Question about Garden
1990 cub cadet carb settings 1210 model brand new part.
  • 10865 Answers
SOURCE: cub cadet 7254 with a 25 hp kawasaki running rough when hot
your carb needs to be either rebuilt or replaced. it is crudded up with lacquer.
Posted on May 10, 2009
  • 323 Answers
SOURCE: install belt on cub cadet mower
First, make sure you have the model number and serial number (located under the seat) and then go to www.cubcadet.com to get a belt diagram so you know which way the belt snakes through the pulleys.
You will have to remove the two pulley covers on either side of the deck.
Fit the belt around the right side of the deck pulleys when you are on the left. There is an arm attached to the springed pulley on the left side. It will have a hole the size of a 3/8" driver/ratchet. Set the ratchet on unscrew (to the left) and push the arm in toward the center of the mower. You will see the pulley moving too, creating enough slack to slip the belt over the edge of the rim of the pulley with a little elbow grease. If it is too tight, get someone to push in with the ratchet while you slip it on. Once again, you are the grass cutter king!
Posted on Jul 25, 2009
  • 61 Answers
SOURCE: Cub Cadet 1641 PTO problems
bad switch.
Posted on Sep 06, 2009
Dolfoff
  • 148 Answers
SOURCE: CUB CADET ZERO TURN Z-FORCE 3-BLADE CONFIGURATION
Under each blade is one single nut holding each blade on. It is not left-hand thread and there is nothing special about it.
Standard thread - Standard hardware - Standard tools. (If memory serves, you need a 15/16" socket to remove these.)
There is no need to index or time the blades. They cannot hit together unless something is bent or damaged on your mower deck.
Hope this helps,
Dolf-
Posted on Oct 15, 2009
  • 13 Answers
SOURCE: I have a cub cadet rzt50 mower...Need to replace a tire
There is a thru bolt, and inside and outside bushing, and center sleeve. Remove those to remove the wheel. Obviously support the frame on a jack. Most tires can be removed using a slight soapy solution and 2 smooth screwdrivers. Replacement, use a soapy solution around the bead, and using only hand pressure put the tire back on. Use a cinch strap around the center of the tire to help keep the tire beads against the rim and air it back up.
Posted on Apr 16, 2010
Cub cadet manuals pdf
something clogging jet in carb water in gas rebuild carb
Sep 06, 2014 | Cub Cadet Garden
Troubleshooting
Carb needs to be rebuilt, new needle and seat also float fuel level is critical.
after uninstalling carb remove fuel bowl turn carb upside down to verify float is parralell (level) with carb body if not adjust tab on float so it is clean all small orfaceses and jets.
Aug 09, 2014 | Cub Cadet Garden
Cub cadet stops running
rebuild carb and make sure fuel pump is working while you have carb off
May 30, 2014 | Cub Cadet Garden
Adjust idle speed
on the top of the carburator there should be an adjustment to set the idle speed
Apr 25, 2013 | Cub Cadet Garden
Cadet does not fire
is it the 12 hp kohler? if so it is electronic type no points.
have you tried cleaning the flywheel magnet and coil?
use very fine sandpaper and clean them. if still no go gheck kill switch and nothing there is is probally a bad coil.
Jul 25, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Cutting grass.heard loud Pop tractor shut Cub Cadet 1210 Hydro
just trace the spark plug wire to the coil but you can check the spark by putting a new plug in the wire and make sure it is grounded and turn the engine over if you have spark then you have to pull the fly wheel off and check the fly wheel key
Jun 27, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Can I print out the maintenace manual for Cub Cadet Mower
I need the serial number so that I can locate the manual
Jun 16, 2009 | Garden
Transmission oil ? for cub cadet tractor
Hi, Cissy, Every Cub Cadet is different, and they keep their manuals to themselves. With your exact model and serial number, you can go to their website and view the manual for your model which should have the type of oil you need. Their website is www.cubcadet.com and go to service. If you have trouble, let me know, but I will need the model and serial. Good Luck, this should Fixya!
Mar 23, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
