Question about Maytag Performa PAV2200
Maytag Performa loud gringding/clicking noise
The subject pretty much explains it. The noise became quieter after I got the water out, but it was still rather loud. Motor? Clutch? The belt seemed like it may be a little loose, but that wouldn't cause this would it? I cant afford a new washer right now so any help would be appreciated.
  • mlrescue Jul 26, 2008
    I can feel something grinding in the pump and it is real loud. It seems to be pumping the water ok. Can I continue to use it until the new pump comes? It's not leaking.
  • 639 Answers
Mlrescue,YES!
If its 10 years old or more don't put money into it!
The new ones are much more energy efficient!
Try these guys,they are good!
A&E Factory Service is nation wide!
1800-905-9505
They are open 7 days 24 hours to make appointments
Neil
Posted on Aug 24, 2008
We have a Maytag Performa PAV2200 Washing machine...lately, during the spin cycle it makes a loud whinning or scraping type of noise during the spin cycle and sometimes during the wash cycle.... we took...
Might be the tub bearing going out. Is she leaking any?
Here is a visual inspect and repair of the tub seal:themobilian_1841.jpgthemobilian_1842.jpgthemobilian_1843.jpgthemobilian_1844.jpg
I used a pipe wrench to unscrew this top portion of the seal (lefty loosey)themobilian_1845.jpgthemobilian_1846.jpgthemobilian_1847.jpgthemobilian_1848.jpgthemobilian_1849.jpgthemobilian_1850.jpgthemobilian_1851.jpgthemobilian_1852.jpg
Those 6 springs are pretty tough to get back on there without the special tool
other than that it all goes back pretty easy.
Service manual and more HERE
Mar 12, 2011 | Washing Machines
I have a Maytag Performa Washer, model number PAVT244AWW, that does not agitate. Everything else is working. It makes a loud noise during the wash and rinse cycles when the agitator is supposed to be...
My Maytag Performa makes a grinding sound when it agitates. When it starts to dump the water it makes a loud grinding on metal sound... really loud. What is the problem and how much to fix?
Sep 05, 2010 | Maytag Atlantis MAV6000 Top Load Washer
Loud Rubbing noise from my Maytag Performa Dryer
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer2_bing.gif Repair Squeaks, Grinding, Clicking and Knocking Noise
http://www.fixya.com/support/r4416566-dryer_repair_squeaks_grinding_clicking
heatman101
Jul 20, 2010 | Maytag Dryers
My Maytag Performa dryer makes a loud scratchy noise while drying. What is the noise and how do I fix it?
My Maytag Performa gas clothes dryer makes a scratching noise for the first few minutes when turned on, then it goes away.
Jun 01, 2010 | Maytag Performa PAV2200
Washer is making a loud noise when its trying to rinse
you will have to open up the panel to check where the smell comes from. It could be on the motor which may cause also a loud noise or from the electrical, loose connection or bad relay may cause a noise of a different kind.
Sep 21, 2009 | Maytag Performa PAV3200
Maytag performa washer grinding noise
Sounds like the water pump is going out on it. The part runs about $80 and should only take about 45 minutes to install.
Jun 25, 2009 | Maytag Performa PAV3200
Spin cycle not working, was making loud noises,water won't drain
i dont have a model number ..just tip unit prop it up try and spin unit with belt on with your hand ,,than take belt off and spin pump pully..by itself...onthejob
Jan 24, 2009 | Maytag Performa PAV2200
LOUD NOISE IN SPIN CYCLE
you have a bad tub seal asm. remove agitator, spin basket and tub asm. remove seal and install new one. good luck
Dec 15, 2008 | Maytag Performa PAV2200
Very loud squealing noise in spinn.
If your Maytag is a top loader equipped with a vertical transmission under the tub, the squealing may be coming from, either the brake assembly, or the snubber which the entire pedestal rides on.  Could you please post back comments and let me know if this is the type of washer you have?
Oct 18, 2007 | Maytag Performa PAV2200
Washing Machines Logo
100 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
