Question about Stinger Streamlight 75000
Switch replacement instructions
How do I get the switch out. I have removed the tail cap, lens and batt, removed the charging screws (2) I have a long rod pushing from the Batt side toward the lens.while I am pressing the switch in.
  • 19 Answers
You have to push the light down from the long rod you have there while compressing the two grids with a needle nose plier. The switch should be able to slide right out that is if it's a black switch. However...if you have the older version of the switch module that either has a clear/beige switch or clear beige/cream switch you need to bang that ****** out. Try not to hurt yourself because this can get a little tougher and may take a couple of practice to actually get that switch out. If all else fails send it back to Streamlight repair department. It's covered under lifetime warranty you know ;) www.streamlight.com follow the contact section and the addy's there. goodluck
Posted on Aug 28, 2009
How to install evo 5 tail lights
check see tail light lens has 4 screws holding it in place.if so remove 4 screws then remove rear tail light lens then replace tail light bulbs.if you have trouble replacing tail light bulbs the auto parts store sales person will help you free of charge and help you replace bulbs.i have seen auto parts stores sales person help people replace batteries,windshield wiper blades and light bulbs in vechicle if you have trouble fixin it your self.
Feb 06, 2012 | 1998 Mitsubishi Lancer
How do I remove the bulb from left rear tail light lens?
Simple.. open the hatch. You'll see 2 screws on the inside of the lens, remove them. Now pull the lens assembly out slowly. No need to remove the wire connector. You'll see 3 caps, simply twist the one containing the bulb you need to replace. Reverse order for re-installation.
Feb 20, 2011 | 2000 Jeep Grand Cherokee
How do i replace a 2006 A6 rear light. I crashed into a wall in the ice and it broke the plastic. I have a full replacement unit.
Rear iignts in rear na, removing and instaiiing
Fig. 325: Rear Lights In Rear Lid, Removing And Installing
Courtesy of VOLKSWAGEN UNITED STATES, INC.
Removing
CAUTiON: • Switch off all electrical components.
. . Switch ignition off and remove ignition key.
o Turn light switch into "0" position.
o Open cap - 1 - for warning triangle.
o Rotate quick-release screw - 2 - counter-clockwise 90 C and remove cover - 3 - from luggage compartment lining - direction of arrow -
Fig. 326: Removing Bulb Socket From Housing, Pressing Catch Bracket Downward
o Disconnect electrical harness connector
o Remove bulb socket - 1 - from housing, press catch bracket - 2 - downward - arrow - to do so
Fig. 327: Identifying Nuts, Clamping Bracket, Inner Tail Lamp, And Clamp Mounting
o Unscrew nut - 2 - and remove clamping bracket - 1 -
o Remove nut - 4 - and remove inner tail lamp - 3 - toward outside
o Remove clamp mounting - 5 - from body cut-out
Fig. 328: Identifying Clamp Mounting, Nuts, Inner Tail Lamp, And Tabs
Installing
Installation is the reverse of removal, noting the following:
NOTE: • Make sure seal between body and tail lamp housing seals properly.
. Attach clamp mounting -2 - at inner tail lamp and screw on nut -3 - loosely.
. Attach inner tail lamp -4 - at body cut-out and make sure grip tabs - arrows - of clamp mounting rest against body cut-out
. Slide clamp mounting - 1 - onto threaded pin of inner tail lamp and tighten nuts - 3 - and -5 -.
Jan 19, 2011 | 2006 Audi A6
2008 Jeep Grand Cherokee - My tail light lens covers seem to be loose. When you open the rear deck, you can see two black plastic caps where I think there are screws behind them to tighten the actual lens...
those are not really screws. they are a "one time" clip which hold the lighs in place. I just went theu the same issue. I pull the caps with needlenose pliers, and cannot reuse the. Went to the jeep dealers and purchased 2 new ones at 5 euro (am in germany) a piece. so, I went to the hardware store and purchased 2 flat head screws and it works much better.
Oct 30, 2010 | 2008 Jeep Grand Cherokee
Having trouble fixing brake lights
Tail/Turn Signal Lamp Removal & Installation Cab/Chassis gm-06-00-1071.gif
To Remove:
  1. Disconnect lamp assembly electrical connector.
  2. Remove nuts and lamp assembly from bracket.
  3. Remove lens screws.
  4. Remove lens, gasket and bulb.
To Install:
  1. Install lamp assembly and nuts to bracket.
  2. Connect electrical connector.
  3. Install bulb, gasket and lens.
  4. Install lens screws.
Except Cab/Chassis gm-06-00-1075.gif
To Remove:
  1. Lower endgate.
  2. Remove 2 tail/turn signal lamp assembly retaining screws.
  3. Rotate tail/turn signal lamp assembly and remove from vehicle.
  4. Disconnect lamp assembly electrical connector.
  5. Remove bulbs by pulling straight out of bases.
To Install:
  1. Install bulbs by pushing straight into bases.
  3. Install tail/turn signal lamp assembly to vehicle and secure with 2 screws.
Oct 13, 2010 | 1997 GMC Sierra
How do I replace a burned out backup light on a 1998 cheverolet silverado c-1500 pickup truck?
To Remove:
To Install:
To Remove:
  1. Lower endgate.
To Install:
Jul 17, 2010 | 1998 Chevrolet C1500
How to change rear tail light on 2006 honda odyssey
Lift the rear door, remove the rear tail light lense, replace the bulb and replace the tail light on the car.... once the screws have been removed, be sure all of them are removed,,, the lens/light cover may have to be pried off with a flat blade screw driver.... place a folded paper towel of something else to protect the paint.... before prying...... Check the owners manual for instructions.
May 13, 2010 | 2006 Honda Odyssey
Replace batt on NcStar Scope 3-9x42E
The battery on lighted reticle scopes is located underneath a screw off cap on the rheostat switch usually on the ocular lens housing. Hold the base of the switch with one hand and unscrew the cap with a coin. Replace the battery with a CR2032 button type battery (this is the most common battery size for these)
Hope this helps, Mark the Gunsmith
Please leave feedback.
Jan 13, 2010 | Optics
How do I replace a tail light lens on a 2004 dodge caravan
have to replace tail light asm, open hatch remove 2 clips or screws they might have either,and gentle pull out and remove connector.good luck.
Oct 10, 2009 | 2004 Dodge Caravan
Stinger Streamlight 75000 Logo
3,827 people viewed this question
Top Stinger Camping, Backpacking & Hiking Experts
Shehu Pro
Shehu Pro
Are you a Stinger Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
