Question about Nokia 6133 Cellular Phone
The sound on my Nokia 6133 has stopped
The vibration works just fine. I can receive calls but the phone doesn't "ring" nor does the text message alert sound or the alarm. i have had the phone since May 2008 and it was fine until about a week ago. i did NOT get it wet either.. please help. Thanks..
  • tbrasky Jul 09, 2008
    Thank you. The settings are all fine. I will take to t-mobile where I bought it.
  • 43 Answers
Sounds like a short or a setting peoblem.try to set it and if that doesnt work take it to where you bought it they will look at it for you for nothing.i encountered this before.my problem was a short.
Posted on Jul 09, 2008
  • 87 Answers
Please change profile setting
My sidekick lx text alert tone does not work. the sidekick does not vibrate or make a sound when i receive a text.
This most likely has to do with the sound profile that you currently have set. Go into the sound options, see if there is a detailed option available to increase/decrease the ring volume or vibration.
Some phones have the option to turn on an alert and vibration for text/incoming call.s
May 02, 2011 | Cell Phones
How do I adjust the volume,too LOUD?
Hello jinniq51,
i have some tips on how to do it hope it helps :D
Settings
In this menu, you can adjust various phone
settings. To reset some menu settings to their
default values, select Restore factory set.
Tone settings
Select Menu > Settings > Tone settings and from the available
options:
Ringing tone-To set the tone for incoming calls
Ringing volume-To set the volume level for the ringing and
message alert tones. If you set Ringing volume to be level 2 or
above, your phone rings with the ringing volume ascending
from level 1 to the level you have set when there is an
incoming call.
Vibrating alert-To set the phone to vibrate when you receive a
call or a text message
Message alert tone-To set the tone to sound when you receive
a text message
Warning tones-To set the phone to sound tones, for example,
when the battery is running out of power
Apr 15, 2011 | Nokia 1600 Cellular Phone
Where or how can you turn your ringer volume up or down
Hello Hank,
When you make call use the left and right square key for increasing or decreasing volume.
Apr 15, 2011 | Nokia 2600
Cannot get phone to ring only vibrate
To change the Nokia 6133 to ring, do the following-
Select Menu > Settings > Profiles > Select any one profile that is available in your mobile. (Ex. General)
1. Menu > Settings > Profiles > General > Personalise > Incoming call Alert > Ringing
2. Menu > Settings > Profiles > General > Personalise > Vibratibng Alert > Off
After this activate the profile(Ex. General)
Menu > Settings > Profiles > General > Activate
After this the phone will only ring and wont vibrate.
If you want both then change the vibrating alert to On.
Good Luck.
Jun 04, 2010 | Nokia 6133 Cellular Phone
The text message sound alerts on my Glyde phone arent working
Nokia phones call them "profiles" , a set of preset modes where you can have different volume levels and tones for different occasions i.e General, meeting, loud, silent etc. I was suggesting trying a different preset mode If available to see if it worked for you.
Jan 14, 2010 | Samsung Glyde SCH-u940 Cellular Phone
Nokia e50 wont notify me when i recieve a new text message
Hello there! thanks for using Fixya.com!
Try the following instructions, to personalize your Nokia E50!
Profiles
Warning: In the offline profile you cannot make or receive any calls, or use other features that require network
coverage. Calls still may be possible to the official emergency number programmed into your device. To make calls,
you must first activate the phone function by changing profiles. If the device has been locked, enter the lock code.
Select Menu > Tools > Profiles.
You can adjust and customize the ringing tones, alert tones, and other device tones for different events, environments, or caller
groups.
To customize a profile, scroll to the desired profile in the list, and select Options > Personalise.
Define the following settings:
Ringing tone — Select a ringing tone from the list, or select Tone downloads to open a bookmark folder containing a list of
bookmarks for downloading tones using the browser. To listen to the selected tone, select Play. If you have two alternate
phone lines in use, you can specify a ringing tone for each line.
Say caller's name — Activate the text-to-speech ringing tone feature. When someone from your contacts list calls you, the
device sounds a ringing tone that is a combination of the spoken name of the contact and the selected ringing tone.
Ringing type — Select how you want the ringing tone to alert.
Ringing volume — Select the volume level of the ringing tone.
Message alert tone — Select a tone for received text messages.
Or you may still go to this website for more info! http://nds1.nokia.com/phones/files/guides/nokia_E50
Feb 15, 2009 | Nokia E50
Mobile phone
u better go to the technician for repair the problem of that is the buzzer
Jun 09, 2008 | Nokia 6101 Cellular Phone
RAZR v3xx
go to settings and set a ring or vibrate alert do it by going in profiles and edit them
Nov 27, 2007 | Motorola Mobility RAZR V3xx Cellular Phone
Nokia N73.Incoming message alert gone..No tone,vibration,message envelope
Follow this steps in the given order -
1) Switch off your phone
2) Remove memory card
3) Switch on your phone
4) Ask a friend to send you a message. Now you will hear the tone
5) Switch off, insert the memory card & switch on again
6) Ask someone to send a message again. It will work
Nov 07, 2007 | Nokia N73 Cellular Phone
Nokia 6133 Cellular Phone Logo
140 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
