Question about Rain Bird Xerigation XCZ-075
Brinks 24 hr outdoor analog timer how it work
Brinks model 42-1050 manual?
Brinks timers and manuals: - Water Heater Timer
waterheatertimer.org/Brinks-timers-and-manuals.html
Brinks timers and manuals. ... Brinks 44-1020 manual · Brinks 42-1020 manual ·Brinks 42-1020 instructions ... 42-1050 yard stake · Invisa timer 52-9206 · Brinks ...
I need an instructions guide for Brinks timer 42-1050 - Fixya
www.fixya.com/.../t10900275-need_instructions_guide_brinks_timer_4...
Nov 28, 2011 - SOURCE: Brinks model 44-1050 digital outlet timer- I don't. I have an instruction for a Brinks 44-1030 which I believe programs the same.
Brinks-outdoor analog stake timer-42-1050 Timer will not ...
Dec 14, 2015 | Hardware & Accessories
How to set a outdoor heavy duty 24 hr. timer
1) Timer not identified.
Copy following link to identify same-similar timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
2) Add comment and include photo of timer, or describe timer in detail.
Dec 09, 2012 | Hardware & Accessories
How do you use a brinks mechanical timer 42-1020? I have figured out what all parts are just don't understand how to use the pins??
Brinks 42-1020 is analog timer with 48 segments (pins) located around edge of dial.
Each segment (pin) represents 15 minutes in 24 hour day.
Segments on this timer push down and outward.
Open following links for instruction illustrations:
http://waterheatertimer.org/pdf/Brinks-42-1020-manual.pdf
http://waterheatertimer.org/How-to-set-timers.html
Aug 19, 2011 | Hardware & Accessories
How do i get my timer to come on model 42-1050
Timer is not identified.
1) Add a comment with in-focus photo of timer on flickr, for possible help
2) Open following link to help identify same-similar timer:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Brinks
3) If this is a Brinks product, contact Hampton products for manual
4) Open following link for setting analog timer:
Add a comment for more help
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Jun 11, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I HAVE A 42-1014 TIMER I SET IT SAY 3PM AND HOUR LATER IT IS STILL ON 3PM IS THE TIME SUPOSE TO DO LIKE A CLOCK THIS IS THE SECVOND ONE I GOT FROM WALMART AND IT DOES SAME THING
If you have analog timer, the dial is supposed to rotate as time passes.
Check that circuit has power.
1) You posted under Intermatic T100 series outdoor timer.
Open following link to troubleshoot Intermatic.
http://waterheatertimer.org/How-to-troubleshoot-Intermatic-timer.html
2) My local Walmart does not sell Intermatic timers.
They sell Brinks timers.
Open following link for possible troubleshooting help for some types of Brinks timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html#troubleshoot
3) Add a comment with photo of timer that you posted on Flickr for possible identification and help.
4) Upvote the help.
May 12, 2011 | Intermatic & Indoor/Outdoor Rain Tight...
I have a brinks outdoor analg timer that did not come with instructnns 15 amp 42-1050 24 hour
There are 4 possible solutions:
1) Contact Brinks at Hamptonproducts.com
Then scan your instructions into pdf format and post manual on your website, and add a comment to this thread with link to your manual so others can download it for free.
2) Add a comment with photo of your product so I can match up with known products.
http://www.fixya.com/support/r6568559-post_photograph_fixya_questions_answers
3) Open following link to identify same-similar timer and download manual.
The same timer design is used across different brands.
Add a comment and say which timer matches your product
http://waterheatertimer.org/Woods-timers-and-manuals.html#59730
4) Open following manual and see if it is similar and workable
http://waterheatertimer.org/pdf/Tork-806-manual-and-programming.pdf
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
Apr 11, 2011 | Solar Intermatic Timer 6 Outlet Outdoor
BRINKS 42-1014 OUTDOOR ANALOG TIMER
I don't have an instruction manual but there's not much to know. Set the on/off times by depressing the white and grey tabs just above the hour notation for the times you want. If the tabs are up then the power is off. If they are pressed in then power's on. Plug it in, turn the dial to the current time and attach a device using less than 500 watts and you're good to go. There is a # to the helpdesk 800-562-5625_36.jpg
May 06, 2010 | Intermatic & Indoor/Outdoor Rain Tight...
Rain Bird Xerigation XCZ-075 Logo
303 people viewed this question
Top Rain Bird Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Rain Bird Hardware and Accessory Expert? Answer questions, earn points and help others
