Question about Vizio Televison & Video
My two year old grandson knocked VIZIOe$20va 42" lcd tv ccfl atsc hdtv 1080P over. It has no physical appearing damage but we can not reconnect to receive either audio or visual input?
  • 4 more comments
  • Silverpengui Jan 02, 2011
    The TV was connected by HDMI to HDMI cable --. Are you saying we should not try to reconnect it that way?
    did you get my previous comment where I said we used hdmi cables? -- Because I just received this response again
    ignore my last e-mail -- didn't see small print at bottom of one you sent -- sorry
    tried everything -- no luck
    Cable box is fine. Tested it out on another TV. TV get power, but the screen stays dark like it is off. I believe that the back light is what is wrong. Does this sound right?
  • Silverpengui Jan 03, 2011
    Thanks for your help, but you didn't give us anything to do we would be comfortable doing, beyond just rehooking up.And a cursory look for something obvious.
    I have an American express guarantee that will fix or replace the TV, but was hoping for a simple way or reconnecting or determining the extent of damage. I'm not willing to risk causing major damage voiding the warranty, etc., as an amateur working on something I know nothing about. Or spending a substantial amount of time finding out it is something we
    can't fix anyhow. I'll chalk up the $12 to win some, lose some & take it to a service center for an estimate.
  • Vizio Master
  • 19,396 Answers
Hi.
The only thing you can do at a user level is the following power reset and testing. If that does not work, then the TV must be disassembled and tested at component level by a technician:
Turn off TV and any connected device.
Disconnect TV power cord.
Disconnect any connected device (eventually mark cables with stickers first)
Connect back receiver box only using HDMI.
Connect back power cables of TV and box.
Turn receiver on first.
Turn on TV.
Eventually use the Source/Input button to locate a source.
If still does not work, check if the TV displays on screen menu or not. If there is no on screen display or raster, try using a replacement cable.
If still no luck after the above, then the TV must be tested by a technician. In that case use your warranty to get the set repaired.
Best regards.
Ginko.
Posted on Jan 03, 2011
  • Vizio Master
  • 6,993 Answers
Maybe you did not get the TV and receiver connection right, that's why there is neither video or audio.
Using a RCA (Yellow, white and red wire) connection, connect the yellow (video) from video out of the receiver to video in of the TV. The same goes to Audio (red and white wire).
Turn on the receiver, put your TV on AV and there should be a display and sound. If there isn't sound/video, then maybe there is some disconnection in the TV when it fell over.
Get a screw driver, disassemble the TV, remove the TV back cover and carefully check all the components on the TV board. Make sure every thing is intact before assembling back the TV together.
But I believe there should be any damage in your TV. I just hope is a mere wrong connection problem between the TV and receiver.
Also, check the back receiver, make sure all wire connections are intact.
Good luck.
Posted on Jan 02, 2011
  • 2 more comments
  • Walesarumi
    Walesarumi Jan 02, 2011
    Yes, don't connect it that way, use RCA connection method. This will help to reveal if there is a problem with the TV or not.
  • Walesarumi
    Okay, that is no problem at all. Just keep in touch when you need more assistance.
  • Walesarumi
    do you have a small TV or another TV so that you can use it to test the receiver and see if it will work. This will make us know exactly if the problem is from the receiver or if there is some kind of disconnection in the TV when the TV fell over.
    If the receiver works on another TV, then maybe the video can or something else has been disconnected inside the TV which will make you end up disassembling the TV.
    Good luck.
  • Walesarumi
    That's close, but at least the sound should come up if its actually a back light or display problem. I think there is more to this problem.
    Have you disassembled the TV?
How to fix a 1/2 black screen
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Oct 19, 2014 | Magnavox 42MF439B 42" 1080p LCD TV - 16:9...
1/2 of screen turns black, what can I do to repair it?
You may have a faulty T-con board or bad connections at the screen sockets,the contacts on the flexible circuits can be cleaned with an eraser but be carefull not to bend or in any way damage these ,the result will be the need to replace the whole set..
Le
Oct 13, 2014 | Magnavox 42MF439B 42" 1080p LCD TV - 16:9...
42mf439b/f7 Magnavox LCD TV How to replace invertor modual
Oct 08, 2014 | Magnavox 42MF439B 42" 1080p LCD TV - 16:9...
Vizio 42" E421VO 1080p Widescreen LCD only shows 480p why
In order to help you out with this, I would need to know which input you are attempting to use, what the source content is and what kind of cable(s) you have hooked up to the target input.
Apr 28, 2014 | Vizio 42" E421VO 1080p Widescreen LCD HDTV...
Televison & Video Logo
79 people viewed this question
Top Vizio Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
