I have a pro heater 50,000 to 80,000 Model # A661767 propane, and when I try to light it it comes on with the button held in but when I let go of the button after one minute it goes out and will not stay lit.
  • 674 Answers
It sounds like you have a thermocouple problem. Locate the thermocouple and make sure it is in the flame while the pilot is lit. If the pilot flame is weak, try to correct. Some pilots have a small air hole in the tip a short distance back from the flame that can get clogged with dust. Some don't have this hole. Your thermocouple may just need to be cleaned. This can be accomplished with some fine steelwool or emory cloth. Let me know if you have any questions.
Posted on Jan 02, 2011
Cannot get it too light
PDF]operating instructions and owner's manual - Rural King
www.ruralking.com/.../MH9BX_Portable_Propane_Heater_Manual.pdf
light, adjust or operate the heater. PORTABLE PROPANE HEATER FOR RECREATIONAL AND COMMERCIAL USE. MH9BX. Model #. 02/09 32030. MR.HEATER, INC., 4560 W. 160TH ST., ... Get fresh air at once! Have heater serviced. speciFicatiOns. MODEL NO. .... Some people cannot smell well. .... Buddy series hose.
Mr. Heater Portable Buddy Propane Heater - Bass Pro Shops
www.basspro.com/...Heater-Portable-Buddy-Propane-Hea...
Bass Pro Shops
Feb 03, 2016 | Mr Heater Base Camp Portable Buddy Propane...
Propane torpedo lights but doesnt stay lit
I'm confused. First you listed this as a propane torpedo heater. Second, it's a problem with and All Pro PK115 T Forced Air Kerosene Space Heater. And finally, you say "propane torpedo lights but doesn't stay lit."
Which is it? To really help you, I'll need the correct manufacturer's name & model number. And whether it's propane or kerosene fired?
Thanks.
Mar 02, 2011 | All-Pro Kerosene Garage Shop Heaters - All...
I open the tank but when I try to start the heater it runs for a second and then goes out as if it wasn't getting any propane.
check the flame sencor
is clean and in postion pressureswitch could be blocked , try jumping out pressure switch see if it lights , check tank is full ,
Jan 09, 2011 | All-Pro Propane Garage Shop Heaters - All...
I 50,000-85,000 All Pro Propane heater release red button fireout
If the red button has to be held down for a period of time to get the heater going it overrides the shutoff mechanism. If you are holding it the prescibed amount of time then either the hydraulic system which keeps your unit running is bad or out of place or the metering valve is bad. Check for a copper line with a bulb on the end. It should probably be in the fire created by the heater, if not bend it to be in the heat or very close. If this is ok then you may need to get a new burner for the unit which would probably mean buying an entire new unit as the cost would probably exceed the cost of a new unit. Let me know how you make out.
hardrocko
Feb 07, 2010 | All-Pro Propane Garage Shop Heaters - All...
Heater won't stay lit after releasing yellow button
you need to replace the thermocouple at the burner tip it will be a copper line with a bulb in the flame tip with a copper tube leading back to the gas valve and it senses the flame and keeps the gas valve open
Dec 24, 2009 | All-Pro Propane Garage Shop Heaters - All...
Where can i find a parts breakdown for this heater spc-85
I plug a Thermostat in The power line to break the power when at temp. Once I start the heater using the reset button,when temp is reached and the themo calls for heat just the blower comes on only. I have a All Pro propane 50,000 to 85,000 btu heater thanks Ron
Nov 21, 2009 | All-Pro Propane Garage Shop Heaters - All...
The gas does not light
get a new unit dont play with propane it goes bang!!
Oct 31, 2009 | Reddy Heater RLP100 Portable Forced Air...
SPC-12 SPACE HEATER WON'T STAY LIT?
When holding button in,you are overiding themocouple funtion. You probably need to replace the thermocouple
Feb 27, 2009 | All-Pro Propane Garage Shop Heaters - All...
Heating & Cooling Logo
49 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
