Question about Canon Office Equipment & Supplies
How to change the inkjets - Canon Office Equipment & Supplies
    New Friend:
Hi
Please follow the following Step by step Procedure to change your inkjets.
Open the top board of your inkjet printer. You ought to have the capacity to get to the ink cartridges once the top is open. A few printers will re position the cartridge carriage to give you better get to.
Expel the old cartridge from the carriage. Contingent upon the printer, you may need to push down on the cartridge and afterward pull outward to expel it. Different printers may oblige you to lift the cartridge out of the printer.
Unpackage the new substitution cartridge totally. New cartridges will frequently incorporate plastic strips and defensive bundling that must be expelled before you can embed the cartridge into the printer.
Embed the new cartridge into the printer. This will be the turn around of expelling the old cartridge.
Close the top board of your inkjet printer and permit the printer to distinguish the new cartridge. You ought to now have the capacity to print utilizing your recently changed inkjet cartridge.
Inkjet Cartridges and Toner Refills
Posted on Feb 17, 2017
  • 475 Answers
  1. Open the top panel of your inkjet printer. You should be able to access the ink cartridges once the top is open. Some printers will reposition the cartridge carriage to provide you better access.
  2. 2
    Remove the old cartridge from the carriage. Depending on the printer, you may need to press down on the cartridge and then pull outward to remove it. Other printers may require you to lift the cartridge out of the printer.
  3. 3
    Unpackage the new replacement cartridge completely. New cartridges will often include plastic strips and protective packaging that must be removed before you can insert the cartridge into the printer.
  4. 4
    Insert the new cartridge into the printer. This will be the reverse of removing the old cartridge.
  5. 5
    Close the top panel of your inkjet printer and allow the printer to detect the new cartridge. You should now be able to print using your newly changed inkjet cartridge.
Posted on Jan 02, 2011
How to change the toner
This unit does not use toner. It uses ink cartridges, hence it is called an OfficeJET All-in-One INKJET Printer. To change the ink cartridges, you lift the latch located on the front of the unit above where the paper comes out.
Aug 26, 2010 | HP OfficeJet 9120 All-In-One InkJet...
How to chang ink
When it is time to replace an ink cartridge in your HP inkjet printer, you will receive a pop up message on your computer screen. Replacing an ink cartridge is just part of owning an inkjet printer, and a tradeoff with the high quality imaging you are able to achieve on an HP inkjet. It is not something a professional needs to do; just follow these simple instructions to complete the change and get right back to printing.
  1. Allow your inkjet printer to run entirely out of ink. Unless the quality of your images is suffering, there is no problem with letting your ink run low.
  2. Open the printer door. It should fold from the top down toward the tray. When it is open, it should expose the inner workings of the printer.
  3. Press the change cartridge button. It is at the top of the printer next to the power button.
  4. Pull on the green top of the inkjet ink cartridge and remove it up and out of its holder. Do this gently so the printer is not damaged in the process.
  5. Recycle the empty inkjet cartridge or have it refilled at an ink refilling center.
  6. Carefully remove the tape from the refilled or new inkjet ink cartridge and insert the cartridge in the same orientation as the one you removed.
  7. Push on the green top until the cartridge snaps into place, press the cartridge change button and close the printer door.
Good luck.
Apr 26, 2010 | HP PSC 1315 All-In-One InkJet Printer
Change ink
Usually, with an inkjet printer to change the cartridges, open the cover and then press the power button - or the other button, if there is one. Don't be afraid to press buttons ..
The cartridge carrier will then move from its 'parked' position to a more central, accessible position. Unclip the cartridge retaining clip and simply lift the cartridge out. Virtually all inkjet printers work on this principle.
Don't try and manually force the cartridge carrier along from its parked position otherwise you will cause damage.
May 17, 2009 | Epson Stylus C20UX InkJet Printer
Need to change inkjets
the short life may be due to the qualiy of prints..............
when u give the printcommand the inkjets move towards the rigt handside then u can remove them.....
Oct 10, 2008 | Canon PIXMA MP160 All-In-One InkJet...
151 people viewed this question
old marine
old marine
