Question about Breville CT75XL 4-Slice Toaster
Can you recommend a tool to help remove odd screws. Need to remove cover to fix lever. It currently will not catch.
  • 114 Answers
Most of these screws call for what is referred to as a "spanner" bit. You can find bit sets on eBay if you look under "Security Bit Set." Charges should be about $5-$6 with free shipping.
Posted on Dec 01, 2012
If the screws have a triangular hole in the head, they are the same kind that are used in McDonalds Happy Meal toys. You can get screwdrivers to fit on ebay or amazon. Search for Silverhill Triangle Head Screwdriver on amazon.
Posted on Jan 19, 2011
I have a Porter Cable biscuit jointer, model 527 and I'm an amateur woodworker, NOT a mechanic. I can't locate my owner's manual on this tool and have the smaller blade in the tool currently. ...
Model 557 is shipped with a 4" diameter blade installed. This blade is used
for all operations except for the "FF" biscuit. The "FF" biscuit requires that
the 2" blade (furnished with the tool), be installed as follows:
DISCONNECT TOOL FROM POWER SOURCE.
1. Loosen four blade cover retaining screws (A) Fig. 10, and remove blade
cover.
2. Depress and hold spindle lock button (B) Fig. 11, while rotating blade by
hand until spindle lock engages.
3. Continue to hold spindle lock button while using the 5/32" hex wrench
(furnished with tool), to remove blade retaining bolt and flange, (by
rotating counterclockwise).
4. Remove blade and store in a safe place for future use.
5. Place 2" diameter blade (furnished with tool), onto blade mounting
flange (orient with teeth facing in same direction as directional arrow
cast in housing, see Fig. 14).
6. Position blade retaining flange (flat side out), to spindle, insert blade bolt
and rotate clockwise until hand-tight.
7. Depress and hold spindle lock button (B) Fig. 11, while rotating blade by
8. Continue to hold spindle lock button while using the hex wrench
(furnished with tool), to tighten blade retaining bolt securely, (by rotating
clockwise).
9. Rotate the "quick set" depth adjusting turret (A) Fig. 12, to the "FF"
position.
10. Lift safety lever (A) Fig. 13, fully retract the plunge mechanism, and
reposition the safety lever as shown in Fig. 14. Slowly release pressure
on plunge mechanism.
11. Reposition blade cover plate to tool, and secure in place with the four
retaining screws (removed in step 1).
DO NOT OPERATE TOOL WITHOUT BLADE COVER INSTALLED
Sep 06, 2017 | Masonry Tools
Have to slam door to get oven to operate
Try a) Lubricate the latches. I sprayed wd-40, you probably can use vegetable oil. Both sides, latch and receptor. Just doing this may fix your problem. (I have to admit I did part b first before trying this so I am not sure, but after doing this, it made my part b fix work even better)
b) Failing this, I found opening it up (t-20 torx screw driver) and tying a wire in the top hole, through the bottom latch body and fastening to a bottom hole of the microwave frame to force the mechanism to stay in place. You want to pull it towards the oven cavity. This will keep it from bending out of alignment. I found that it is only the bottom latch that has to catch for the microwave to sense the door is closed.
Mar 30, 2011 | Panasonic NNSN797S Microwave Oven
Hello My name is Mohamed. I have a sharp microwave oven model R-316FSU, I am having trouble opening the door. The latch seems to stick. How can I fix it?
Door catches.
One of the latches may be damaged or misaligned and is not lifting the other latch clear of the housing. Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When the door levers are in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Mar 21, 2011 | Sharp R-316FS Microwave Oven
Knoica minolta 250W printer cartridge jamed lever and mechanism cam off I cannot move it now thw whole machine has jammed what can I do please?
OK... YOU HAVE TWO POSSIBILITIES... EITHER THE LEVER ON THE TOP COVER BROKE OR THE ONE ON THE PRINTER CARTRIDGE...
IF ITS THE ONE ON THE TOP COVER THEN YOU NEED TO REMOVE THE LEVER HANDLE COMPLETELY AND GET A PLYERS AND USE IT TO TURN THE METAL THE LEVER IS ATTACHED TO OR FIGURE OUT WHERE THE THE LEVER GETS THE MACHINE TO LATCH AND USE A FLAT HEAD SCREW DRIVER AND SLIP THE LATCH... THEN CONTACT KONICA MINOLTA AND PURCHASE A NEW LEVER...
IF ITS THE TONER LEVER THATS BROKEN... YOU ARE GOING TO HAVE TO GET A PLYERS... TAKE A FIRM GRIP ON THE TONER AND REMOVE THE TONER IN THE SAME WAY THAT YOU WOULD IF THE LATCH WAS THERE... IF ITS BEEN PUT IN ODD THEN IT MIGHT BE STUCK... YOU MIGHT NEED TO USE A FLATHEAD SCREWDRIVER ON THE ENDS TO HELP THE PROCESS ALONG...
USER MANUAL
Feb 12, 2011 | Konica Minolta magicolor 2500W Laser...
Microwave door will not close properly
Door catches.
Remove from any power source, remove the cover of the cabinet. Slacken off the clamp mechanism and ease the clamp over the guide to allow the door to open. When a new door lever is in place, the door may be easily adjusted by slackening off the screws that clamp the door catch/actuators in place whilst holding the door closed and then tightening the screws. The rear of the door may be adjusted by slackening the lower door hinge screws and adjusting as required.
I hope that helps.
Feb 03, 2011 | Microwave Ovens
Red light and blank screen, will it work again, can it be fixed?
Yes your phone can be fixed.
The problem probably could be from the power supply or from the panel.
If it is the power supply, then it most likely could be that it got exposed to a high current and the board got burnt.
To fix this, all you have to do is to replace the panel.
To replace the panel;
  1. Remove your back cover, battery, sim and memory card. Two screws need to be removed,
  2. Run something like a credit card under the camera surround. It's stuck down with double sided tape so will come away quite easily. You now have access to two more screws. Remove these screws.
  3. Run something like a credit card around the join of the front and back cover in order to release the front cover.
  4. The front cover will still be attached by a wire. The connector from the wire attaches a bit like a plug and socket and can be levered off with little force.
  5. Two more screws, need to be removed.
  6. Now lift the main body of the phone away from the back cover.
  7. Turn the main body of the phone over and you'll see a ribbon connector. This attaches like a plug and socket. Just lever it up, away from the phone, to unplug.
  8. Then you replace the panel of the phone,
  9. The LCD screen can now be lifted away from the phone.
  10. Reverse the whole procedure for reassembly.
take care
Jun 20, 2010 | RIM BlackBerry Bold 9000 Smartphone
Where are there free turn instructions available on how to replace a turn signal in a 1994 chevy silverado? I will pay $1 for this answer.
You posted in the fre section...no need for the dollar but I'll take a cold Corona and lime!
Here ya go....
Removal & Installataion
  1. Make sure the switch is in the OFF position.
  2. Remove the Steering Wheel as outlined in this section.
    1. Remove the instrument panel trim cover.
    2. Insert a screwdriver into the lockplate cover slot and pry out the cover. Remove the lockplate. A special tool is available to do this. The tool is an inverted U-shape, with a hole for the shaft. The shaft nut is used to force it down. Pry the wire snap ring out of the shaft groove. Discard the snap ring.
    3. Remove the tool and lift the lockplate off the shaft.
    4. Remove the turn signal lever screw and lever.
    5. Press the hazard button inward and unscrew it.
    6. Remove the switch retaining screws. Pull the switch connector out of the mast jacket and feed the switch connector through the column support bracket.
    7. Position the turn signal lever and shifter housing in the downward, or "low" position and pull downward on the lower end of the column using a pliers on the tab provided. Remove the wire protector.
    8. Remove the switch mounting screws. Remove the switch by pulling it straight up while guiding the wiring harness cover through the column.
  3. To install:
    1. Install the replacement switch by working the connector and cover down through the housing and under the bracket.
    2. Install the switch mounting screws and the connector on the mast jacket bracket. Install the column-to-dash trim plate.
    3. Install the flasher knob and the turn signal lever.
    4. With the turn signal lever in neutral and the flasher knob out, slide the thrust washer, upper bearing preload spring, and canceling cam into the shaft.
    5. Position the lockplate on the shaft and press it down until a new snap ring can be inserted in the shaft groove.
    6. Install the cover and the steering wheel.
Retaining ring removal
Pliers may be used to remove the turn signal wire protector
Removing the turn signal switch
Install the lockplate and the retaining ring using the tool illustrated (or its equivalent)
Jun 08, 2010 | Cars & Trucks
I need too replace my main sail need diagram
For an exploded diagram of your engine, go to www.babbittsonline.com/parts/viewbybrand/parts.aspx
Feb 02, 2010 | 2002 Honda CR 250 R
Viewfinder
you have the lens cap on.
Oct 07, 2008 | Pentax K1000 35mm SLR Camera
How do I remove cover from fridge temperature control panel?
lever off the thermostat knob and you will often find fixing screws behind. also, fixing screws are often hidden behind little blanking plugs which lever out to expose the screw head
Jul 21, 2008 | Refrigerators
Breville CT75XL 4-Slice Toaster Logo
498 people viewed this question
Top Breville Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Jerry Greenberg
Jerry Greenberg
bengsoon Neo
Are you a Breville Kitchen Appliances - Other Expert? Answer questions, earn points and help others
