1994 Honda Accord Logo
Posted on Jan 02, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is this also for a v tech head - 1994 Honda Accord
Archaeology
Level 3:
President:
  • Master 662 Answers
  • Posted on Jan 02, 2011
Archaeology
Master
Level 3:
President:
Answers
662
Questions
8
Helped
496017
Points
2068
Jay - post this follow-up question in the "post a comment" section to your original question - essentially keeping everything together in one conversational thread. All I could do with
"is this also for a VTECH head?" is to ask for a clarification..
Why is my 2005 chevy avalanche loose coolant, FAST. I did pressurize the system, but didn't find any leaks. Found TSB from GM about cylinder heads cracking at oil passage issue, but oil is clean.
Coolant can and is lost without getting in the oil from a leaking head gasket or cracked head or block. In the years as a dealer tech most often oil was not in the coolant.
What do I need to convert a ls b18 to a lsv b18 with vtec head??
Sir,
I am providing you with a forum that has a variety of approaches for you to learn . Take a look. ls vtec question head gasket Honda Tech . Take a membership.
Honda Tuning shares a nice article also. LS VTEC Head Swap Tech Honda Tuning Magazine .
Finally. Here is an open-minded parts assembly that will prepare you for the possibility. How to Build reliable LSVTEC B20VTEC Honda Engine . Although, it is not your question. It is a good estimate. Take a peak. Keep Tuning. Fare. Well.
Engine smoking no power blowing air instead of sucking
I think you have a blown engine cylinder head gasket or gaskets and or a cracked cylinder head or heads. Any qualified auto tech can confirm this guess is the the problem. Do not attempt any repairs until a shop has looked into the problem.
2helpful
Need torque specs for bolts on head of my 2002 honda civic ex v-tech 1.7 engine. just fixed them about a week ago and have to fix them again
Hello claudian1535,
Below is an image showing the torque sequence. The torque procedure is a three step process:
Step one torque all head bolts to 14 ft.lbs.
Step two torque all head bolt to 36 ft.lbs.
Step three torque all head bolts 49 ft.lbs.
I hope this helps.
Regards,
netvan
1helpful
Trying to locate a "v tech valve" for 1995 honda
No the v tech valve is located in the head and is run off oil pressure.
2answers
Replacing head gasket
start in middle and work outwards left right left right with the bolts ,torque ??easy start with a rachet which will allow about 40lbs then a snap on knuckle bar till you can feel bolts stretch.as to type of head???is it 8 valve or 16??16 valve dearer to do
1helpful
White smoke problem
Hi white smoke is produced by water in the combustion chambers do to bad head gaskets ,crack heads ,or lose cilinder head bolts,you should take it to a good tech before will cause any mayor damage .....
Head gasket
You can do a search on Google for "240SX owner's forum" and some enthusiast forums will likely show up. They'll probably have illustrated tech procedures posted by members who have done it. It's a VERY involved job. You need to remove the entire timing assembly (timing belt, tensioner, etc) after you tear apart the front of the engine (and since you're taking it off, you should put on new timing parts, so plan for that), and after that's off, the top of the motor (spark wires, fuel rail, etc) has to come off, along with the valve cover, so you can remove the head. You'll need the new head gasket of course, and new head studs/bolts as well, plus a new valve cover gasket and possibly several other gaskets as well. You will also need to find the torque specs for each of those bolts, and the proper tighten/loosen/retighten procedure for the head bolts (which will likely be listed in a tech procedure on one of the forums).
That's it in a nutshell - it's not for the faint of heart by any means.
Top Honda Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Honda Expert? Answer questions, earn points and help others
