Question about Maytag Dryers
My dryer is throwing the breaker when I put a full load of clothes in it. If I cut it in half ( a light load) it doesn't. Is that the belt or the breaker?
    President:
  • 662 Answers
It might be the belt - but I'd first suspect that the bearings have lost lubrication and need to be
lubricated.
This happens on all dryers, and I find that every year I have to tear into my friends dryer and grease
the bearings to keep it running happily for another year.
STEP 1: take back cover off and clean out all the lint - lint is ALWAYS part of the problem when
a dryer is having a difficult time rotating its drum.
There're 2 sets of bearings to worry about:
(1) motor bearings - add some light lubricating oil (not grease) to the rotating ends of the motor
Difficulty: easy
Cost: zero - if you have a can of 3-in-1 oil handy - or any motor oil (like for a car).
(2) roller bearings - add some grease to the posts on which these 2 rollers rotate.
Difficulty: moderate in the case of the roller under the drum - the one near the motor is easy.
Cost: $zero - if you have a can of automotive bearing grease lying around.
Cost: $3 if you need to buy a can (its about the size of a large can of peanuts &has a plastic lid).
I don't suspect the breaker - it seems to be doing a good job of protecting your dryer from burning
itself up by trying with all its might to turn that drum which is so difficult to turn due to
loss of lubrication on its bearings.
Happy new year and may you always have dry clothing.
Posted on Jan 02, 2011
  • Archaeology
    Archaeology Jan 02, 2011
    oops - forgot to mention that the last dryer I looked at (a Kenmore) was turning poorly
    due to having one of its rollers actually come apart from its own inner hub - the outer
    plastic part had separated from its own hub and was rotating around it - the hub
    had seized onto the post.
    the fix was to replace the roller, and grease the roller post.
    Cost for a new Kenmore roller: $13 sales tax
    President:
  • 2,468 Answers
Check the drum bearing, drum wheels(if so equipped), drum glides and drum motor,possibly the bearings are getting dried up on the motor shaft and causing a high start/run current,otherwise,yes the breaker could also be weak,also, but not likely the heating element can be starting to short out to the case and grounding out causing a high current draw problem,but not very likely due to its ok on light loads,just not heavy loads
How do I dry clothes
Either hang them up wet or put in clothes dryer
Nov 26, 2014 | Malber WD1000 Front Load Washer/Dryer
Dryer will only spin with small load
You need to replace the belt that will solve all your problems.
Oct 17, 2012 | Dryers
My whirlpool cabrio front load dryer will power on but when you press start it doesn't. All it will do is light up under "sensing" but never moves on to actually dry the clothes. I have...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 18, 2011 | Whirlpool Dryers
Maytag dryer model number lde7334ace wont spin a full load of clothes we put a new belt on and fan blade now it wont spin a full load
recheck the belt, Tim:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Apr 06, 2011 | Dryers
We have to put only a half load of clothes in dryer and then run through at least 2 - 3 cycles before they will dry, sometimes more. Someone told me it sounds like a sensor might be bad, and that there are...
A simple fix may be to just reset the circuit breaker. Sometimes on a double pole circuit one breaker trips which still allows for the dryer to operate with little or no heat. If that does not work, check the vent to insure good air flow and no blockage. If either of these do not resolve the situation you need to look at the thermostat or the heating element itself
Feb 27, 2011 | Dryers
I have jst purchased this washer today, however the dryer takes ages,,,,,,their seems to be water going in when its drying, clothes come out hot, but still as damp as when i put them into dry.
Hi, this is normal for a washer dryer, water isn't actually going in, it is condensating and then being pumped away.
when you use the dryer program your are only meant to put half the washing load or less in at a time if there is too much wet washing in the machine it will take forever to dry as it cant get rid of the amount of condensation quick enough so some of it is reabsorbed into the clothes and so it goes on.
so the trick is only to put in a maximum of half the full washing load.
Hope this helps.
Feb 11, 2011 | Hotpoint Ariston WD440G Front Load...
My Whirpool dryer Mod. LEN 2000LWG, type DWSR-ELE-2406028-CV54, Imperial Series, was working fine, but after the second medium sized load it stopped drying the clothes. I finally noticed that the inside...
The Hum most commonly means that the drum belt on your dryer is probably broken
There is a simple way to test for this.
1 remove the clothes from the dryer.
2 put your hand inside the drum and turn it. If it is easy to turn, the belt is broken. If it is difficult to turn, the belt is good. You may be looking at motor problems.
Almost all of the time, it is a broken belt.
The link below has the full procedure for changing the belt.
Hope this helps,
Best Regards,
Mark
http://www.fixya.com/support/t6322596-get
Jan 19, 2011 | Whirlpool Dryers
Kenmore Dryer Model No. 110.64632300
If it is 6 years of age or older and have a lot of use in the past you will be better off replacing it. The cost to repair it will outweigh its age and cost to repair
May 20, 2010 | Magic Chef CYE4000AWW Electric Dryer
Dryer wont tumble when loaded.
check for a "glazed" drum belt or a broken "idler" pulley near or on the motor that keeps the belt tight on the drum
May 10, 2010 | GE DBXR463GB Gas Dryer
Squeaking due to weight of clothing
When you need this kind of noise and there is no abnormal vibration, then it depends on the drive pulley that pull the belt.
If it depends on the weight, and you get vibration it can also depend on bad dumper pads.
Here you can locate dumper pads and drive pulley below the tub.
Both parts are serviceable, repair should not be expensive.
If you need to contact a repair service, you can use the number listed on the owner manual.
Sep 05, 2008 | Hotpoint NWSR483EBWW Electric Dryer
Dryers Logo
85 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
