Question about Karcher Garden
Water leaking from spray gun - Karcher Garden
  • 34 Answers
It depends on were the water is leaking from on the gun. If the water is leaking from were the high pressure hose goes into the gun it could be that on oring as been damaged. If the water is coming from the trigger you may need a new trigger gun.
If you tell me your model number (1.xxx-xxx.0) i can tell you the part number that you will need to give to your Karcher dealer/supplier to replace it.
Posted on Jan 18, 2011
  • John White
    John White Apr 06, 2015
    A video discusses this problem and points to a blog that contains a solution:https://youtu.be/_amfg3qV4rs
3 Suggested Answers
freetek
  • 5568 Answers
SOURCE: Our neighbor just made the mistake of running hot
The seals in the pump may have failed from the hot water; they shouldn't but stuff coming from China is often not as it should be. Your unit may have been assembled elsewhere but I would bet the innards are of Chinese origins.
Posted on Aug 23, 2009
  • 497 Answers
SOURCE: durabuilt pressure washer 1600psi. Water leaking
Sounds like a faulty seal around the gun. Repair might be few bucks if you take it in. But the price of the part is probably under a buck. Depends if you want to rip apart it yourself.
Posted on Aug 12, 2009
Campbell Hausfeld HD4200 spray gun. Will not spray plain water. no siphon effect at feeder tube. What to check?
Check for air leaks above the top of the feeder tube. If it leaks air there, then no suction. Bad gaskets often cause this.
Oct 28, 2016 | Campbell Hausfeld Air Tools & Compressors
Rolson spray gun 70809 not spraying
the paint may be to thick for the gun. or it could be clogged. try spaying plain water through it if it sprays you have your paint to thick
Jul 14, 2012 | Air Tools & Compressors
I have binks model 21 automatic guns on my striper i installed rebuid kits when testing with water the guns drip water from liquid nozzle but not from needle it seats properly is this normal and will not...
If it is leaking fluid from the holes in the nozzle then the tip is not making good contact with the seat, the seat of the nozzle could also be dinged, or the tip / gun gasket might be bad. If the water is coming from the needle / nozzle seat, the needle or inside seating area of the nozzle could be nicked.
Nov 25, 2009 | Binks Air Tools & Compressors
GX 08 spray gun problem
drain your system of pressure. remove your air cap and nozzle from the gun. slowly increase fluid pressure till it comes out of gun. this will clean out debri from gun. reduce pressure so you don't wast anymore fluid.
clean nozzle properly / completely
clean aircap. properly / completely
inspect needle tip for abnormal wear.
if cleaned properly you will find your gun works much better.
Oct 17, 2009 | Wagner GX08 Airless Spray Gun
Durabuilt pressure washer 1600psi. Water leaking
Aug 12, 2009 | Coleman Powermate DuraBuilt 1400 PSI...
2400 -- no water pressure? --there are no leaks -
You probably need to replace the high pressure seals, the check valvesw, or the unloader valve.
Jun 25, 2009 | Garden
Spray gun leak
go to iwata site they will help
Apr 27, 2009 | Dmm Iwata LPH400 LVB Gravity Fed Spray...
Spray is very fine or not spraying
Any air leaks in the suction portion of the machine will cause it not to spray or spray weak. This is a airless paint spray correct? Your paint should be at least thin down using 1 gallon of water for a 5 gallons of paint. I find Baer paint is even thicker and had to slowly add more water.
To check if it is your paint. Fill a bucket of just water and see if it will spray your water. Of course after it gets a good prime. Let it recirculate until the water is coming out of the bypass as a solid stream. If it does not spray water then you have either a air leak or your pump packing needs replacement.
Let me know the results and the make and model of the machine.
Mar 20, 2009 | Binks Air Tools & Compressors
Spray gun for water and air
You can buy them here for about $22 US.:
http://www.detailyourcar.com/airwater-guns-and-hose-c-51.html
They're used for detailing cars, if you don't like these, Google "air water guns"
Jan 19, 2009 | Air Tools & Compressors
Garden Logo
1,184 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
