Windows XP Will I lose everything on my puter when I do this upgrade ?? Guy Swanner
  • 4,472 Answers
There is a way to only do an upgrade, but I would recommend backing up whatever data you have/need and installing the fresh copy of windows. You may want to purchase a new computer for a few hundred dollars you could get a machine that wouldn't be outdated for years. Here is just one example this is a refurb, but you can get new ones in this price range as well.
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3901457&Sku=G153-GT5654
This is a very fast computer and would be compatible with everything for years. So for only a couple hundred more then what you would have to pay for windows. This also may be alot easier as installing a fresh copy of windows does not always run smoothly. Sometimes it is hard installing all the current drivers especially on older pc's where they may not even have Window's XPdrivers.
Hope this helps and let me know how it goes.
Thanks,
Lee
Posted on Jul 09, 2008
Need to remove XP compatability mode from Windows Pro 7 in order to ru. Install of upgrade to ACT.
Right click the install program for ACT, choose properties then compatibility mode tab and unselect "Run this program in XP compatibility mode", click OK. If that doesn't work, select that box and choose Windows 7 as the compatibility mode.
Oct 04, 2015 | Microsoft Windows 7 Professional for PC
How do I install Windows 8.1 on an 4TB internal HDD???
Thanks guy! It's helpful! And friends you can also get your windows 8.1 upgraded from https://www.facebook.com/Windows-XP-Key-1742549319367506 It's convenient and easy to finish the upgrade process with this site.
Feb 16, 2015 | Seagate HDD Computers & Internet
Converting from xp to windows 7
You can, but thorough backup of all your XP stuff is needed first, as you will lose much of it. Here is the detailed MS guide
http://windows.microsoft.com/en-AU/windows7/help/upgrading-from-windows-xp-to-windows-7#T1=tab01
Unless you have a genuine copy of W7 already, I'd recommend going to W8.1 , as it has now stabilised and will be supported for much longer than W7. However your hardware would need to be good enough. From XP there is no automated way to check this, instead
http://windows.microsoft.com/en-us/windows-8/system-requirements
Jul 22, 2013 | Microsoft Windows 7 Professional Upgrade...
How can i upgrade from Windows XP to WIndows 7?
Hey, just use Zinstall XP7. It can upgrade to Windows 7 and keep your programs and files and everything. No reason to stay on XP, I think - 7 is awesome
Mar 18, 2010 | Dell Inspiron 6400 Notebook
I need my 25 product key for windows xp to reinstall it on my puter or another puter I got it with my puter when i baught it. the envelope it was in is a blank white sleeve that doesn'r have any writing on...
Contact microsoft and explain the situation. You will be probably told you are a victim of software piracy etc etc.
Which, from the way you describe thw white CD envelope is very likely.
Hard though it sounds, you might need to buy a new licence.
Feb 11, 2010 | Microsoft Windows XP Home Edition
How do i install a new windowa xp profess. with out losing info and programs on old windows xp prog .New windowa xp pro is legit old one is not New = unopen windows xp pro. program that can be ''...
Just select the Upgradation option.. while installing the XP on your system.
by this Operating system will be upgraded without loosing any saved data.
Sushant
9873412111
Jun 13, 2009 | Computers & Internet
I turn on my puter it goes to the user login and then logs off
I've run into this problem too often lately. So far I haven't managed to find a decent fix for it :( I've ended up having to backup the computer's data, reinstall windows, and restore all the data.
From the times I've seen it you get to the login screen, click on your user, get the "Loading personal Settings", a quick flash of the desktop, then back to the login screen saying "saving personal settings". It would do this in both safe mode and normal mode, so I was never able to try turning off startup software or services.
Booting to the windows XP disc and running a check disc might help, but from my experience with the problem you will probably need to reinstall windows. Hopefully someone else has a better idea.
Best of luck :)
Apr 13, 2009 | Microsoft Windows XP Home Edition
Upgrading an Acer Aspire 2008 model to run windows Xp in one partition and Vista in another
http://apcmag.com/how_to_dualboot_vista_with_xp__stepbystep_guide_with_screenshots.htm
You'll probably find this website most useful. This website was designed for users who want to dualboot that already have XP on their machine. There is a link to a how-to for users who already have Vista installed and want XP also. Good luck and I hope this helps.
Apr 13, 2008 | Acer Aspire 3680 Laptop
Dazzle DPM-5000
have you tryed the maker of the product?? sometimes if a device is installed in a windows xp envirerment it wont reconize that device BUT willk show up in devices to be installed under the intall mnew devices. hey will be or have a question mark on them and simply install the software fior that device as I have in the past as windows will tell yan to not in stall asm it dosent reconize the hardware THats a BS thing windows has as everything I mean EVERYTHING that I have one mt puter was xp compatable even if the windows says it wasent It was.
Mar 23, 2006 | Zio Corporation Digital Photo Maker Video...
Computers & Internet Logo
David Payne
David Payne
