Remote will not work I have tried changing batteries
    President:
  • 662 Answers
(1) try shining up the battery contacts - a little sandpaper/emery cloth/steel wool can clean up
even invisible oxide(s) on the surface of battery springs and contacts
(2) if that doesn't work, buy a universal remote as a replacement - the last 1 I bought was $8 at
a Dollar store - and it worked fine. But make sure that the remote supports your newer TV - alot
of older "Universal" remotes only support the obsolete analog sets along with just a (very) few
HDTV sets.
(3) as a last resort, pop the remote cover, and see if there's anything that got in there that you can
clean out to try to get the remote working. For every 10 remotes I've opened up, I've found
something fixable in about 10%. Usually they just die leaving behind no visible forensic evidence
of their COD (cause of death).
Posted on Jan 02, 2011
Changed batteries in remote now remote not working
Was your remote working before changing the new batteries?.
If yes, try another pair of batteries.
Nov 04, 2013 | Hunter 52" Ceiling Fan With Light And...
2002 hyundai elantra keyless remote not working after changing battery
try disconnecting battery in car then reconnecting...might help.
Aug 16, 2012 | Hyundai Elantra Cars & Trucks
Remote quit working for litex ceiling fan
after changing the batteries make sure you didn't change the remote code. If you didn't there should be a reset button inside the battery compartment, it may just look like a small hole. Just use a toothpick and insert it into the hole and lightly depress the reset switch.Replace the battery cover and try using the remote again.
Apr 13, 2012 | Casablanca Fan Dryers
REMOTE DOES NOT WORK I HAVE CHANGED BATTERIES
If you have been change the battery but remote still not work, please dissemble your remote check battery lead/wires for defective and other part on pbc. If nothing wrong there, the problem is usually the IR bulb on remote. Try replace with same model or just replace your remote with new one.
Regards
Regards
Mar 26, 2011 | Televison & Video
Skytech model no. sky-3001 changed batteries in remote and the transciever now i get nothing you can manually get fireplace to turn on using the transciever but when you switch it to remote and try to use...
You have to get the remote and transceiver to talk to each other. Remove all the batteries and wait a couple of minutes
before replaceing them. Place the transceiver in the REMOTE
position, press and hold down the LEARN button, and then
press the MODE button on the remote control. A change in the
beep tone will be heard and you have MARRIED the two devices. Should solve the problem.
Dec 18, 2010 | Skytech 3301 Thermostatic Gas Fireplace &...
The remote control stopped working on my toshiba flat screen i changed the batteries and only the volume works with the remote still can't turn on/off or change channels
Make sure the mode switch is set correctly for the device (TV, Cable, Video recorder, etc) that you are trying to control.
Apr 28, 2010 | Toshiba CZ36V61 TV
Post battery change- Wii remote won't sync
you will have to reset the consuleback to new you do that buy going in to the menu and setting follow the directions its because the software know what its looking for
Sep 21, 2009 | Nintendo Wii Remote Controller
Changed batteries and now remote won't work
sometimes if the batter is of expired stock then also it does not work.also try to clean the contacts in the sockets where u insert the battery.if still does not works then its quite possible that the internal circuit of the remote has gone fasulty.so the remote now needs replacement.
Dec 11, 2008 | Sharp Televison & Video
Remote not working,
Changed batteries on remote now they will not not work Help !
Jul 02, 2008 | Aspire Digital AD-225PSC Subwoofer
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
