Question about Akai LCT2060 Television
No sound when connected to my digtal cable box
When i connect my cable box to my TV using the yellow, white, red cords i get no sound. There is sound on the regular channel but when i connect the cord to the av1 or av2 there is no sound. Please help me this is my three year old son TV and he wants to watch cartoon network at night.
    Problem Solver:
  • 7 Answers
Have you tried to connect the red white and yellow av cords to another tv? if you have sound on another then its probably the tv you are trying to connect to for your son. If thats the case you could by an rf modulator which converts the red white and yellow to the coax connection in which case you'll have sound.
Posted on Jul 09, 2008
Hooking atari flashback to the tv/
White is sound yellow is picture.
look for three rca jacks red white yellow. connect and set tv to see whatever input you connected to. white can go either white or red but yellow must match.
Dec 24, 2013 | Atari Flashback 2 Console
How do I find the right channel to set my tv on so it will receive cable tv
If it is a cable box and you are connecting via coaxial cable using the rf converter in the box it is usually channel 3-4 but it can often be switched. If it is a satellite box it may use a high channel number like 73. Keep in mind that there is a traditional tuner and a digital tuner in your tv set so you made need to connect the cable and then do a channel setup for it to sense the active channel.
The image quality is best when the cable box is connected in this order from poorest to best; coaxial cable, rca cables (red,white,yellow), s-video (on older televisions), component video and optical audio using the three yellow, blue, green cables for video and a white or red for audio or optical input, DVI, or the best, HDMI with support for 1080p and audio. On your TV you should use an HDMI cable and simply change the Input or source button to that. The HDMI cable integrates video and sound and it will transmit a dolby surround signal to your TV just as a separate optical connection will.
Nov 27, 2013 | Insignia 42" LCD Flat-Panel HDTV
The coax input on my tv is broken off how can I connect the cable to it other than the red white and yellow cords which don't have a good connection either I have my dvd player hooked up to hdmi is there a...
the simple answer is no.
but if you have basic cable (coax) you could connect it to a vcr, tune the channels with the vcr-
connect the vcr to the TV with composite video (yellow, red/white)
Apr 13, 2011 | Samsung Televison & Video
Help
Hi, Flat panel television instruction manuals are not very easy reading material, there are many connections on the back-you need to plug in some sort of input-always coming from the " out to T.V." of another device. Cable coax's are most common-the cables aren't very flexible that's one way to tell them apart from an RCA cable-usually with red, white, yellow,green and blue colored ends. The red, white and yellows are what we'll focus on for now-the yellow's are for a picture-connect them from an " out to TV" to " video input" on the back of tv, then for sound likewise- red and white colored from an"audio out " to "audio in " if coming from a VCR-you may use the rather un-flexible " screw on" coax connector-same if coming from a satellite/cable box-some satellites require tuning tv channel to # 60 for a picture-other wise it's channel 3 or 4. although you will get a better picture using yellow, red & white rca cords. I hope this has been of some help, prodzilla
Mar 31, 2011 | Televison & Video
I am trying to hook the dvd player up to my old tv and am only getting sound, I am using the red, white and yellow cord.
I hope this will clarify things, you have 3 connections on each end.
DVD
  • Yellow Cable goes on Video Out (Yellow)
  • White Cable goes on Left Audio Out (White)
  • Red Cable goes on Right Audio Out (Red)
TV
  • Yellow Cable goes on Video IN (Yellow)
  • White Cable goes on Left Audio IN (White)
  • Red Cable goes on Right Audio IN (Red)
the coaxial audio connection does NOT need to be connected.
I hope this helps,
Magoo
Mar 10, 2011 | Toshiba SD4990 DVD Player
Trying to hook up panasonic veira flat screen tv without a manual. Not sure where to put the red, yellow and white cord.
These cable is to connect your tv to other hardware like a dvd player. Just plug the yellow cord on the yellow input in the TV and in the yellow output of the DVD, and the same thing for the other two colors. The yellow it's for the image, and the white/red are for the stereo sound (right and left channels).
If you don't have extra hardware you wont need to connect that cable.
Mar 07, 2011 | Panasonic Viera TH-42PZ80U Plasma TV
Need to connect dvd player have yellow, red and white connectors
Red is right channel, White is Left Channel, and Yellow is video.  If you just got the TV and DVD player its a pretty simple setup.  Just look on the back of the DVD player and hook the yellow cord to video and hook the other end to video on your TV.  Now just plug in the red and white cords to the audio on the back of the DVD player and connect the other ends to audio on the back of the TV.  You can bypass these connections and just get a HDMI cable which has video and sound all in one convenient cord, but they cost more.  You just connect the cord on the back of the DVD player where it says HDMI and then plug the other end to the TV where it says HDMI.
Nov 05, 2009 | Televison & Video
Sound Problems?!
If you have just basic cable with no box, your tv must have audio out. If you do have a box then you can come out of it. Digital coax or optical would be better for the dvd if it has it.
Jul 07, 2009 | Audio Players & Recorders
How to connect new HD cable box to receiver
HI:
You are using a new HD Cable box, that are using componet video cables for HD, Unfortunetly this receiver does not have componet inputs, so you will just have to run the audio from the televison directly to the receiver by connecting the video out and audio out from the television to the receiver's video Input one. This will require a normal RCA composite cables yellow,red,white. Connect one end of each of the cables to televisions output terminals, and the other to the input one on the receiver. Note: Your TV might have a seperate term called Monitor out, Connect the yellow here, and the red and white to audio out. You can do the same for the DVD but you have to use the same cables,Also the television will not display HD picture this way as this is not a HDTV Receiver. If you just want TV sound to the receiver then do not use the video(Yellow) cable just use the audio out terminals from the tv and connect to Input one on the receiver. you can do this with the cable box also but you have to use RCA type cables . If you want the full HD experience then a new up todate receiver is necessary.
Dec 06, 2008 | Sony HT-DDW740 System
Just need to know where to plug in the red, green and blue cords
The red-blue-green outputs of the cable box are COMPONENT video, and the yellow-white-red inputs on the tv are COMPOSITE video. Although the words sound almost alike and the connectors look similar, they are incompatible signals. You'll need to change either the cable box or the tv so they match. Maybe this would be a good way to rationalize getting that new home theater system! Or maybe call your tv cable company and ask for a different box with composite video output. Once the cable box matches the tv, you don't necessarily need to change the cables. If the connectors fit, go ahead and use the cables you have.
Jul 15, 2008 | Quasar SP-3235 32" TV
Akai LCT2060 Television Logo
140 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
