Question about Frigidaire Refrigerators
Frigidaire refrigator model FRT8G6FMB2 top mount freezer working fine but bottom refrigator is not cooling properly.
Sea Breeze
  • 4654 Answers
SOURCE: REFRIGERATOR BOTTOM IS NOT COLD.
OK that number is good, Frigidaire model GLRT13TEB3 Sometimes the freezer section appears to be cold enough but you may need to check it if we don't find the problem soon. If your freezer is not defrosting properly it will restrict air flow to the fresh food section and that make us think that's the only problem. Your refrigerator has a defrost timer located inside the fresh food section behind the thermostat control cover. Unplug the refrigerator and open back of the freezer compartment to expose the evaporator coil. If covered with ice or frost this will be considered to be something wrong with defrost circuit. First we check timer, then element and then the defrost thermistat. Let me know what you find after you expose the evaoprator. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Apr 22, 2009
Sea Breeze
  • 4654 Answers
SOURCE: Frigidaire model FRT16CRH. Top freezer not getting
Your refrigerator has a defrost timer and it may not be going into defrost every 8 to 10 hours. I was not able to get a picture for you of the location, but look inside the fresh food compartment and inside the teperature control panel should have a hole with sometimes a plastic plug stuck in it. If not there it will be under the kick plate at bottom of fridge. Take a flat head screwdriver and slowly turn to the right until refrigerator stops running. After about 30 minutes if it does not restart, star by again turning slowly clockwise until it starts. Let me know what you find, Thanks, Sea Breeze
Posted on May 18, 2009
VtToolMan
  • 704 Answers
SOURCE: Refrigator not cooling properly, freezer works fine
I'll assume you don't have much food/items in the freezer section. Because you have the fridge set on the max cooling setting and the freezer set higher than the mid setting, it could be that you have frozen the cold air passage from the freezer to the fridge.
If you can, 1) remove all contents that would spoil; 2) turn off the fridge 3) open both doors and allow the fridge to manually thaw out completely (this will speed up the opening of the cold air exchange passage between the freezer and fridge, which is likely blocked and frozen solid. Have plenty of towels handy to soak up the water from the defrosting process,
After a FULL day of being left off and doors open to thaw out, check for any further thawing and dripping water inside, if present wait another 8 hours (you really want to get it thawed out the first time!) When that's done, reset BOTH temperature controls to the factory mid-point setting (5?) as marked on your control knobs.
The key to having a refridgerator run properly is to allow for it to run at the factory settings for at least 24 hours BEFORE you adjust the controls higher and/or lower for each section. Adjust it up or down in ONLY 1 setting increments so as to not cause ice build-up and freezing of the internal air exchange passages.
Also, as you've relegated this fridge as a garage "beer & backup" unit, make sure to keep the freezer as full as possible to make it run as efficiently as possible. You can freeze jugs of water and pack it with cheap thrift store bread to help it run correctly. An empty freezer has to work harder to keep just air at freezing temps. As such, it will pass much colder air into the fridge, and cause these types of freeze ups. By the way, turning up the temp controls only makes it worse and just results in a total "freeze up" inside the cabinet panels that you can't easily see or get at to rectify, hence the reason to shut it off and let it fully defrost.
When you're done, you should have your fridge back in action working like it should, but remember, don't rush temperature adjustments, even thou we all want those frosty beverages, it'll take a couple of days to achieve the desired "chill" you're likely used to getting when it was your primary fridge.
Hope this helps and Best Regards! Semper Fi!
Posted on Aug 03, 2009
SOURCE: fridge not working properly on kenmore bottom freezer model 596.7
I have a similar problem, although I have no cooling in the fridge section. Had a repair man indicate that the electrical panal(pcb board) needs to be replaced. It is on order ($200). Sure hope that is the issue. To me, it appeared that the freezer fan(which cools the fridge) was not working. Whether that is the result of a faulty electrical panal is yet to be determined. Good luck!
Posted on Aug 13, 2009
Sea Breeze
  • 4654 Answers
SOURCE: refrig & freezer not cooling properly
I believe the start relay and start capacitor with the overload will need replaced. That is easy and should solve your problem, Sea Breeze
Posted on Aug 26, 2009
I have a Whirlpool Refrig. model GX5FHDXVY04. The freezer is working properly but the refrigerator is not cooling. I noticed frost on the inside back panel of the freezer. I turned the temp down in the...
Many of frost-free fridges use fans to move a controlled amount of air into the upper or side cooling chamber, check for non-working fan or a stuck or malfunctioning damper control. Keith L.
Mar 02, 2012 | Whirlpool 24.8 Cu. Ft. Side-by-Side...
Freezer seems to be working fine. refrigator does not seem to be cold enough
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Oct 01, 2010 | Frigidaire FRT17G4B Top Freezer...
Refrig compartment does not cool on my new Kemore Frig.
Check and make sure the fan in the freezer is running. if not possible bad fan. If fan is running, check to see if you have any ice built up on back freezer wall. Normally frost type ice. If so, you may possibly have a bad defrost bi-metal mounted in the freezer section. Next could be a defrost timer control. Model number usally will help more in getting it right.
Feb 28, 2010 | Kenmore Refrigerators
Warm refrigerator compartment
We had similar problem. Found the interior lights of refrig. were not turning off. Found out this was a recall problem and was fixed by sears for free.
Jun 21, 2009 | Kenmore 73503 Stainless Steel Bottom...
Amana Refrigerator
Is fan in freezer running? If not it is bad and needs replacing. Please leave feedback.
Nov 27, 2008 | Amana Easy Reach AFD2535DE Bottom Freezer...
FREEZER NOT FREEZING
I will be more than happy to help.  Read this first on Frigidaire Refrigerators.   Then if you have anymore questions about this ask me on Frigidaire Tech Support.
Thanks, Bill
Jun 30, 2008 | Frigidaire FRS26H5AS Side by Side...
Kitchenaid ksrj25cnst refrig does not cool but freezer is fine
sounds like you have a defrosting iss\ue here, ther is aduct on the left sideof refig wall perhaps 3/4 the way down usually behind one of the crispers its frozen over with ice not allpwing fresh food air to properly circulate, l;ook to the bottom of your freezer on the back wall is there ice on the panel?? if so your not deforsting properly there satech sheet underthe kickplate showing basic wiring and trouble shoooting guide as well
Apr 06, 2008 | KitchenAid KSRD22FKBT / KSRD22FKWH /...
Frigidaire stand alone Refrigerator won't cool Fans and Compressor work
when you removed the back panel inside refrig was there any sign of cooling, perhaps only top 1 pass of the coil was frosted, or completly warm no signd of frost at all?
Feb 17, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Refrigerators Logo
46 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
