Question about Hoover L2310 GUV Central System Vacuum
Ordered a replacement motor for Hoover GUV garage utility vac L2310. It took months to receive. There are no installation instructions and the old motor was left with one of the dealers and lost. Any suggestions as to how to replace this motor.
reddevil6
  • 1673 Answers
SOURCE: valve stem assembly
Put the rubber seal on the bucket first, then put the spring on the valve stem, slip into the hard collar, then push it into the opening in the seal, it will snap into place.
Posted on Feb 14, 2008
micromaster
  • 3614 Answers
SOURCE: lost instructions for hoover steam vac
kindly please wait...
Posted on Jul 13, 2008
jyackle5
  • 8197 Answers
SOURCE: instructions on how & how much cleaning solution on steam vac
http://www.hoover.com/pdfs/manuals/F5914900.pdf
Posted on Jan 11, 2009
  • 909 Answers
SOURCE: Lost Manual for Hoover Steam Vac Model #5906-900
Visit www.hoover.co.uk
There you can pick after sales service,instruction manuals, etc. etc.
You will find your manual there.
I hope this helps
Posted on May 13, 2009
CorvetteKing
  • 108 Answers
SOURCE: Do not know how to use Hoover Steam Vac Spin Scrub
Hoovers website, Hoover.com has them free to print.
Posted on Jun 14, 2009
Belt falls off Dirt Devil upright
I have a Hoover canister vacuum it works great.
I think you have the right idea. Good Luck!
May 15, 2017 | Vacuums
Water in henry hoover motor HVR 200A
Chris, I hate to be the bearer of bad news, but you've already guessed it. You need a new machine. Personally, if I were you, I'd check into the small shop vac's, type of vacuum. Craftsman has a good one that I've been using for, wow, more years than I can remember now. I had it a long time I know that. I actually picked up a spare one at a garage sale last summer and put it up on a shelf for one my old one finally bites the bullet, but so far, it's still going strong. The wet/dry vac's have a float system in them that actually plug the bottom of the air chamber where the vac draws it's air from, when the water gets too high in the tank. The motor starts to race faster than normal and that's the tipoff that it's full. Dump out the tank and go at it again. Better luck this time.
Nov 10, 2013 | Numatic Henry Bagged Canister Vacuum
Spinbrush is very loud, barely sprays, spraks flew out the side. It is only 6 months old.
Hope you kept your receipt! That's a warranty item. Your motor is making the sparks. Go to hoovers website find the nearest service center and take the machine and your receipt to them. You'll get a new motor, installed, at no charge because they have a 1 year warranty.
Jan 18, 2013 | Hoover Steam Vac Dual V w/ SpinScrub...
Vac will not come on?
If it's less than 30 days old take it back and go get a good vac from a vac store. If it's 9 months to a year old, it's probably got a bad motor. It was made in China, and built to fail in one year. Buy a Riccar. Made in America and built to last for 20 years
Apr 30, 2010 | Hoover U8315960 Bagged Upright Vacuum
Hoover U5780-900 Windtunnel a month 1/2 old just started stopping when it is running and wont turn back on for a few hours why?
The motor has a thermal protection sensor on it. So your motor may be going bad, it is pulling to many amps for some reason, could be a clog somewhere or a bad bearing in the motor.
Feb 21, 2010 | Hoover U5780-900 Windtunnel Cyclonic...
Low suction
I suspect the hoses are plugged with debris.
Apr 21, 2017 | Hoover L2310 GUV Central System Vacuum
No suction - air blowing OUT from tube
Is the air blowing out of the pick-up tube or out of the exhaust tube on the unit? I am assuming the pick-up tube. The installer has hooked your system up to the exhaust tube on the unit. Hook up to the intake on the unit instead.
May 27, 2009 | Hoover L2310 GUV Central System Vacuum
The unit has 2 intakes. one is used. what do i do with the other
no one is exaust so one sucks one blows sucks is inside for vac . blows gets exsausted outside
Thank you for useing fixya please rate me
Oct 27, 2008 | Hoover L2310 GUV Central System Vacuum
Brushes not working
Check the filter from the bottom, it has a red frame, pull it out far enough to clean it, if it is clooged, then the brushes won't spin. If it is clean, pull the brush block out, make sure the shaft that goes up into the turbine is not brokked off, if it is replace thebrush block. With the brush block out, turn on the machine and look up where the brush block goes, there is a square hole, if it is turning, then it is ok, if not, then the turbine is either clogged up or the turbine has gone bad.
Jun 20, 2008 | Hoover F7220900 SteamVac V2 Upright Vacuum
Central vac (Hoover) always on!
There should be a manual/auto switch. If it is in the manual mode, then it will run all the time. Other then that you probably have a stuck relay. But this will have a years warranty on it, so you should be able to have it serviced under warranty.
Oct 08, 2007 | Hoover L2310 GUV Central System Vacuum
Hoover L2310 GUV Central System Vacuum Logo
130 people viewed this question
Top Hoover Vacuums Experts
Jim Parker
Jim Parker
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
