Question about Whirlpool GS460 Gas Kitchen Range
When I turn the oven on it preheats for about 5 mins then starts beeping. The display says "F2". I unplug it for 5 mins and replug it in. Then I hit "oven" and "start" and it works. What does F2 mean and can I fix it myself? Thanks.
  • 1,531 Answers
This is a shorted oven probe fault code. you will need to replace the oven temp sensor.
The part number should be 8273902 and it can cost about 76.00 dollars from a local parts store in your home town.
I hope this helps.
Happy New Year and thanks for choosing fixya.
Posted on Jan 02, 2011
Testimonial: "Thanks Seth. I'll try it. What a fast response. I've had this problem since I moved in 3 months ago."
Electric range flashing "F1"
EOC is the Electronic Oven Control. if you have major sparks I would call a service tech because there is an underlying cause that needs a trained eye to be sure it is safe for you to use.
Jan 30, 2012 | Frigidaire Ovens
F3 f4 gaas oven when preheated these numbers appear it beeps and shuts off
Hi, replace the oven temperature sensor if "F2," "F3" or "F4" is displayed. "F2" indicates the oven temperature is too hot and the oven temperature sensor is suspect. "F3" or "F4" indicates the oven temperature sensor or shorted or open.
Jan 22, 2011 | Magic Chef Ovens
After setting my oven to preheat (the oven ignites) around 5 mins. a beeping noise sounds and the oven displays F2. I can't find my owner's manual. Thank you for your help. Connie Acosta
This is likely the oven temperature sensor needs replacing (step 3) But if that checks good follow steps 1 and 2 .The videos will walk you thru performing the checks.
1. Look for welded relay contacts on bake or broil relays. If this happens, replace oven control (also called clock or ERC).
2. For SELF CLEAN models: check door lock operation.
3. Look for a high resistance connection or any other cause of high resistance in the oven temperature sensor circuit. Check sensor, sensor harness and sensor harness connection at sensor and oven control. Replace sensor if found defective.
Oct 07, 2010 | Whirlpool GS460 Gas Kitchen Range
F10 error on kenmore elite electric built in model 790.4907
Try unplugging the unit from the wall, wait 5 minutes and replug back in. I had same thing happen to me a few months ago. I had to leave my stove/oven unplugged for 24 hours to finally get it to reset itself. It is working fine now.
Aug 12, 2009 | Kitchen Ranges
Takes 20 minutes to preheat.
The unit seems to be working ok....usually the temp probe will reach temp in 5 minutes and it will beep....i sugg for cust to let sit for 15-20 mins for precise cooking.
Jun 11, 2009 | Kitchen Ranges
Kenmore Ultra bake self cleaning oven is showing code E0 - F2
My oven will not stay on, when started to preheat it will come on for a few seconds and they it will make a beeping noise and the codes E0 F2 will appear. The codes stay on even if the oven is off.
Jan 04, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
Kitchenaid YKGRT607HS6
F2:E0 is shorted keypad, and F2:E1 is no keypad connection, you need to replace the keypad.
You can find schematics and find replacements by entering model number here.
Dec 14, 2008 | KitchenAid KGRA806PSS Gas Kitchen Range
When we cook in the oven it says F2 every 10 mins.
This means that your oven temp sensor has failed. There is no way to fix the sensor. You have to replace. The f2 means that your oven has reached its heaeting limit and it shuts down for safety. Replace oven temp sensor and it wil fix it.
Nov 18, 2008 | Hotpoint RGB745 Gas Kitchen Range
Whirlpool GS460 Gas Kitchen Range Logo
308 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
