Question about Microsoft Wireless Controller for Xbox 360 (Blue)
Console is not syncing with controller even when it is plugged in
    Problem Solver:
  • 13 Answers
Are you using a play and charge kit, if so just try taking battery pack out and using normall batterys, as the play and charge kit does not carry any controler info to the xbox only voltage,
so it still acts as a wireless pad even when plugged in,
so what im saying is it could be a rubbish signal due to not having enough power charge,
if this does not fix it and you have tried the proper syncing process involving bothe the sync button on the xobx and the one on the controler its probably a broken controller, you should borrow one off a friend to see if that will connect to make sure not a faulty xbox
thanks
Posted on Jan 02, 2011
2nd controller how to get it to work
Turn on your console. Turn on the controller. Press the "sync" button on the front of the console. Within 3 seconds press the "sync" button on the top of the controller. (between the triggers, above the battery) If it does not sync chances are the controller is failing. Replace as needed, or plug it in.
Mar 03, 2013 | Microsoft Xbox Console
Tip
How to sync your Xbox 360 wireless controller
I have come across a few questions asking why a wireless controller is on but not connected, or why it is on and no corresponding green lights were on, etc.. So here it is: DRAGONF1R3 REPAIRS' GUIDE TO SYNC YOUR XBOX 360 CONTROLLER TO IT'S CONSOLE
Quite a title I know, but the actual guide is very simple.
Step 1: Power on your Xbox 360 console. In this guide I'm assuming everyone already has their console hooked up, if not, contact me.
Step 2: Power on Xbox 360 Controller. Make sure it has a battery pack that has correctly place and working batteries or charged re-chargeable battery pack.
Step 3: Locate the small circular sync button on your controller. It is near where your controller can be plugged in (between the LB and RB).
Step 4: Locate the small circular sync button on your Xbox 360 console. It is next to Memory Unit slot 2.
Step 5: Press and hold the controller sync button until the green power lights start spinning.
Step 6: While your controller lights are still spinning press and hold the console sync button. The console's lights should spin also, then flash, and finally show the player slot light on both the console and the controller.
Viola! You've synced your wireless controller! You can sync up to four controllers.
Also, you can use this guide to sync to different Xbox 360 consoles. So you can bring only your controller to your friend's house.
Note: If you sync your controller to another console, you will have to re-sync it to your own afterwords.
on Jan 18, 2010 | Video Game Consoles & Games
My controller will not link with my xbox. it just flashes 4 green lights around the circle. what can i do?
Did you sync it? here's how to sync it:
Step 1: Power on your Xbox 360 console2_bing.gif. In this guide I'm assuming everyone already has their console2_bing.gif hooked up, if not, contact me.
Step 2: Power on Xbox2_bing.gif 360 Controller. Make sure it has a battery pack that has correctly place and working batteries or charged re-chargeable battery pack.
Jan 23, 2010 | Microsoft Xbox 360 Controller
Neither of my xBox 360 wireless controllers will sync with my 360 console. I have tried both contollers with a variaty of battery packs and they still wont sync but i have no problem with my wired...
Remove the batteries from both controllers, and unplug the Xbox for a minute. Now turn the Xbox on by the power button on the console, Install the batteries in your controllers, and hit the Console sync button first, then hit the little sync button on top of the controller.
If this does not work, you can purchase the wired charge pack that you must plug in to the USB port of the console to charge, and this will sync as your wired controller does. When it is synced unplug the wire from the controller and voila. Remember, the charger pack will look like this.
http://www.techsick.com/shop/images/P/xb360-controller-charger-36.jpg
Good luck and be patient.
Dec 19, 2009 | Microsoft Xbox 360 Controller
Just got play and charge kit and i put the rechargeable battrey pack in and pluged it in but now the controller and console are not reading snigle
sometimes the xbox has a syncing problem, then controller when turned on turns on the console, so it is obv working but dosnt connect after that, i had this problem and what i did was as followed, 1. turn the console on dont use the controller hold the sync button on the Console for 30 seconds, after this turn off the console and remore the power plug from the console and your mains, now wait about 5 miutes, then plug it up, first click the xbox sync button, and hold the remotes sync, this should then work. if not i suggest contacting microsoft, http://www.xbox.com/support
Jun 07, 2009 | Microsoft Xbox 360 Wireless Controller
I cant sync my madcatz ps3 wireless controller
try to plug it in and then press the ps button or let it sit for a little bit while plugged in and then try it
May 27, 2009 | Sony Playstation 3 (PS3) Console
Will not play rock band!!
if they are wireless you need to connect them. push the sync button on your xbox and then the sync button on the controller, repeat for each controller. if youre plugging it all into a USB hub, you need to plug in the hub. with a wall adapter.
Apr 01, 2009 | Microsoft XBOX 360 ARCADE Console
Xbox 360 CONTROLLER QUESTION
Are you syncing them up? To do this press the small white button on top of the controller at the same time you press the small circle button on the front of the console.
Jul 01, 2008 | Microsoft Xbox 360 Console
Wireless controller issue
The fact that the controller is not syncing to your console even when connected via the Play and Charge cable leads me to believe that your controller is more or less "a goner". The wireless controllers should automatically sync with the console when plugged in via the cable, so since yours doesn't sync I would guess there is something wrong with the IC chip inside and somehow something got corrupted.
Out of curiosity, when you plug in the cable how can you tell the controller is on if it doesn't sync? Do the lights continuously spin around in a circle? Do they just flash? Does quadrant 1 light up like normal but pressing buttons on the controller doesn't do anything?
Apr 13, 2008 | Microsoft Xbox 360 Controller
Microsoft Wireless Controller for Xbox 360 (Blue) Logo
119 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
Martin Murray
Stu Morris K
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
