Question about Denon AVR-3801 Receiver
Getting error ether img downloadfail AE when i try to update the firmware of my Denon AVR-3311
  • 151 Answers
SOURCE: Denon AVR-3802 Problem
Check that your speaker cables are not touching each other at the amp end and also at the speakers as this will cause the amp to shut down.
hope this helps.
CABLE GUY.
Posted on Jul 12, 2008
petraman7
  • 1175 Answers
SOURCE: Manul denon avr-1601 en castellano
http://www.usa.denon.com/ArchivedAVReceivers.asp?archivedModelSearch=true&clearCurrent=true&archivedCategory=AV&archivedModel=AVR-1601&imageField.x=15&imageField.y=13
Espagnol as well ...I think
Posted on Feb 16, 2009
  • 119 Answers
SOURCE: Remote control for Denon AVR 1706
YES YOU CAN THERE MAYBE A FEW DIFFERENCE BUT YOU WILL BE FINE TO USE IT
Posted on Mar 02, 2009
taran_2005
  • 10515 Answers
SOURCE: protection error in denon avr-3000
Do you know what caused the protection shut down in the first place? Did you short your speaker wires even briefly?
You could try to Unplug the Unit for Few Minutes, say 30 minutes and then turn it back ON.Usually that would fix the issue.
If you are going into protect mode with no speaker attached,chances are that your output Ic is in need of replacement .This is the most likely cause of a protection error that you are experiencing.I am having a bit of difficulty in locating specific part numbers but feel confident that replacing outputs will remedy your concern.For further info and parts or authorized service locations in your area I suggest to contact mfg at www.usa.denon.com/ .Click on support or call(201)762-6500.I believe that they have a flat rate service and will give you an estimate.
Still, on the remote possibility that it is just a glitch caused by momentary power interruption or fluctuation, try to re-initialize the microprocessor, a hard reset (not unless this is what you were referring to as rebooted). The reset should force the AVR-3300 to revert back to factory defaults removing glitches, errors in settings & configurations, memory & presets as well as user preferences.
* turn OFF the unit using the POWER button;
* press and hold both SPEAKER A and SPEAKER B;
* without releasing the 2 buttons, press the POWER button;
* release the 2 buttons only when the display starts to flash;
* in the event of no display flashing, repeat the process.
Should the above be not corrective, then it would be a hardware fault and not just a glitch.
Let me know, if needed further assistance.
Hoe i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jan 13, 2010
  • 3741 Answers
its the main amp in your unit. Depending on the construction the main amp can be an IC (Integrated Circuit) or discrete components. Anyway, the protective relay protects your speakers from being destroyed. When a main amp breaks down it normally outputs DC voltage. DC voltage is not good at all for a speaker.
You need to replace all the defective components in your unit before the unit will be up running again.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
I have a Denon AVR s900 I am trying to update the firmware but it keeps failing. The update repeats and now the unit is not usable. How do I stop this?
Try pressing and holding the "tuner preset ch +" and "tune - " buttons and pressing power. The entire display should light up and blink. This should stop the firmware retry loop.
Dec 27, 2016 | Denon Audio Players & Recorders
HOW TO UPDATE THE FIRMWARE
There may not be any facility to update the firmware for this model without taking to the service center. This model does not have any device input like SD card or internet connection that would enable download of firmware upgrade. The later Denon models have this capability.
You will have to consult the local Denon service center for advise.
Mar 16, 2015 | Denon AVR-1905 Receiver
I have a denon avr-400 receiver. When running a firmware update, i got the error message: Connection fail:03. Now, my receiver is not working. stuck in this endless cycle of failure messages. Help
Unfortunately a failed firmware update will result in an inoperative unit. The solution is to update the firmware directly to the chip. Not a DIY solution. A local Denon repair center will be equipped to do that for a nominal fee. Your unit is a bit older to get much help from the main company.
If you are handy you need a chip burner and the proper setup and then force the firmware onto the chip. Lot of computer guys may have that around to help.
Good luck
Jan 16, 2015 | Denon Avr-5800 Receiver Ad, 4 Pg, 2000,...
Denon avr-2113ci hdmi can't change source
Can you update the firmware on the amp as this could also affect the connection between the players.
Jan 15, 2013 | Denon AVR-2113CI
Denon AVR-1912 firmware upgrade failed
I'm having the same problem, Denon has taken down the firmware upgrade for yours ( and mine) AVR-1912. My receiver is also stuck in the update fail loop. Supposedly they will have it back up, but I don't know the timeframe.
Lots of others are having the problem with the firmware upgrade. Go to
http://www.avsforum.com/t/1334369/the-official-denon-avr-xx12-model-owners-thread/16380
and that should help you out, though I can't say how much. I've gone as far as resetting the microprocessor, but it keeps trying to update, and then fails...
Dec 12, 2012 | Denon AVR-1912 3D Ready A/V Receiver - 90...
My AVR 391 goes on Standby and freezes there.
Seems you cannot fix this issue yourself. If the unit is still under warranty, Denon will replace a chip which has a flawed firmware. The unit cannot be updated remotely and a physical repair is necessary.
Sep 18, 2010 | Denon AVR-3200 Receiver
Denon AVR-3806 keeps losing video signal. The audio signal is still good. What could be the problem?
If your using HDMI, pull it from the receiver and run directly to the TV, then run optical or digital coaxial to your receiver. It's referred to in the industry as a "Handshake" issue. It has to do with firmware and hardware of your receiver and continuous ridiculous updates from the recording industry to protect copyright. Hope this helps. If you still have issues, post a comment and I will help you troubleshoot further.
Sep 20, 2009 | Denon AVR-3806 Receiver
No video on Denon avr 688
After days of frustration the real problem was with the cable box. It needed a firmware update. Following forum advice I disconnected the cable box power cord for a few minutes, reconnected it, allowed the cable box to reinitialize. Turned off receiver and TV. Turned TV back on and set it to HDMI connection, turned on receiver and all worked fine. Great picture and sound.( Needed to buy an optical cable to go from the cable box to the receiver to get sound from the speaker system. )--the dirtybird
Apr 14, 2009 | Denon AVR-3300 Receiver
Updates
mr rusty
you might try here for more info on the demon updates there you find the req links ,
Denon 3808/4308/5308 Firmware Tracking Thread - AVS Forum
hope this some help to you.
riz.
Aug 07, 2008 | Denon AVR 3808Ci Receiver
Denon AVR-3801 Receiver Logo
374 people viewed this question
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
