Question about Miele Novotronic W1918A Front Load Washer
The red light indicating a problem with water input is blinking. What should I look to fix?
Replace the cold water inlet valve.
W1900.pdf (http://www.mediafire.com/download.php?mynd4zimd2m
Posted on Jan 07, 2011
Mr coffee problems
You didn't indicate a specific model. So, I'm going to assume yours is relatively the same as my JWX27.
Let me start by clarifying what the red light indicates.
A solid red light indicates the cleaning cycle is in progress. A blinking red light indicates the coffeemaker is off, but due to be cleaned. When the coffeemaker is due to be cleaned, the red light will continue to blink while the coffeemaker is off until the cleaning cycle has been completed fully. The entire cleaning process takes about an hour and a half. And, it is not intuitive. So, here are my instructions.
With the coffeemaker off (with the red light blinking), pour four cups of pure white vinegar (no water added) into the reservoir. Don't short the amount. You'll need four cups to complete the cycle. Remove any filters, but leave the strainer basket in place. Tap the "select" button three times until the red light is on (and stays on, not blinking). The cleaning cycle now begins. It should take between 45 minutes and an hour to complete. Don't be concerned about the 30-minute long pause during the cycle when nothing happens. This is intentional and part of the cycle.
After the cleaning cycle has completed, get rid of the vinegar. Rinse out the strainer basket and the coffee pot. Run a full pot of clean water thru a regular brew cycle (with the pot and basket in place, of course). Then, dump the water, rinse the pot and basket again, and run another full pot of clean water thru a regular brew cycle. Dump that water too. And, you're done!
Jul 20, 2014 | Mr. Coffee Coffee Makers & Espresso...
Why won't the red blinking light go off on my primo water cooler?
If the cooler or the water are not getting cold I would check for a high pressure reset if they are getting cold the compressor would working fine, you could also try flushing it, is there a pattern to the flash that may indicate a code................good luck! mine has developed a leak and does not heat less that 6 mo old pretty disapointing.
Jul 20, 2014 | Unknown Primo Deluxe Stainless Steel...
Clean instructions
First, let me clarify what the red light indicates.
Feb 04, 2014 | Mr. Coffee JWX27 12-Cup Coffee Maker
Vulcan maual for vs160 hot water systems
i have vulcan vs160 hot water system , two indicator lights are mention on this system, one of green and one of attention light (red)
the problem is that, the red light is blinking every time.. so please can u tell me why red light is blinking all the time... thanks
Mar 13, 2013 | Motorcycles
HITACHI TV 50XU53K DEAD SHUTDOWN RED PROTECT LT BLINKS
Do any of the green led lights in the set come on?---red one should be on all the time--blinking would indicate a problem in the power supply at the primary side (INPUT).
May 21, 2012 | Hitachi Televison & Video
Blinking red light no picture
No picture or do u have a blue (or some other color) screen? And the blinking red light, is that the indicator light down by the power button that is blinking? I have the same tv and very similar problem, i have a blue screen and the red indicator light is blinking. If you have gotten ur problem fixed I would love to know how, or vise versa if I get mine fixed.
Sep 11, 2011 | Toshiba 65H84 65" Rear Projection HDTV
Replace the 2 bulbs. Unit powered up correctly and turned on like normal. Then Lamp1 and Lamp 2 indicator lights blinked (Indicating Start UP). After some period of time, it switched to Red 6 times blink...
1 red blink every 2.5 seconds indicates a cover error-- for this check the lamp cover
2 times red blinks very 2 seconds indicates temperature error. for this let the projector cool off check filters and fans that there is no blockage of air for proper cool down
3 red blinks every every 2 seconds Power error. incorrect voltage input or internal malfunction.
4 red blinks every 2 seconds indicates Fan Error check the fans make sure they are working and not blocked or need replacing.
i have nothing on 6 ligths go ahead reconect and check for proper count. hope this information helps.
Best of Luck.
Ray.
Jun 05, 2011 | Sanyo PDG-DXT10L Projector
We ran the clean cycle on the coffee maker and the clean cycle will not turn off.
First, let me clarify what the red light indicates. A solid red light indicates the cleaning cycle is in progress. A blinking red light indicates the coffeemaker is off, but is due to be cleaned.
The red light will continue to blink while the coffeemaker is off until the cleaning cycle has been completed fully. The process takes about an hour and a half and is not intuitive. So, here are my instructions.
May 15, 2011 | Mr. Coffee JWX27 12-Cup Coffee Maker
Tefal quick cup
Press the Hot and Cold button for 3 seconds,
The red indicator light will start to blink,
Release the hot and cold buttons and while the red is still blinking, press the and hold the hold water button, Once the desired amount of hot water is reached release the hot water button.
Now press and hold the hot and cold water buttons simultaneously for about 3 seconds.
The red light will stop blinking to the end of the programming.
NB the RED LIGHT WILL BLINK FOR THE DURATION OF THE PROGRAMMING.
Repeat the process for the cup quanity selector for the cold water.
------------------------------------The end -------------------------------------------
Feb 28, 2009 | Tefal Kitchen Appliances - Others
Cleaning light will not quit blinking after cleaning
The same thing happened to our Mr. Coffee this week! I followed the instructions about running vinegar through, then rinsing several times with water. However, the light would not stop blinking. We did by-pass the light by setting the timer for delayed brewing and it worked. However, that blinking light came on again. Then, my husband tired the vinegar wash again but instead of doing it one time, he ran the same vinegar through 6 times until the light went out! Then he proceeded with the water rinse. Our Mr. Coffee is working again!
Nov 16, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Miele Novotronic W1918A Front Load Washer Logo
148 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Dan Webster
Dan Webster
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
