Question about GE RM24912 Universal Remote Control
I have a Philips tv an older one an i have sudden link and my remote will not let me use my cable channels
  • 44 Answers
Hi - My name is Tina and I am with Suddenlink. I'd like to help you solve the issue with your remote, but I'm afraid I don't have enough information to investigate. I would suggest you contact our Customer Service department, as they will be able to troubleshoot and get your issue resolved. They can be reached at 1-888-822-5151.
Posted on Jan 03, 2011
42pf5321d/37 wont find cable channels
Check and replace its tuner. If you wish to get some details; check the site linked here. Pull up older posts.
Jul 17, 2016 | Philips Televison & Video
How do i manually program my channels on older tv without a remote
Nothing you can do without the original remote. One cannot get into the setup pages. Replacement remotes usually don't work on this point either. They are missing this special setup button. In order to watch DVD, VCR, connect them with a SCART cable. When you switch on the player, the TV will detect this and go automaticaly to this input. If connected with RCA plugs, you can choose the input with the program Up/Dwn buttons on the TV set itself, going "lower" than channel 1.
Jan 04, 2014 | Philips Magnavox 20MT133S 20" TV
Innovage jumbo remote controls channels on cable box but nothing on tv
You should set the remote control with your TV too, with the setup code to your TV brand. Find it from the remote control's code list, and set it up with. For more information check this link. Setup procedure, and setup code list to many popular remote controls are given. Pull up older posts.
Dec 10, 2013 | Innovage Jumbo Remote Control
I got a free tv from a hotel, it has no remote. Can I use a universal remote to add channels to the tv? It only goes to channel 69. Also, can I plug in a dvd player? I can't find anywhere on the tv to plug...
Often these commercial TV's are just vanilla types catering for TV alone. The43 cable channel is possibly the only other alternative that is a money maker for the motel/hotel. They try and prevent people from connecting their own DVD players to their equipment so they are the ones who make the $$.
It is possible to use a Universal remote providing it is capable of being controlled by a remote.
Philips code is 0054 , you can only try!
Please rate my help++++Thanks for using FIXYA
Nov 21, 2009 | Philips Magnavox 27MS343S 27" TV
I have installed a Digitalstream DTX9950 converter box with my TV attached to a rooftop antenna. I can turn the TV off and on with the DTX9950 remote, but I can't bring in any stations, other than the DT...
Are you using the coaxial cable to connect the converter box to the set, or have you hooked it up with rca type video cables? The latter are highly recommended if you want a better connection and have audio/video inputs on the back of your television. But you don't want both A/V & coaxial.
Also be aware that some older antennae will not pick up digital signals well. Try to use a coaxial cable all the way up to the antenna junction. Find out where most signals are broadcast from in your area and aim the antennae appropriately. (Use a compass.) See helpful link here. Your converter remote should have a signal strength button that you can use to check the various channel strengths. If you're using a coaxial link to the tv and have little signal strength, expect a poor picture. You'll also want to select the Mono option for Audio Output in the converter menu.
Finally, depending on the age of your set, if you're using rca video inputs, use the TV/Video button or the AV button on the TV or universal remote to switch the input from the channel on your TV to the video 1 setting (or whatever picks up the digital converter signal) so you'll get that clear signal. Then you can use the converter remote to change channels, adjust volume, etc.
Jun 14, 2009 | Philips Magnavox 20MT133S 20" TV
Can only get channels 1-13,can't get the cable channels
Press Menu
Scroll right to TUN (Tuner)
Scroll down to TV/CABLE
Toggle from TV to Tuner
Problem Solved
Feb 15, 2009 | Philips Magnavox 27MS343S 27" TV
Philips LCD 17PF8946/37 TV not working
The good news is that the "No Input Signal" message means that your TV is not broken. If you are trying to watch cable, then you have simply turned the TV to the wrong input channel. If your cable comes into the Philips using a coaxial cable wire, use the Philips remote to change the channel to Ch.3 or 4 - whichever channel you normally watch cable on. Make sure the cable box is turned on if you have a cable box. If the cable box connects to the TV using another type of wire, use the Ch+/- on the Philips remote and go through all the AV channels until you find the right one. Good luck! Let me know if you need additional help.
-Tha Mp3 Doctor
Dec 30, 2008 | Philips 17PF8946 17 in. HDTV-Ready LCD...
Unable to select channels using the unit
First, test to make sure the Philips remote is working by trying to play a dvd. If the remote control is working, then either A) your TV is set to the wrong channel, or B) you have not selected the correct source on the Philips remote.
Look at how the cables run from the back of the Philips to the TV. In the back of your TV, the slot that the cables are plugged in to is usually labelled "AV1, "AV2, "Video 1", "Input 1" or something like that. Change the television to the appropriate input/source channel.
Press the Source button on the Philips remote and make sure it says E1 or whatever the appropriate source is.
Then try changing channels using the Philips remote.
This does not exhaust every possibility, but you must check the above first to see if anything else might be wrong. If the above does not work, then I would double-check to make sure the cable/satellite box is connected to the Philips correctly.
-Tha Mp3 Doctor
Dec 25, 2008 | Philips DVDR3576H DVD Recorder
My tv channels dont work
Did you follow the suggestion to rescan your channels in the setup?
Nov 19, 2008 | Philips Magnavox 27MS343S 27" TV
19 INCH OLDER MOEL
Hello.
You did not say if you were using cable or antenna. If cable, you need to use the remote that came with the TV. Get into the menu and look for channel setup or an equivalent heading. in one of your menu schemes will be a selection fot ant. or cable. Select cable and the other channels will magically apear when you exit the menu option.
Good luck.
Oct 17, 2007 | Philips Magnavox 27MS343S 27" TV
Televison & Video Logo
Top GE Televison & Video Experts
Computer Repairing
Computer Repairing
Are you a GE Televison and Video Expert? Answer questions, earn points and help others
