Question about Sewing Machines
Hey, i got a raleigh traditional sewing machine (foot-treding) n i've been using it fine for three weeks and one day suddenly it wont sew nicely anymore.. the needle moves up and down but the stiches won appear n it's not sewing the cloth down..n if i try the sew it super fast, it works SOMETIMES but the stiches starts half inch frm the starting point and it stops stiching if u go at a slow speed
RickE1
  • 202 Answers
SOURCE: My machine stiches automatically when turned on! Help
It could be because there is a wire pinched in the covers to look for or a bad L-print circuit board BUT... Because the foot pedal is not jammed does not mean it isn't working correctly. Inside the foot pedal are two big springs that lift up what is called a carbon pin housing (that has a hook that attaches to the top of the footcontrol)that has carbon contacts attached to it. When these are lifted up the machine is stopped. When you press the footcontrol down it presses the contacts down and speeds up the machine. So somehow this carbon pin housing hook has become disengaged from the footcontrol and the contacts are sitting at the bottom allowing your machine to start at full speed. If your not afraid to fix this yourself heres what you do... 1. With a small screwdriver go through the tiny hole on the bottom of the foot control and adjust the potentiometer. (the potentiometer will only turn 3/4 of a revolution.) 2. Hold the foot control while removing the 4 screws and the two bridges. 3. Carefully release the housing (spring pressure) but do not pull the housing apart. 4. The top and bottom cover are connected by a hook. (if its not broken off) I think this is your problem since most likely the hook has become unattached. At this point though it would be good for you to clean the strips that the 2 carbon pins slide on with a q-tip and remove old carbon residue. Check to make sure the 2 little black carbon pins are not broken. (if they were the machine would not run at all). Be careful not to hurt the carbon pins) 5. To put this back togeather properly... insert the carbon pin housing into the bottom housing of the foot control (if you took it completely out). 6. Insert the two springs 7. Insert the top cover and hold it down while installing the 2 bridges with the 4 screws. to connect the hook follow the rest of the procedure... 8. Press the bottom and top togeather until 2 loud "clacks" can be heard. The clacks indicate that the hook engaged into the latch. 9. Now operate the footcontrol several times by hand up and down. It must be possible to hear clearly the soft clicking of the micro switch. If the clicking of the micro switch cannot be heard repeat step 1. Good luck. Your only next step will be to bring it to a tech or get a new footcontrol. (spendy) Rick.
Posted on Aug 27, 2007
akylas
  • 26 Answers
SOURCE: Juki blindstitch machine; model CM 636; needle sizes? and would it cause skipping?
If the problem started after you changed the needle size, may be,
otherwise, check your needle/looper timing, and distance between needle and looper.
Posted on Jun 09, 2008
SOURCE: sewing stops
I sprayed air into the bobbin area - it just needed a cleaning.
Posted on Nov 23, 2008
  • 323 Answers
SOURCE: L-344 loose stiching
You need to do a tension assembly test. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Tension assembly test. To do this test. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test, adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.)
If it doesn’t work this way then you probably have a piece of thread or lint stuck inside the tension discs. To remove it, turn the tension to 0 zero and raise the presser foot.Using a small screwdriver, open the space between the discs and spray with canned or compressed air. The stuff should come out. Do the tension test again to make sure you got everything and then try sewing again.
sewman7
Posted on Dec 24, 2008
SOURCE: how to adjust the stich lenght on a juki ddl 553 strite stich.
press the black button while moving the side
Posted on Jan 25, 2009
How to fix a pressure foot lifter on a singer tradition
You can get a replacement Lifter from Sewing Parts Online here:
http://www.sewingpartsonline.com/presser-bar-lifter-singer-v880153000.aspx
Most likely, the screw end on the machine has broken off.
Jan 18, 2016 | Singer 2250 Tradition
Globe 877
try to open foot control after turning off power , its foot control switch problem , it stuck internally , its simple problem try it
Apr 12, 2014 | Sewing Machines
Cant get machine to embroider
there are three positions the presser foot can sit in. Up and down are the same on any machine. The 7570 has an in-between position for embroidery. Lift the presser foot and the lower it slowly while pushing gently. It should stop about half way down. The embroidery foot pushes the foot into the down position with each stitch allowing the fabric to move easily to the next stitch.
Jan 29, 2013 | PfaFF Creative 7570
The light comes on but there is no power to the sewing machine
it's possible that the motor went out or the foot pedal could have
gone out.
it would be a good idea to have the machine checked at a sewing
machine shop
Aug 19, 2012 | Singer Sewing Machines
I am sewing a zip into a waterproof jacket and it's not feeding through the machine properly
That sounds pretty heavy for your machine... yes try your walking foot attachment AND a longer stitch
Jul 10, 2012 | Janome Sewing Machines
Silvercrest overlocker - the 'red' pathway thread won't progress through
have you tried changing the needle?
since you've only had the machine for a week, I'd suggest taking it back & getting another machine.
Mar 26, 2012 | Sewing Machines
We have lost the extra manual for the necchi 6022 sewing machine. It had the instructions on how to create designs and what settings to use when using the serger foot in stretching/elastic material. I...
I'm a bit confused, this isn't a serger machine as far as I can see. So do you mean an overcasting foot where you sew a XXXXX type stitch along the edge of the fabric? The overcasting foot just helps you to line up the fabric edge and sew over it neatly.
if you go to this page http://www.sewingpartsonline.com/necchi-6022-sewing-machine-parts.aspx
there is an instruction manual for sale.
http://sewmamasew.com/blog2/2009/06/feet-feet-feet/ is also a great resouce on sewing machine feet with good photos of what they are used for.
Here is a video of overcasting foot in action http://www.sewingmachine-sales.co.uk/sewing_machine_info/video/34/adjustable-overcast-foot.html
If you are wanting to sew knit fabric then you just need to use a small zig zag stitch and a ball point needle to put elasticity into the seam. Or your model may have a stretch stitch, where the fabric is moved forwards and backwards during the stitch formation to add some elasticity.
Sewing elastic stretched onto fabric is a bit different with a SM, can be fiddly and hard to keep everything lined up nicely and stretched. Some machines have a little device which clips onto the needle plate in front of the needle that you can feed elastic through and tighten it to tension it, then just use a three step zig zag stitch to seam over this onto your fabric. But I don't know if Necchi has such a thing, your needle plate would need holes in front for it to clip into. Elna had these on their swiss machines in the 80's but haven't seen a similar device for a while.
Hope I've answered your question and not completely misunderstood your problem. Purchasing a manual is often the best way forward when a machine is unfamilar. Or www.sewing.about.com is great resource.
Jun 06, 2011 | Necchi 6022 Sewing Machine
Light is on but won't sew
Sounds like either the foot control or the motor has failed. The foot control is the easiest to replace, you should be buy a replacement control for about 30.00.
May 25, 2010 | Janome Harmony 9102D Mechanical Sewing...
BOBBIN THREAD
omyGod!! Thank you sooo much!!! I changed the tension on the top of the machine, like you said and now, it is working beautifully, God bless You!!!
sandylou
Dec 08, 2007 | Sewing Machines
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
