Question about Ovens
I have a Maytag Gas - Double Oven Range - Precision Touch 850 Series Range - Model # MGR6875ADB I posted a question on December 30 in the evening and I haven't seen an answer yet but when I go back I can't find my question listed on this site. I'd rather not have to type it again.
  • 3 more comments
  • Sally Jo Pyle Jan 02, 2011
    I'd like to try ordering just one part to save money. Which one would you recommend trying first? What do you think of that idea?
    nothing happens but an immediate beep when i do the cancel and keep warm buttons simultaneously.
    i wonder if this is an indicator that it is indeed just the keypad that is the problem...please advise...
    Sears was willing to sell the components separately.
    so can i leave this conversation open until after we've received and installed the new pad?
    sure is nice to have you out there helping us!
  • Sally Jo Pyle Jan 11, 2011
    Actually I asked that this stay open until after installation - why did you close it?
    oh - sorry. sears sent the wrong part so we won't have it for about 5 more business days.
  • Ovens Master
  • 5,370 Answers
Yes you can keep updated.After you replace the part.And let us know about the results. " the touch panel has completely gone unresponsive" as per this it indicates faulty touch key pad control panel board.This board has to be checked and replaced.--------Helpmech.
Posted on Jan 03, 2011
  • Ovens Master
  • 19,396 Answers
Hi.
Here your old request.
I think that the answer has ended under the long cue of post Christmas help requests sent to Fixya. Apologies.
About the problem. First trip the circuit breaker or disconnect oven power cord for two minutes. This will reset the appliance.
If that does not work, then the control module is probably faulty.
The control module and switch board it is sold in one unique assembly. The part minimum price I found is $268. Here the part: control/switch assemb (controlsw).
Installation is very simple. Here a testimonial: Installation Instructions
The kit is represented as part nr.2 in the diagram below. Click on the picture to enlarge:
Here all parts for this oven: MGR6875ADB
Note: if the repairman really offers to replace the control assembly for $300 ($30 labor inc. taxes!), then I would let him do the job. A technician can better test the part and will take the respnsibility of the replacement. I think that the repair price will be no less than $350, and that the quote of $300 was given by the tech without checking the updated part price.
Good luck with the repair and Happy New Year.
Ginko.
Posted on Jan 02, 2011
  • 3 more comments
  • Ginko
    Ginko Jan 02, 2011
    Hi.
    From your description it looks like the problem can be the button pad rather than the controm module. As said the two parts (control and switches) are sold in an unique assembly, then you replace them at the same time. Before replacing the part tell husband to check connectors to control module and switchpad. If he knows how to use a multimeter, the switchboard can also be tested looking for a jammed switch.
    IMPORTANT:
    Before ordering parts also ensure that problem is not just a jammed electronic in need of reset. Here the procedure:
    Return To Factory DefaultSettings
    The control can be reset to the factory default settings.
    To return to the default settings:
    1. Press and hold upper oven Keep Warm and CANCEL pads
    for three seconds. A single beep will sound and "dEF" (default) will appear in the display.
    2. Press the More+ pad to choose the factory settings. "cLr" (clear) will appear in the display.
    3. Wait four seconds and the factory settings will be accepted.
    4. If the More+ or Less- pad is not pressed within 30 seconds, the control will return to the existing settings.
    Before performing any maintenance or disassembly disconnect power from appliance.
    All the best.
    Ginko.
  • Ginko
    Ginko Jan 02, 2011
    Hi.
    RE:nothing happens but an immediate beep when i do the cancel and keep warm buttons simultaneously.
    After the Beep you should get Clr on display, and then you should be able to use more pad to select the reset. Not getting Clr on display can be given by both faulty timer and faulty pad. Only way to test control pad is by using a multimeter set on Ohms on contacts to control module to check if switches are opening and closing
    RE: Sears was willing to sell the components separately.
    In that case the pad is also usually cheaper and you replace the switch pad first. The fact that the clock is working suggests also that the electronic control board is OK. This is however no definitive test.
  • Ginko
    Ginko Jan 11, 2011
    Problem closed.
  • Ginko
    Ginko Jan 11, 2011
    Hi.
    It is not me, I am not even 100% sure it closed. Problems auto-close in seven days with no replies. I did not expect such a long time with no replies. You can still ask questions on this thread, but I can only post short comments. I do not know if the other expert can post full comments. I was doing a test and posted that sentence.
  • Ginko
    Ginko Jan 11, 2011
    Hi.
    Ok, I understand. You can still post comments. It is not me deciding how the solution is closed. I was just testing because I could not find the button to post, and I found out that the solution was closed.
    I will still answer if I get notification of further messages from this discussion.
    If you have any query about Fixya system (eg. closing opening solutions etc.), you can write to premium.support@fixya.com they answer within next working day.
    Regards.
    Ginko.
This touch 850 series double oven is only heating up to 170 when dial is on 350 do I have a bad element?
Elements usually either work or they don't, if it comes on the but does not give enough heat the thermostat is bad. If it was cleaned inside recently, check the routing of the stat lead perhaps its kinked etc.
Mar 16, 2015 | Maytag Ovens
Maytag gas oven has an F1 code. Model # CGR3740ADW.
The F1 code on a Maytag electric stove means the electronic range control, clock or touch pad is defective. You or a technician can do a test to determine which item is broken, but you must replace the electronic clock range in models where the touch pad and range control are one part.
Feb 01, 2011 | Maytag 24" Built-In Single Gas Wall Oven -...
My oven when turned on goes to F1 and the heat is like broil...only the top burner comes on????
Hello,Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacement of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
KENMORE Range/Stove/Oven Fault Codes – 362 Series (General Electric)
F1 = Stuck Touch Pad Key - Replace Electronic Range Control (ERC).
KENMORE - 911 Series (General Electric/Roper)
F0-F1-FF = Failed transistor in Electronic Range Control (ERC).
KENMORE Range/Stove/Oven Fault Codes- 665 Series (Whirlpool)
F1-E0 EPROM Error - Electronic Range Control (ERC).
F1-E1 EPROM Error - Electronic Range Control (ERC).
F1-E2 U/L ERC Errors - Electronic Range Control (ERC).
F1-E3 Fuel Type Fail
Kill power 30 seconds-Cancel-Start/Enter-5 seconds-Should see “E” for electric-
“9” for gas-If code changes again-replace Electronic Range Control (ERC).
KENMORE - 790 Series Electronic Oven Control (Frigidaire)
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal check sum error.
Runaway Temp = Replace Electronic Oven Control (EOC).
Kill power 30 seconds - if error returns - replace Electronic Oven Control (EOC).
Thanks
May 28, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
I have an in the maytag gas oven that keeps beep and show f-1 when its shut off
This simple test will help determine whether the ERC (Electronic Range/oven Control or Clock) or the touch pad is defective when this error code is present.
1. Disconnect power to the range/oven (unplug the range/oven power cord or turn the power off to the range/oven at the circuit breaker). It is very important that the power to the range/oven has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC/EOC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the code comes back (usually accompanied by a beeping sound).
7. If the code comes back and the beeping as well, replace the ERC(control board). If it does not, replace the touch pad.
Nov 02, 2009 | Maytag 24" Built-In Single Gas Wall Oven -...
I have a Maytag Gase Double Oven Range Precision Touch 750 Series and having a problem with temperature control for lower over how can I fix. Jim
Hello Jim,
Can you clarify the problem you're having, or how the temperature control issue manifest's itself, i.e. can't set temp in display, too hot, too cool, won't ignite etc.
Just some clarity to move you further, hope I can assist further.
thank you
Oct 27, 2009 | Ovens
How to unlock the frigidaire oven range door and remove error F3?
How do you adjust the oven door on a Fridgedaire Gallery Series gas stove?
Jul 13, 2009 | Frigidaire 30 in. Electric Gallery Series...
My kenmore oven is beeping and will not stop. the display shows F-1.
Please use the chart to determine which stove you have. You will have to look at the model number. The first 3 numbers will be the series on the chart. In most cases an F1 error would require replacment of the electronic control. This part is commonly refered to as an EOC or ERC. However this type of repair is usually reserved for repair specialists.
F1 = Shorted Touch Pad = Electronic Range Control (EOC) Internal checksum error.
Dec 16, 2008 | Ovens
My kenmore electronic stove is having a beep with code F1 on the
Dec 15, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
Ovens Logo
429 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
