Question about Brother HL-4040CN Laser Printer
Does cold cold weather hurt toner in a printer. I carry a brother 4040 in car and want to leave it in there. thank
  • 1,772 Answers
Sorry to read about your problem, I hope this helps you out.
NO, NO the toner cant handle the cold, moisture in the toner will freeze
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Posted on Jan 02, 2011
  • 6,771 Answers
The only advise I can give is the electronics and the mechanical operation of a unit like this will be put under more strain when it comes in out of the cold. The electronics need one to three hours to warm up before you plug it in or risk blowing the circuits, and mechanical parts will build up condensation causing printer malfunction. The extreme cold you are talking would will give the printer a short life span.
Have this and a Brother 4040. BOTH are producing random splatter dots. Mostly black, but a few cyan. Replaced the toner with OEM, replaced the drum set with OEM, but the spatters continue. Cleaned the drum...
Remove the transfer belt and clean it GENTLY with alcohol (Iso-propanol preferred but Meths will work) on a cotton ball or very soft cloth. Rotate the belt as needed until all the surface has been cleaned. You may need to go round several times to clean off persistent spots. Patience is better than pressure. If spatters continue check the fusers. It is also possible that there are toner spots on the drums which can also be cleaned off with Iso-propanol on a cotton ball
Oct 02, 2017 | Brother MFC-9560CDW Wireless Laser...
Brother dcp 7055 printer toner ended error
i haver Brother Laserjet DCP 7055 printer. Once i refilled its toner but now on 2nd time i refilled it the printer is gives an "Toner Ended" error & replace the toner message.... Pls help meto solve it... Thanks lucky bareilly
Jan 10, 2012 | Office Equipment & Supplies
Hi I have a brother HL-4040 CDN -- I had to clean off the imaging drum by rotating the gear manually now it is telling me that all three of my new colours of toner are suddenly at their end of...
For getting proper guidance to fix this error plz call me at +1800-243-0051 ' 1800-243-0019. Because its not possible to fix the error on here. May be we fix it with doing some work together.
May 19, 2017 | Brother HL-4040CN Laser Printer
My Brother HL 4040 says "toner life end" for the black toner. I was just replaced a few days ago, printed OK now its empty?
Gently pull the toner cartridge out. don't want to spill toner,,, inspect to see if all plastic has been removed. warning toner is super fine soot do not repeat do not vacuum it up ,,, messes up vacuum and puts dust in air,,stains clothing
Look at contacts on toner cartridge and scrub with old tooth brush,,, look at contacts of printer same same.
Nov 27, 2010 | Brother HL4040CN Laser Printer
3b error code on display unable to print
Sorry, this is a serious error and it means the PC board is toast. On mine, it gets to 22 on the counter (I assume it's a RAM integrity check) and then the LCD turns red and says "Print Unable 3B". When I called Brother they told me I needed a new PC board, which by the way is very hard to get to (you have to disassemble everything, then take apart the printer piece by piece). The price for the PC board is around $100 plus labor, so you're talking easily $200 to fix this.
Thanks Brother for making a self-destructing Lemon of a printer, the Brother HL-4040. And thanks for telling me I was on my own and to fix it a local repair shop.
May 19, 2010 | Brother HL4040CN Laser Printer
Red streaks
That machine needs constant cleaning, you slide out the toner drawer and one at a time remove each toner, open the frosted plastic flap below and slide the wiper back and forth about 10 times to clean the corona. You could also have a bad magenta cartridge which Brother will replace for 90 days from date of purchase.
Nov 23, 2009 | Brother HL-4040CN Laser Printer
Problem with our Brother mfc-7840w toner all over the page
since i finally figured this out I thought I would post this for anyone who has the
HL-4040 CN printer - or one similar
After seeing the hitting the buttons with the door open tricks for different models I tried anything that sounded like it had the same buttons my 4040 has... nothing on here worked so I just started hitting combinations of buttons with the door open - wow there are quite a few hidden menus there
For the toner life reset menu:
1 Open the front cover of the printer
2 press and hold the cancel button
3 press the reprint button while still holding cancel
- here is the reset menu - go to the appropriate cartridge on
- the menu and reset it and you're done!
FYI... Pressing the "Go" button and the up arrow gives you the parts life reset menu (drum, laser, fuser, etc.)
I also did the electric tape over the windows - which worked before the reset - but I thought this fact would be helpful too.
For anyone that is asking "what window?" I think it is the clear plastic opening on the sides of the cartridges where you can actually see the powder inside the cartridge - the color of the toner (magenta, yellow, or cyan). I didnt really know that for sure when I tried, but it made sense, and it worked. So I am fairly sure that is the "window" you should be trying to cover.
you can go here for more update: https://www.microtonersupplies.com.au/toner/brother-toner-catridges
Sep 03, 2009 | Brother MFC 7840W Printer
Toner light is still on
If you put new toner in your used cartridge and you still have the Toner light, you need to reset the "reset gears". Take the cover off of the gear side of the cartridge. The reset gears are actually attached to the inside of the cover. Move the gear with the lever to the opposite side of the current position.
Nov 30, 2008 | Brother HL-2170W Laser Printer
PRINTER
Hi
  • Open top cover
  • Remove toner unit
  • Place on flat surface
  • Press the blue release level and lift toner unit out leaving drum
  • Open new toner packet
  • Shake new unit remove yellow protection plate
  • Fit into drum unit click down
  • Install whole unit into machine
  • Close top cover
Thats it Thanks J
Nov 06, 2007 | Brother HL-2040 Laser Printer
Brother HL-4040CN Laser Printer Logo
1,163 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
