Lost manual, need to set temp. from C to F temperature
  • 2,133 Answers
Simple. Press < and > (or) - and + at a time for 5 seconds continuously.
Posted on Jan 02, 2011
I have a Skytech 3301 for a propane stove with some thermostat problems.
Great question! It sounds to me like the Skytech's swing temp setting may be out of whack.
Here is a quick link to the product page with a link to the owner's manual at the bottom if you need: Skytech 3301 Fireplace Remote.
Below is an excerpt on how to check and modify the swing temp settings for the Skytech 3301. (I apologize if the copy/paste formats poorly).
The Thermo Mode on the transmitter operates the appliance whenever the ROOM TEMPERATURE varies a
certain number of degrees from the SET TEMPERATURE. This variation is called the "SWING" or
TEMPERATURE DIFFERENTIAL. The normal operating cycle of an appliance may be 2-4 times per hour depending on how well the room or
home is insulated from the cold or drafts. A smaller "swing number" increases the number of cycles so the room temperature is more
constant. A larger "swing number" decreases the number of cycles, which saves energy, in most cases. The factory setting for the "swing
number" is 2. This represents a temperature variation of +/- 2
0
F (1
0
C) between SET temperature and ROOM temperature, which determines
when the fireplace will be activated. The "SWING" number values are:
1=+ 1
0
F (.5
0
C), 2= + 2
0
F (1
0
C) and 3 = + 3
0
F (1.6
0
C).
SETTING THE TEMPERATURE SWING (TEMPERATURE DIFFERENTIAL)
1. To change the temperature "SWING" setting (1-3), press the TIMER/TIME and DOWN buttons
simultaneously to display the current "SWING" setting in the SET TEMP frame. The letter "S" will
display in the ROOM TEMP frame on the LCD screen.
2. Press the UP or DOWN button to change the temperature differential or "SWING" (1-3). See above
for 1-3 "SWING" temperature valves.
3. To store the "swing number press the SET button or allow 15 seconds to lapse, and the new "swing
number' will be automatically programmed.
MANUAL CHECK OF " SWING" OR TEMPERATURE DIFFERENTIAL
The operation of the factory set "THERMO SWING" can be checked by adjusting the SET TEMP 2
0
F above or below the room temperature.
This will cause the system to turn ON or OFF. Normally the system will only respond to temperature changes every two minutes. Manually
changing the SET temperature will activate the system in less than 10 seconds. IF the "SWING" is changed, then a new room temperature
differential will respond. Factory setting of "SWING" temperature is 2
0
F.
Jan 17, 2013 | Skytech 3301 Thermostatic Gas Fireplace &...
We have a fairly new furnace. I have the temp set at 65 the furnace only runs for 3 min at a time and comes on every 5 min. This sounds extreme to me?
It depends on the differential that you have programmed into the thermostat. In most of them you can set the temperature you want the thermostat to activate, and then you set the run differential such as three degrees below 65. In other words, the thermostat will activate at 62, and drive the temperature up to 65, cut off and wait for the temperature to drop to 62, where it cuts on again. see:
http://yourhome.honeywell.com/home/Products/Thermostats/
Check http://homeappliance.manualsonline.com/manuals/mfg/honeywell/8000.html to see if you can find the manual if you have lost yours.
Dec 07, 2010 | Honeywell Heat/Cool Thermostat
Electric furnace won't shut off
It sounds like a bad or badly miswired T-stat
Jan 20, 2009 | Goodman CLQ36AR49 Air Conditioner
Incorrect temperature in oven
the computer needed replacement. i just purchased another range instead.
Mar 27, 2008 | Amana ACS3350AS Gas Kitchen Range
Westinghouse fridge
cooler means coooler cabinet temperature...
Feb 12, 2008 | Refrigerators
Three Temperature zones
Did you read the owners manual? It will be kind of hard to tell you because there are so many different settings for different areas.
Dec 26, 2007 | Danby DWC310BL Wine Cooler
Inacurate temp
The follow suggestions apply if you are at sea level, or a bit above. If you are in the mountains, you'll have to compensate for altitude issues. You need an accurate thermometer to be spot on. One way is to use an electronic thermometer. Another is to set the oven to 217 degrees, insert a small pan of water into the oven, with a metal tray or pie tin on a lower rack to catch spills and see if it eventually boils. If the water didn't boil, you can adjust the temperature upward in  5 degree steps (see your owner's manual for details). If you've lost your manual, you may be able to go on-line and get a pdf copy of your manual.If the water does boil, you know your oven is accurate within 5 degrees. You can then proceed to re-do the experiment at 212 degrees, if you wish. Then you may use the data to adjust the oven temperature.
Dec 03, 2007 | Maytag MGR6772 Gemini Gas Kitchen Range
Honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Sep 24, 2007 | Honeywell /KAZ HOME ENVIRONME HZ-705 7Fin...
Heating & Cooling Logo
18 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
