Question about GE JTP45 Electric Double Oven
Door to oven does not close completely - how do I access the door hinge to check or replace it?
  • rbkleiman Jan 03, 2011
    How do I remove the hinge from the frame? Do I need to remove the front frame to get a hinge out, and if so, how do I remove the front frame?
  • 552 Answers
Click on the link below to watch a video that explains how to remove the oven door.
http://www.appliancerepairlesson.com/2011/01/22/oven-door_diy-oven-repair-help-101/
Posted on Mar 06, 2011
  • 1,543 Answers
Open oven door. Flip metal holder down at hinge to lock hinge. Lift door with hinge attached up slightly and off oven. Reverse to re-install door, making sure notch at bottom of hinge is hooked in frame of oven properly.
Posted on Jan 02, 2011
2 Suggested Answers
  • 1462 Answers
SOURCE: Oven Door Doesn't Completely Close
no adjustment. probably needs new hinges - hinge spring gone slack
Posted on Mar 20, 2007
Door will not close completely leaving 1cm gap at top.
If the door closes fine till that 1cm gap hinges more than likely wont solve it you need to replace the supports that the hinges slot into
Dec 13, 2013 | Electrolux EOG6330 Gas Single Oven
Door will not close completly
When you say "oven door will not close properly", do you mean that it closes but not tightly against the rubber seal on the oven cavity?
Or is it some other closing problem?
If it is the former, then it is a sign of the door hinge springs wearing out. The solution to this is to replace both hinges on the offending door.
Sep 08, 2011 | Ovens
Oven door won't quite close tightly. I can push it about another 1/4 inch to close it completely.
You need to replace the hinges in the door. Go online to a spares website and enter make and model and order new hinges. You can replace them by unhooking the door, just takes a little effort, you might need to flick back latch on hinge and lift out. Remove inner door panel, usually 4 screws and remove. then change hinges. The 2 big pieces are the hinges.
  • images?q=tbn:and9gcsg1plmaxnucdapg-xpimmjauz_p4kgblmyf6iotcmgyh-hv4v3
Mar 09, 2011 | Ovens
Oven door does not close properly, light stays on.
Check the hinges at the bottom corners to see if the spring is still connected and see if the hinge is wore out. The door lifts off the hinge when it's in the partially open position after loosening the screw holding the door in position on the hinge. Slide the oven out a little to access the hinge to replace or inspect.
Jan 01, 2010 | Kenmore Ovens
My oven door doesn't close completely. Is there a way to adjust the door?
Hi There
I found this for to read so you can fix your door.I hope this will help you.Let me know how it goes.
The oven door won't close If your oven door has gotten bent or warped (maybe you rested something heavy on it…), you need to remove the door, disassemble it, and straighten it. You can lift most oven doors off of their hinges by opening the door several inches to its first "stop," and lifting the entire door straight up. If the hinges have become worn, damaged, or bent, you probably need to replace them. We recommend replacing both hinges at the same time, to prevent uneven wear of the undamaged hinge.
Thank you for writing to fix ya.
Best Regards Richard
Dec 30, 2009 | Ovens
I have a Neff U1420 double oven and the hinges on the main oven do not close the door fully. I have read that it is possible to correct this problem by putting washers under the screw of the hinges but I...
Hi.
If the door does not close properly then the fault is a faliure in the door hinge springs. Sorry but using washers will not cure the problem..
The only way is to replace the two door hinges. You may NOT need to replace the hinge backs.
If you would like to email me the full model number (numbers after U1420) then i can source the part numbers for you.
regards
Aardvark Repairs
aardvark.repairs.btinternet.com
Nov 17, 2009 | Ovens
How to remove door for whirlpool oven RBS305PDB2
open the door about 1/3 of the way and lift it off the hinge pins. it helps to have two people do this. when it is time to replace it, put the hinges in that 1/3 open position and slide the door back down on.
Oct 02, 2009 | Whirlpool RBS305PD Electric Single Oven
Jenn-aire JJW8530dds
It might be because when the door was completely removed ( which they do rather easily for repairs and moving) it wasn't put back properly.
I would suggest you remove the oven door and re install.
You do not remove any screws or anything like that to remove the oven doors.
When you have the oven door open squeeze each hinge and shift then both outwards it will release the door from the hinge, the hinge stays on but the door will slide off the hindge. Afterwards check the alignment and reinstall the oven door
Aug 02, 2008 | Jenn-Air JJW8330D Electric Single Oven
Mar 10, 2007 | Miele Novotronic H350-2B Electric Single...
GE JTP45 Electric Double Oven Logo
1,208 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Oloyede Monsuru
Are you a GE Oven Expert? Answer questions, earn points and help others
