Question about GE JKP27 Electric Double Oven
Hi. I have a GE Profile JKP27W double oven. After running the self cleaning cycle, the top oven no longer works. The display will read 100 degrees for a minute and then shut off. I've cut the breaker to the unit and have moved the bakeing element from the bottom unit to the top, but the problem persists.... Any suggestions?
  • 1 more comment
  • tjroyer Jan 03, 2011
    Hi Daniel -
    Thanks for the advice... I'll test the resistance on the sensor tonight.
    Travis
  • tjroyer Jan 08, 2011
    Hi Daniel,
    I verified that the temp sensor is reading correctly. You indicated that I should test the door switch as well... I'm assuming that this is working properly as the oven light is switched on/off based on the door being open or closed. Let me know if I'm over simplifying...
    Is there anything else I should check before replacing the control assembly?
    Thanks,
    Travis
    I did some additional digging - I think you were referring to the latch sensor. I dug up the technical data sheet (was conveniently inside the oven cover panel). I verifie that the latch is reading as open currently (0 Ohms). I havent'e figured out how to simulate the oven latch relay being closed as its an electronic switch....
    Guessing this is not likely the culprit... will look into replacing the control as you've suggested.
    Thanks for your guidance!
    Travis
  • 4,323 Answers
Hi
The issue can either be a bad electronic control/clock assembly or the oven temperature sensor (probe) has gone bad. To solve this issue start by checking the oven temp. sensor for 1100 ohms, if the rating is more then that then check the control and door switch and replace the part that is bad. Hope this helps...
Daniel
Posted on Jan 02, 2011
  • 1 more comment
  • Daniel Scott
    Daniel Scott Jan 03, 2011
    Alright Travis
  • Daniel Scott
    Daniel Scott Jan 08, 2011
    Travis you can replace the control
  • Daniel Scott
    Great...if you are testing it with a multimeter then check the control before replacing it as the latch seems to be open then it should also be replaced.
Upper oven will not self clean. The door lock does not actuate when self clean is selected. All other functions seem to work OK
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 23, 2010 | GE Profile JKP56 Electric Double Oven
Double oven, top oven run by keypad turns off
I have a double oven. The top unit works fine. The bottle unit will turn on to cook or clean. Then after a few seconds it turns itself off.
Oct 12, 2009 | GE Profile JKP56 Electric Double Oven
Bottom oven doesn't heat after running self-clean cycle
Usually, when an oven won't heat, it's because the bake element is burned out. The bake element is the black, pencil- thick tube at the bottom of the oven. When the oven heats, the element glows red. This element has an expected life-span of several years. It may last for only one; it may last for many more. When the element burns out, you need to replace it.
Aug 17, 2009 | GE Profile JTP56 Electric Double Oven
GE JTP56 double oven controls OK top OK bottom no heat
have you inserted the business card as described in the solutions?
Jun 26, 2009 | GE Profile JTP56 Electric Double Oven
Display went blank during the self cleaning cycle
heatman101
uiitu
Apr 29, 2009 | GE JTP28 Electric Double Oven
GE Electric Double Oven Door Will Not Unlock
Seems like you found out the hard way what I wrote about in this tip...
Check it out it also contains some thing to try on how to unlock that oven..
heatman101
Asker's Testimonial " Wish I had read this first. I never would have usedthe self cleaning option. Thanks for the info!! " - amymrocks
Nov 05, 2008 | GE Profile JTP56 Electric Double Oven
GE Profile JGB97 Self Cleaning Oven Controls won't work
You have a problem that may be solved with my solution to the Dreaded F7 Problem. Even though you don't have a F7 error on the display the symptoms are all the same. You can find my fix at the following links.
http://www.fixya.com/howto/h155060-dreaded_f7_error
I have shared this with more than 1550 folks and most report success. This problem often develops after a self clean cycle.
I hope it works for you too. Please let me know at the following:
hutchipop@yahoo.com
Good Luck,
Charlie Popeck,P.E.
Consulting Engineer
Feb 06, 2008 | Ovens
Ovens Logo
308 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Are you a GE Oven Expert? Answer questions, earn points and help others
