear this fan running when you open the freezer.
3. The coils on the freezer side are clogged with ice which won't let the fan circulate the air over to the Ref side.
This is a failure of the defrost system.
Jan 10, 2009 | Nor-Lake Norlake Refrigeration 4' x 6'...
Beverage air cycling off/on
These units are not designed to run in temps much lower than 50 degrees. They have no winter controls and the freon pressures will take a nose dive when running in a cold ambient condition. The unit will not run well in a cold environment, compressor damage may result. :(
Dec 16, 2008 | Beverage-Air Beverage Air 2- Tap Unit...
Temperature 94 in refrig. normal in freezer
Check to see if refrigerator door is lower than freezer door. If so remove toe panel, (bottom front). Under refrigerator door hinge at bottom right is adjuster for door. Adjust upward so door is even. On some models when door is too low it causes light to stay on some times, raising ref. temps.
Nov 04, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Beverage-Air Beverage Air ''Prestige Plus'' 74 cu. ft Solid 6 - 1/2 Door Reach-in Refrigerator - Top Mount Compr... Logo
73 people viewed this question
Top Beverage-Air Refrigerators Experts
Dennis Boxerman
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Beverage-Air Refrigerator Expert? Answer questions, earn points and help others
