Question about Cub Cadet Garden
2006 cub cadet m60 tank trouble starting ever since new.problem seems to just get worse ,mower has less than 400hrs. murrays do better than this .HELP!!!
5 Suggested Answers
  • 62 Answers
SOURCE: Z force 48 in. cub Cadet mower starts but dies
Check the wires to the seat switch. Under the seat you should find 2 wires connected to the seat. Unplug them, and use a jumper on the end that goes into the body of the mower. Try it again, and if it works, replace your seat.
Posted on Apr 18, 2009
  • 323 Answers
SOURCE: install belt on cub cadet mower
First, make sure you have the model number and serial number (located under the seat) and then go to www.cubcadet.com to get a belt diagram so you know which way the belt snakes through the pulleys.
You will have to remove the two pulley covers on either side of the deck.
Fit the belt around the right side of the deck pulleys when you are on the left. There is an arm attached to the springed pulley on the left side. It will have a hole the size of a 3/8" driver/ratchet. Set the ratchet on unscrew (to the left) and push the arm in toward the center of the mower. You will see the pulley moving too, creating enough slack to slip the belt over the edge of the rim of the pulley with a little elbow grease. If it is too tight, get someone to push in with the ratchet while you slip it on. Once again, you are the grass cutter king!
Posted on Jul 25, 2009
Dolfoff
  • 148 Answers
SOURCE: CUB CADET ZERO TURN Z-FORCE 3-BLADE CONFIGURATION
Under each blade is one single nut holding each blade on. It is not left-hand thread and there is nothing special about it.
Standard thread - Standard hardware - Standard tools. (If memory serves, you need a 15/16" socket to remove these.)
There is no need to index or time the blades. They cannot hit together unless something is bent or damaged on your mower deck.
Hope this helps,
Dolf-
Posted on Oct 15, 2009
  • 13 Answers
SOURCE: I have a cub cadet rzt50 mower...Need to replace a tire
There is a thru bolt, and inside and outside bushing, and center sleeve. Remove those to remove the wheel. Obviously support the frame on a jack. Most tires can be removed using a slight soapy solution and 2 smooth screwdrivers. Replacement, use a soapy solution around the bead, and using only hand pressure put the tire back on. Use a cinch strap around the center of the tire to help keep the tire beads against the rim and air it back up.
Posted on Apr 16, 2010
My 04 cub cadet m60 tank with a 27hp Koehler just up and quits after 20 min. I just changed oil and filter and "change oil " is blinking. Help
I'm not a Cub dealer but the "change oil" light should reset itself after usually an hour of use. check the oil level for the no start. if it has an oil level switch and is low, there will be no spark.
Jun 01, 2016 | Cub Cadet Garden
Is there a way to test a fuel pump on a Cub Cadet M60-KH (53BB5BDX750)
Those pumps are cheap enough on ebay. Take yours apart and clean the diaphram and the valves to make it work better.
Aug 19, 2014 | Cub Cadet Garden
Kohler engine command pro 27 hp not start cub cadet m60 tank
spray some starting fluid in carb if starts ether bad feul filter or fuel pump or need to rebuild carb
Jul 23, 2014 | Cub Cadet Garden
Need valve adjustment specs for 25 hp kawasaki
sometimes it is better to have more clearance than not enough
Jun 16, 2013 | Cub Cadet Tank Riding Mower M60-KW-LC
Cub Cadet ZTR M60, left transmission slipping.
mostly all lawn equipment gear axles & engines run on sae 30 weight oil & it should be 1/2 to 3/4 full unless told other wise
Jun 05, 2009 | Garden
My cub cadet zero turn mower won't engage the blades with the switch.
I have a cub cadet zero turn z force 48 yesterday i was cutting lawn and i heard a clink, the mower stopped, i was ablet o start the mower again but when i pulled the pto knob to engage the blades the mower turns off by its self, when the pto lever is pulled up i can restart the mower what is causing this and how do i fix it
May 09, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Garden Logo
287 people viewed this question
Top Cub Cadet Garden Experts
Tim Whalen
DarkfireVA
Level 1 Expert
Matt Olenzek
Matt Olenzek
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
