Question about GE JTP45 Electric Double Oven
No power to heating coils
I have a GE jtp45w0a1ww. The lower oven has been a problem since new. After a cleaning cycle, hi-temp usage, or in the wrong mood, requests to bake or broil cause nothing to happen. Until 1 year ago I could always remove the panel between the upper and lower oven and reset the temperature switch as described in other posts. That no longer works. I replaced the temperature switch, but that did not help. This last week the upper oven stopped working - just like the lower oven. What is the problem?! How do I troubleshoot/repair?
  • 135 Answers
Hello sir
this is troubleshot on blue letter to check each parts
  • Check for a blown fuse or tripped circuit breaker
  • Make sure the power cord is plugged in securely
  • Test the electric outlet for current
  • Inspect the connections to the terminal block
  • Test the electric cord
  • Eliminate use of an extension cord, if any is being used
  • Check the outlet voltage
Posted on Jul 09, 2008
    Brigadier General:
  • 3,614 Answers
H\ave you check for any damaged ono the themal fuse..?
Jtp45 lower oven hot heating on any cycle
Possibly a tripped thermal fuse. Should be located behind the panel in between the upper and lower ovens. Might have a red reset button on it you can push down. If it clicks and then works again, look for possible cooling fan problems.
May 12, 2014 | GE JTP45 Electric Double Oven
Lower coil will not heat.
If the lower wont heat and the upper work fine then it is the coil itself that is bad and should be replaced. Hope this helps...please post back for further assistance.
Jan 11, 2011 | GE Profile JTP18 Electric Single Oven
Ge oven temp not correct after clean cycle
What are you cooking pizza. When you get at the high extreme most oven controls are not as accurate and have a wider differential. I assume the measurements are taken without opening the oven.
Dec 03, 2009 | GE Profile JTP56 Electric Double Oven
I have a frigidaire oven model # PLEB30S8CCB won't get above 290
The coils should glow red when working. If the lower (bake) element does not glow it may be burnt out. Some ovens cycle the bake and broil elements during preheat and that mey be why you are getting some heat.
Aug 27, 2009 | Ovens
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Self-Clean gets too hot on JTP56 double-oven
Your husband is correct, kind of. You should not try self clean again until you get the oven repaired. You have a temp sensor going out. I doubt that the oven actually got too hot, most likely the resistor in the sensor is failing as it heats up and giving a false temp reading.Since the lower oven was operating at the time, it is probably the sensor in the lower oven. Don't use it for baking until you get it repaired. It will go out completely and shut down both ovens. You should be able to get a new sensor for around $30 and they are not hard to replace.
The oven won't set your house on fire during clean mode if the cabinets were built with the correct air space and dimensions, but they do get very hot, about 800 degrees F. Most ovens give no trouble during the clean cycle, but if there is any weak components in the electronics system it will show up then. It will give you less trouble over time if you don't use the self clean mode and just manually clean it.
Jan 18, 2008 | GE Profile JTP56 Electric Double Oven
GE JTP45 Electric Double Oven Logo
235 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
