Question about GPX PDL705
Everything works fine but it is in black and white now. No color at all.
Only view in black and white on my ilo DVD R04
I was having the same problem. My DVDR04 was working fine. And after about four months of not using it I desired to use it. Turned it on and everything was in black in white. After searching on line and e-mailing Ilo which I never got an answer. I finally tried using an RCA video (Yellow) cable on the line out video jacks, replacing the line out S-Video jack/cable and it worked fine back in color right away.
May 11, 2009 | iLO DVDR04
Xbox 360 does not display any color on any game
definitely sounds like it is a problem with your vga cable. i would suggest trying a different one.
Mar 23, 2009 | Microsoft Xbox 360 Console
Negative screen image
Look in System Preferences for Universal Access, there is a Display option which says Black on White(the normal setting) and White on Black (the setting that has been enabled).
There is a keyboard short cut to change the setting, it involves pressing four keys - Apple, Option, ^ and 8.
Nov 29, 2008 | Apple iBook G3 Mac Notebook
Samsung series 5 500lcd tv just black & white colors.
thanks for rapid comm.resolved issue .stb is a old version ,does not support hdtv ,changed to a newer version,everything worked fine.once again thank u
Nov 29, 2008 | Samsung LCD PREVIEW MONITOR f/950 AND...
My xbox360 does not show any color
if this has only just happened and everything was fine before then try another av lead, or if you have a connection at the front of your tele to plug the red yellow and white av leads into try this instead of a scart connector
Oct 24, 2008 | Microsoft Xbox 360 Console
Inverted colors
be certain it is not the video card connect it to an external monitor and test,
and reseat the video connector from the panel to the card.
look for bent connectors too.
Mar 19, 2008 | Acer Aspire 5100 Notebook
Black and white picture on the JVC TH-505
If you hold the VFP button while a movie is on, you will get a small box on the corner that shows your color. My default color also turned black and white. I just moved over to a user1 color setting (push the right arrow on your remote), and it allows to the change the colors. You might be able to put the colors to come out through here. Hope this helps.
Jan 28, 2007 | JVC TH-M505 System
GPX PDL705 Logo
165 people viewed this question
Top GPX Televison & Video Experts
Bill T
Level 1 Expert
Jaime Hernandez
Are you a GPX Televison and Video Expert? Answer questions, earn points and help others
