Question about Kenmore Washing Machines
High speed does not work - Kenmore Washing Machines
    Sergeant:
    Champion:
  • 342 Answers
Is this a new washer or an old washing machine if it is an older machine then you open the control panel and see if the wires from the high speed are all connected if they are then it may be the motor needs to be replaced if it is a new washing machine then a control board may be the issue
Posted on Jan 02, 2011
I'm wondering if it's the switch and not the resistors because the blower works on 1,2 and 3 mode but not 4 which is high.
On some cars the high speed of the blower goes thru the ignition switch of car. If something wrong with switch, unit will work at lower speeds but be dead on high speed!!!!!!!!
And there could be a problem with the switch since the high speed has no resistors connected in series to reduce speed - motor runs wide open.
Jul 17, 2015 | Mazda 2002 626 LX V6
ON a 2006 HHR LT is there separate fuses for the three fan speeds. The high fan speed is working but th low and medium speeds are not. Where are the fuses located
the fan speeds work through a blower motor resistor and not separate fuses for each speed. when these resistors go bad they are designed to work on high speed only.
Oct 11, 2014 | 2006 Chevrolet HHR LT
High speed
high speed relay or bad fan motor.
May 26, 2014 | Coleman Mach III Air Conditioner
1994 jucuzzi high speed jets dont work ?
If the motor is not going to high speed then you have one of two things happening...
The relay for the high speed is not working right or the high speed is burnt out on the motor...
Check the high speed connections in the motor for power... if you have power it is the motor... if no power there then the control is bad...
heatman101
Sep 26, 2011 | Jacuzzi Allusion Whirlpool 7242 w/2 Speed...
High speed does not work but low speed does. Is there an easy fix, or will this require a motor replacement to get both speeds working again? The cooler is a Mastercool model MC64C
If your motor only works on low speed and not on high speed first check to see if you have the proper voltage to high speed. Check with a voltmeter or multimeter, check from common on the motor to high speed on the motor at the switch. If you have the proper voltage then you have an open winding on high speed and the motor needs replaced. If you don’t have the proper voltage or any volts, then the switch is bad and needs replaced. This also will be the same if, medium speed won’t work and low speed does.
May 29, 2010 | Mastercool 67680 Evaporative Cooler Air...
High speed setting of fan does not work
May 29, 2010 | Kenmore 72115 Air Conditioner
Kenmore mod. #417.44092500 high speed spin doesn't
replace speed control board located right rear base of unit
Sep 12, 2009 | Kenmore Washing Machines
High cool not working
Compressors on these units runs at only one speed. The change to high cool is only a change in blower speed moving air faster over the cooling coil. I would have the running capacitor for the fan motor checked. A bad capacitor can cause your type of problem. The other problem could be that the high speed winding in the fan motor is bad. Try it operation in the fan only position through the two speeds. If it works in the low and high speed for fan only your problem could be in the selector switch.
Jun 23, 2008 | Dometic Rooftop RV Air Conditioner
Hampton Bay 54 In. 5-Blade with remote control at wall.
1. Set the remote to run the fan on high.
2. Pull the fan speed chain until the fan reaches high speed.
3. All speeds should work normally now.
The remote is modulating the maximum speed as set by the pull chain.
Dec 29, 2007 | Hampton Bay 54 In. 5-Blade Fan, Chestnut,...
Washing Machines Logo
12 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
