Question about GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is slowly getting warmer - water dispenser won't dispense (occasionally) turbo cool won't work
  • 1,543 Answers
Open freezer door and look for any frost on the back wall inside the freezer. That would indicate a defrost problem.
Disconnect power to refrig. Unload freezer, Remove shelves and back panel inside freezer. Melt frost with a hair blower. Replace defrost heater located at the bottom of the heating coils. (Note: It may look different than the original, but insturctions enclosed with replacement cover that) Might as well replace the evaporator thermister at the same time, as your problem is about 98% of the time one or the other of those parts. The thermister is a white pencil shapped item, about an inch long, located cliped to the top of the cooling coils you just defrosted.
If you don't have the parts on hand, defrosting only will get your refrig working again for several days, while you obtain the parts.
Note: non-water dispensing is the result of the cold air from the freezer not being able to continue over the frost blocked coils, so it migrates back though the return air vent in the bottom of the refrig, resulting in a frozen water line, and often freezing in the bottom bin of the refrig.
Posted on Jan 02, 2011
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
I have aGSS25XSSQA SS refrigerator seems to have stopped making cold.
Frost buildup on the rear panel of the freezer indicates a defrost problem. Your model has the defrost timer built into the motherboard and for some reason that is unlikely to fail. What does go bad is the defrost heater and the defrost thermostat on your GSS25XSSQASS. Click HERE to view the parts listed as location 240 and 230 GSS25XSSQASS Freezer Components
The defrost heater is listed as location 230 in photo Here is a Link=> WR51X10042 Defrost Heater Assembly
And next is the part in photo listed as location 240 That is the defrost thermostat=> WR50X10068 Defrost Thermostat
Instructions on how to test these parts can be found on the same page as the parts. If you have any questions please let me know, Thanks Sea Breeze
Jul 12, 2012 | Refrigerators
GE gss22sgrf sidebyside water dispenser does not work, ice does
these unit have a problem with the water line freezing inside the freezer door. ge makes a tape style heater that goes inside the dispenser area to give just enough heat to keep it from freezing the water line.
you can try to change the freezer settings, warmer, clean the coils at the back of the unit and leave the freezer door open for 20-30 minute to allow the door to warm up and that will be a temporary fix to allow water to flow until you can get the heater kit.
Jan 09, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
GE refrig/freezer dispenser makes ice, but no dispensing of water
The dispensor water line , is probably trying to freeze , inside the door . raise the freezer control slightly warmer , to keep this from happening . May take 2 or 3 raisings to find the proper temp . Also , you can order a dispensor heat kit , pt # WR49X10173 , which comes with installation instructions .
Oct 05, 2009 | GE Refrigerators
LG LRSC26923TT, water dispenser not working
I have a LG GRP207TUJA side by side freezer, which has a water,ice,crushed ice dispenser. There is a button to select which mode of dispenser. The freezer just appears to be cycling through all the selections all by itself and make the bleeping noise as it moves from one selection to another...any ideas
Sep 15, 2009 | Freezers
Water dispenser won't work --ice dispenser is fine but no water comes of the water dispenser.
fridge set too cold ? frozen tank or water lines in fridge. set ref warmer for a couple of days
Aug 26, 2009 | Amana AFB2534DE Bottom Freezer French Door...
Admiral Refrigerator/Freeezer not cooling-food is melting
Most likely nthe refrigerator has a defrost timer. Need to find it and turn the timer clockwise slowly until you hear a click and refrigerator goes into defrost. If that happens you need to change the timer. It also could be an element is bad also. Let me know, Thanks, Sea Breeze
Mar 20, 2009 | Refrigerators
LG Fridge Freezer display has CF error code
Turns out a CF ER is a Compressor Fan problem.
Had a look and the fan was not turning, although it spins freely. Apparently it's a 3 phase 12v fan. I was able to get a resistance measurement across it but didn't know what to expect.
This also explains why it seemed a bit quieter and why the water is a bit warmer sometimes. The valve for the water dispenser is right beside the fan and it's getting pretty hot in there at the moment.
Dec 07, 2008 | LG French Door Cabinet Depth Refrigerator...
GE (PSS26MSRSS) Side by Side Refrigerator Logo
192 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
