Question about Crosley 0187SST Turntable
When playing 45's the turntable stops before the song is over. Can the automatic stop be reset to let it finish the 45's?
  • 1 more comment
  • jschaper113
    jschaper113 Jan 03, 2013
    I have a different model but the exact same problem. Please someone answer this question so I can figure out how to fix it.
  • adlksjf Jul 21, 2013
    Same Problem
  • rushzzz2112 Sep 28, 2013
    On my Derens turntable radio I had the same problem but fixed it by removing the turntable out of it`s box an looking underneath at the swivel point of the tone arm. There is a screw which you just tighten and the problem is solved. There are a couple of srews but you will soon decide on the right one.
Jukebox AMI 80 made in 1955 turn table will not stop turning
Could be a defective switch. It there is a switch it would have been intended to open after the record returned.
Sep 22, 2016 | Audio Players & Recorders
The tone-arm on my turntable automatically stops too early. Is there any way to fix this?
Yes. you need to set the travel on your arm. I don't know your specific model but they are all the same concept. On the back by the pivot point there should be a small screw that you can adjust the travel before it returns.
Dec 31, 2015 | Audio Players & Recorders
Record player repair
The top arm that swings over the spindle will control the automatic return. Leave the unit off. Swing the overhead holding top arm over and manually load a record. Now switch the top arm over the niddle spindle. Make sure that the switch is set for 7", 10" or 12" (45, 78, or 33). Manually place the tonearm at the start of the record and flip switch to 'play' (not reject or auto). It should play the whole record and automatically eject at the end and then shut off. Leave the arm swung over the middle after you loaded the record. Good luck. Let me know if you have any more questions.
Aug 18, 2014 | Audio Players & Recorders
User manual
try http://www.manualsdrive.com
Jan 17, 2014 | Bush RPA 1 Turntable
Rca lab 1200
This is a belt drive turntable so it could be the belt slipping about. Before you remove the belt note where it fits.
Dec 25, 2013 | Audio Players & Recorders
My Technics turntable slqdd22 cue and stop buttons not working
Hi, with the tone arm sitting on its mount rotate the platter manually approx. 12 times. That should reset all the auto functions. Cheers john.
Nov 21, 2013 | Audio Players & Recorders
Hi, I've had this turntable for about 10 years. I have moved a few times and this may be the cause. The problem is that the platter starts spinning once the unit is plugged in. It won't stop until its...
I suspect that you might have dislodged some of the mechanical parts in the move. Or something plastic has broken. The only cause of action is to remove the bottom of it and look around it.
Aug 18, 2013 | Sony PS-LX250H Turntable
Got a panasonic compact audio system model # SG-HM09A the turntable plays the record fast
there should be a small switch on the inside of the turn table that allows you to switch from 45 (what i think your listening to) to the normal speed which i think is 33
Jan 25, 2013 | Panasonic Audio Players & Recorders
When I play an Album, it will play say 2 songs then on the 3rd song it will come up 'Finished Recording' it seems to only do this when it feels like it. Thanks Erika
what exactly are you trying to do just play records or dj with this? and what software are you using thats saying finished recording? Are you even Recording anything? please let me know
May 17, 2011 | Numark ttUSB Turntable
Easrly stop
You will have to disengage the mechanical switch off lift. Pretty nice for an automatic turntable.
Keep me posted.
Oct 21, 2007 | Thorens TD-190 Turntable
Crosley 0187SST Turntable Logo
663 people viewed this question
Top Crosley Audio Players & Recorders Experts
 Grubhead
Grubhead
Electro Med Services...
Are you a Crosley Audio Player and Recorder Expert? Answer questions, earn points and help others
