Question about Alpine RUE-4202 Remote Control
Remote will not work. Tried new batteries. What is A.PROC. Button?
My console seems to be working, but the remote will not work. I have changed batteries, bought a new remote, tried unplugging everything and nothing happens. What else can i do?
Have you tried syncing the remotes? Open the SD cover slot on the front of the system you will see a red sync button. Then remove the battery cover to the remote and you should also see a red button. Turn on the Wii and then press the red button on the system. Then press the red button on the controller and see if that works.
Jun 30, 2011 | Nintendo Wii Console
Tv Remote stop working already tried new batteries, also tried programing univers remote can't find electron so I tried curtis mathis codes and still can't program remote one work but would not turn of or...
This only takes about a minute and will restart 1 in 3 "Dead" Original Remote Controls.
Step 1- Pull the batteries out of the remote and leave them out until Step 4.
Step 2- Press and release each and every button one at a time on the remote control until every button has been pressed and released at least once!
Step 3- If your remote has slide switches, you must move the switch to
each position then repeat the button pushing in Step 2.
(When you're done, be sure to put the slide switch in the correct position to operate the unit the remote came with!)
Step 4- Put the batteries back into the remote, being very careful to install them correctly.
New batteries should be used if you're not sure about the old ones.
Step 5- Try the remote.
Special Note:
If you have a digital camera, camcorder or camera phone you can test the remote to see if it is emitting a signal. Face the remote towards the lens of the digital unit until you can see the front of the remote. Depress any button on the remote. You should see a light (steady, blink or flashing) being emitted from the remote.
If you do then the problem might not be the remote but the sensor on the set.
Feb 28, 2011 | Televison & Video
My Viper 791xv remote isn't receiving the page information from the unit in the car. When I press the unlock, lock, or remote start button, it works, but then the remote beeps as if it didn't work (3 sets...
My battery ran low and I jump started my car which some how caused the problem. My viper technician made me a buy new remote but the problem continued even with the new remote.
Try disconnecting the battery of your car for ten minutes and then reconnecting it. It worked for me. Now i have a extra remote which i don't need.
Oct 12, 2009 | 791XV The 791XV is a 2-way Security and...
I lost my player 1 wii remote my others don't work.what do i do
open the battery cover on the wii remote you want to make player 1 press the red button while it is facing the sensor bar. Then open the memory card door on the front of the wii and press the red button on the top. the remote should flash a few times then it will be your new player 1 remote. You can only do this if you have 2 AA batteries in the remote. It will not work with the rechatgeable batterie packs because the remote must have power while you re-synch it.
Jun 10, 2009 | Nintendo Wii Console
What is the a.proc button on a rue 4187 remote control used for
To access an audio processor if one has been installed.
Apr 15, 2009 | Alpine CDA-7876RB CD Player
Controler will not turn channels
If you still have the manual that came with remote, reprogram the remote for your receiver. The RC32 is has had some issues because of all the new Directv components available
Jan 05, 2009 | Directv RC32RFK Remote Control
Wii controller not working
Have you tried syncing the new remotes. There is a little red button where the battery is and then there is a little red button on the console. Hit the button on the remote and then hit the button on the console. It should work after that.
Jun 30, 2008 | Nintendo Wii Console
Televison & Video Logo
Top Alpine Televison & Video Experts
Vernon Taylor
ray gallant
Are you an Alpine Televison and Video Expert? Answer questions, earn points and help others
