Question about Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF
How do you increase water temp on Rheem 82v52-2 Water Heater?
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
the big knob, at the base of the water heater, turn to warm or Hot. if water is not hot after that, you have other issues, it will take a hour or two, for the new settings to take effect.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
Rheem hot water heater says set temp? no hot water
If it is a gas water heater you must set the temp on the gas valve. Press the two outside buttons until they flash. Now you can use the arrow button to set temp.
Jun 25, 2016 | Rheem Water Heaters
Ptg 74pvn 2 rtg 74pvp
copy following links for rheem/eco-sense error codes, manuals, required yearly maintenance, support number and resources.
http://waterheatertimer.org/Troubleshoot-Rheem-Tankless-water-heater.html
Probably bad PC board, or bad remote control
Gene
h
Nov 22, 2013 | Rheem EcoSense by 4.2 GPM Tankless Water...
The water tank suddenly increased water temp, both elements look fine. could it be a bad temp control?
Probably thermostat, just as you suspect.
Electric water heaters can be fixed by homeowner.
Replace both thermostats for 25$ and see of problem persists:
http://waterheatertimer.org/How-to-replace-thermostat-on-electric-water-heater.html
Nov 23, 2010 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
No hot water
contact rheem you probably have a circuit board problemb
Jul 24, 2010 | Rheem Tankless Hot Water Heater...
Rheem glas fury water heater rattling
Thermostat may be heating element hotter than normal causing a change in temperature causing the noise. You could try adjusting temp down a little on thermostat. It sounds like it's getting the water very hot and thermostat may not be working correctly.
May 21, 2010 | Rheem 81VP6S/430126 Water Heater
The max temp in the control is 120F. How can I
gas pressure may be increased but most boilers are designed to a limited output 24 28 30 etc
Oct 08, 2009 | Rheem EcoSense by 7.4 GPM Outdoor...
Power vent 50 gal tank flashing code 2-3
1. Turn off power vent blower and set water heater temp to vacation (lowest temp)
2. Turn on power vent blower
3. Turn the water heater temp from vacation (lowest temp) to hot (highest temp) four times.
4. Set the water heater temp to normal
Aug 21, 2009 | Rheem Water Heaters
Rheem 40 Gallon FVR NATGAS Low WATER HEATER 6YR 22V40SF Logo
156 people viewed this question
Top Rheem Water Heaters Experts
Lickzee
gizmonix
Level 1 Expert
Are you a Rheem Water Heater Expert? Answer questions, earn points and help others
