I havoe a thin black line going across Samsung PN50C550 about 6" from bottom of picture. What can I do?
SOURCE: samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Posted on Dec 23, 2008
zjut
  • 106 Answers
SOURCE: thin black line
Try to replace the YSCAN board. If not fix it, then it's the PDP Panel failure.
Posted on Jan 07, 2009
  • 1779 Answers
SOURCE: my plasma has a thin black horizontal line
You can either have a bad Y-Upper buffer board, or dirty contacts on the plug associated with the horizontal line. Best to have a service company look at it.
Posted on Jul 24, 2009
welcomejee
  • 10594 Answers
SOURCE: My KDL46X3100 has developed two thin black lines
It is problem of LCD Panel that will be replaced.
Please check with dealer / store for extended warranty option.
Posted on Aug 07, 2009
  • 178 Answers
SOURCE: thin horizontal black line appeared lower half of
Fixed non moving lines usually means you have a problem in the panel display or t-con. If it is in warranty get it to a factory authorized service center. If not you can try to change the t-con and see if this fixes the problem, if not then it will be the panel it's self and will be cost prohibitive to repair.
Posted on Sep 01, 2009
Horizontal line about 1 from bottom of picture
The t con board or LCD panel of the tv is faulty. Can confirm by replacing the t con board.
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Apr 13, 2016 | Samsung Ln32d403 32-inch 720p 60hz Lcd...
My 42 in phillips LCD flat seen has a black horizontal line toward the bottom how can I fix this.
Samsung LN46B650 Thin Black Horizontal Lines - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI'm experiencing thin black lines from the top of the screen to the bottom. ... by babes808gpa / January 15, 2010 1:42 AM PST ... lines are about 1/4 inch apart from top to bottom of screen. starts on the right and about a 1/3 of the way toward the ...have the exact same problem, my lcd tv has multiple lines are horizontal it ...
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the ...
? 3:05
https://www.youtube.com/watch?v=KiqJuMiEiak
Jun 8, 2013 - Uploaded by Sameh Moustafa
Faulty HD- LCD - LED TV - Horizontal Lines STRIPS on the picture SOLVED .... I just have one black line ...
TV Repair Help for Vertical & Horizontal Lines on Your TV ...
? 2:47
https://www.youtube.com/watch?v=b0sI7LB4cZE
Dec 20, 2015 | Televison & Video
42 inch samsung plasma tv black vertical lines
Hi, Depeending on the thickness of the lines matters. If the lines are Black and about 1-2 inches thick it may be a bad bottom buffer board or a bad panel (screen).
If the lines are thin 1/16 to 1/8 inch it is most likely a bad panel.
You can open up the set and depending on the model, see the thin board/boards running across the bottom with ribbon cables going to the panel. You may be able to attempt reseating the ribbon cables, but be careful as some retainer plugs break very easy.
If the lines are thick black and the reseating doesn't correct it you may be able to buy the coresponding buffer. Unfortunately some bottom buffers are actually part of the panel. If you are not comfortable taking it apart then call a professional but be aware labor charges start around $200 not counting parts, panels start at $600 up to over $1000
hope this helps
Thanks
Eric
Aug 19, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Black screen with a line of the picture running
The vertical sweep generator is dead. The circuit that controls the lines being drawn from top to bottom has malfunctioned or died. This not something you can fix, you will need a professional.
Apr 02, 2009 | Emerson EWF2703 27" TV
Thin black line
Jan 07, 2009 | Samsung FPT5084 50 in. Plasma HDTV
Samsung 26inche lcd tv has a blue thin line acrross the left side
Dec 23, 2008 | Televison & Video
LN-T4665F 46 in. LCD- Black Line across screen
The set is under a year old and is under warranty. The LVDS cable inside these sets have a history of coming loose. The problem could be the panel. Either way, the set is the problem and needs to be looked at. This set is worked on in the home and does not need to be taken to a shop, so, you can still use it. Contact Samsung at: 1-800-SAMSUNG Hope this helps.
Jun 03, 2007 | Samsung LN-T4665F 46 in. LCD Television
Televison & Video Logo
77 people viewed this question
Top Televison & Video Experts
Electro Med Services...
