Question about Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas
Error code 70 on 1004fa rinnai - Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas
Error code h
Error code 11 is ignition failure
Error code H is over heat
May 28, 2016 | Rinnai Heating & Cooling
My Rinnai 1004F giving me error code 99
This fusible link may be open. Try jumpering the two leads and see if the unit operates. If it does replace the fusible link. Do not operate the unit without the fusible link for an extended period. It is a safety device and is there for a reason. Hope this helps.
Jan 04, 2014 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 2532 error code 10
Error Code 10 Problem: Reduced or no air supply to the water heater or there is an obstruction in extracting the flue gases out.
Solution: Make sure that the recommended Rinnai venting is used, there is no obstruction in the venting system, no reduction in diameter and lengths are per instructions. Also make sure that nothing blocks the venting system or fan, and that dip switch and condensation collar are set properly.
Good luck,
Marty
Jan 20, 2013 | Rinnai Water Heaters
I have a Rinnai 516TR showing error code 62
Error Code 62, indicates a faulty fan motor. Which, according to your Owner's Manual, requires a service call by an authorized Rinnai service technician. it may not mean replacing the fan motor. It could also mean a faulty fan sensor.
Hope this helped you. Cheers.
Jul 08, 2011 | Rinnai Heating & Cooling
Rinnai Avenger 25 error 13!
thermocouple high cut out on convection fan rinnai fitters job , have to wait sorry , it is in the manual under fault codes .
Jul 06, 2010 | Heating & Cooling
Rinnai 1004 F Error Code 11
Code 11 is that the unit is trying to light but does not sense a flame after 5 seconds. Usually means you have run out of gas if you are bottled gas. Check your bottles are turned on if you are on LPG, you might need to change over manually. Have you anything else on gas?
Jul 01, 2010 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 556 ftr keeps flashing code 12
Hi
Thanks for using FixYa. Error code 12 on a rinnai 556ftr means Flame failure. Check gas is turned ON.
Also see this error manual.
Please refer to this user manual for more details --
Rinnai 556ftr User manual
Please do rate the solution & revert for further assistance.
Thanks
Rylee
Jul 29, 2009 | Rinnai EnergySaver 556 Air Conditioner
Rinnai 403 FT
who did you talk to at rennnai?
let me know i deal with them on a buisness leval.
Mar 27, 2008 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai 1004fa
page 35 of the following: http://www.rinnai.us/Rinnai.aspx/FileLibrary.aspx/DealerResources.aspx/DocumentsLibrary.aspx/WallFurnacesDirectVentMainHeatSource.aspx/RHFE1004FA.aspx/GeneralInformation.aspx/456RHFE1004FAManual32003.pdf.aspx hope this helps :)
Dec 24, 2006 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai RHFE-1004FA 38,400 BTU Energy Saver Ductless Heater - Natural Gas Logo
80 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
