Question about Samsung Audio Players & Recorders
Samsung rts-he10t/x dvd dose not play all discs even new ones have put disc cleaner in but still, the disc freezes
  • 163 Answers
SOURCE: Cannot play this disc
remove the cover and see if the dvd run, if not you got a motor problem or a motor drive one,if yes then try cleaning the reading eyes(pickup)by blowing dry air (get a can at radio shack)check for goods, if dosent work, take it to a shop for a repair thats all you can do, is a job for a tech....good luck
Posted on Aug 10, 2006
  • 286 Answers
SOURCE: movie skips and freezes during play
This is a common problem on CD and DVD players.
Altini is correct to a point. You can try taking the top case off, removing the DVD drive and taking the top off of the drive. Then use a q-tip on the laser lense. I use a little squirt of windex on the q-tip. Gently clean the lense even if it doesn't look dirty. Make sure you very gently work the lense up and down through it's travel. This will make sure no dust or dirt is interfering with the lense focusing.
Reassemble and try your movies again. This is a 50 50 proposition. If you still have the same problem, the mechanism has likely gone bad. Time for a new DVD player.
Posted on Feb 14, 2008
  • 6 Answers
SOURCE: Recording on DVD-R with Samsung DVD-R155
Heating issue. If you remove the cover and touch the processor chip - you will not be able to keep your finger there for more than a second (that is if your really want to use this crude method to test the temp).
I have taken measurement and its around 50C. Thats a lot for no heatsink or cooling fan.
If you have the unit in a cabinet with no air flow - you will not be able to use this unit for more than 3 months and up to a year. Best to have it on top of a cabinet or in one with an open front and back to allow some airflow - or just anywhere where its in the open.
Samsung has another unit - the AR650, which I believe is discontinued - which for some strange reason has realized this concern. My guess its a whole different team of designers (or at least some folks with some brains) and added a cooling fan into the unit. Its the same exact case and motherboard as the 135, and 155. There are absolutely no issues with it rejecting disc's - even after a year of use for some users.
In Summary:
Solution 1 - Place it in the open
Solution 2 - Remove case and drill holes to the topside
Solution 3 - Remove case and add a fan
Solution 4 - Remove case and add a heatsink over proc (will still need to drill holes over heatsink..
Solution 5 - We can all complain to Samsung and have them recall the units
Posted on Aug 22, 2008
THENTHEREWER
  • 131 Answers
SOURCE: i have a samsung cinema
make sure you have the audio cables connected to the OUTPUT on the tv & the INPUT on the surround sound(from your desciption sounds like you have them reversed)hope this helps,thanx for using fix-ya,please rate all replys
Posted on Nov 18, 2008
  • 98 Answers
SOURCE: player won't read a DVD
Sounds like a bad pick up assy (Laser)
Posted on Nov 25, 2008
I got a new Samsung DVD player (1080) and when I put on brand new discs in it, it just kept whirring inside, but nothing came up on the screen ! I have it connected via HDMI cable to a Samsung LCD TV, so...
If a new DVD player ur tv dose recgonises the DVD disc and not reading the DVD disc,it might be dirty or scratches and cracks on the DVD disc itself.Tries It with other DVD discs,if have the same problems,than it is the DVD player itself,newly bought,yes return it get another one.
Dec 15, 2010 | Samsung DVD-H1080 DVD Player
My Samsung DVDR120 will not accept any new DVD-RW discs. I have tried Maxell, Memorex and SONY. They all either freeze at 85% initialization or formatting, or spit out saying system error. The machine is 4...
This is a common fault and usualy caused by the DVD drive going faulty, The Lazer changes angle as it records across the disc and at about 80% there is a change point.
I suggest putting a cleaner DVD through the unit before you try anything else as a bit of dust can cause that problem. If that doesn't fix it than you may need to change the DVD loader unit as a whole or as you suggested by a new modern unit with even more features.
Jul 16, 2010 | Samsung DVDR120 DVD Recorder
My intergrated dvd is playing up
Sounds like the laser head to me.
Feb 01, 2010 | Philips DVP642 DVD Player
DVD's will no longer play
try blowing or its how you swipe your cds you should swipe up and down by a cd cleaner that might work
Apr 26, 2009 | Samsung DVD-V4600 DVD Player/VCR
X-box 360 won't read discs
sounds like the reader lens has burnt out on it .is your xbox stood upright ? seem to hear the lenses burn out alot faster if the consol is upright as opposed to being led down, you can buy the parts from ebay or other computer shops , or send it back to microsoft to repair , you are able to lay downloaded games as they play off of the hard drive memory , where as the disc games obviously read off of the disc when the laser gets tired they work intermitantly then eventually stop all together.
hope this is of help to you
kind regards
bert31000
Mar 19, 2009 | Microsoft Xbox 360 Console
Won't accept any dvd disc
It sounds like the Laser went out. Buy a new dvd player
Jan 13, 2009 | Samsung DVD-VR330 VCR and DVD Recorder
"wrong disc"
you have a defective lens. best way is to replace it with a new one.
Oct 27, 2008 | Spectroniq PD-1100 DVD Player
DVD video player problem
your laser is getting weaker now, if you have thoroughly cleaned then it needs a replacement now.
Apr 29, 2008 | Samsung DVD-V4600 DVD Player/VCR
Samsung DVD VR355 DVD format problems
I have just copied a video to a dvd on my samsung dvd-vr355 and finialised the disc with a title now it will not play any disc,even if it is. shop bought, just says loading then the dvd opens to reject the disc. please help
Mar 07, 2008 | Televison & Video
Dvd player model dz111
there is a disc cleaner disc and a cleaning solution. put the liquid on cleaner disc and insert it.play for some time. now put a new dvd or cd and try
Oct 24, 2007 | Audio Players & Recorders
18 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
