Question about Systemax (036052) PC Desktop
For some reason I can only search the internet in safe mode. When in normal mode it says I am connected when I try to search it says network link interrupted or cannot find server. I did a ping in cmd it came back good no loss and ipconfig recognized ip address. I tried everything but I have no disk and I'm trying to get my computer back to factory settings and systemax they want to charge 39.95 to even speak to them pls help
  • Systemax Master
  • 3,592 Answers
Try resetting the tcp/ip stack in your version of windows
https://support.microsoft.com/en-au/help/299357/how-to-reset-tcp-ip-by-using-the-netshell-utility
Posted on Jul 11, 2017
4 Suggested Answers
SOURCE: systemax aol optimized pc model SYX-651M03
you most likely have one that is in the motherboard.
I simply installed a new network card
Posted on Oct 07, 2008
SOURCE: Systemax factory restore - how?
Tap F4 repeatedly to launch the recovery console on SystemMax Machines with the recovery partition still intact. Then you should be able to restore the machine to factory defaults without a CD.
Posted on Sep 25, 2009
jaisonthomas
  • 356 Answers
SOURCE: Good afternoon..I was hoping you
you need to reinstall yourwindows. this may caused due to your operating system has corrupted or crashed
Posted on Sep 01, 2011
HOW can desktop be rebooted& I don't know which reboot option to choice
There are a few reboot options. The first reboot is to start a pc normally. The second is Safe mode. Another is Safe mode with Networking. and another is Safe mode with command prompt. Use Safe Mode to do minor adjustments or repairs, or virus scans while connected with the Internet with Networking option. DO not use Safe mode with command prompt unless you know what you are doing!
Apr 10, 2017 | Option Computers & Internet
Tip
HOW TO CONNECT - INVALID IP ADDRESS - 169.254 ..IN VISTA
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
Remember 196.254.x.x mostly we call bad ip address in fact this is not a bad ip address, The INTERNET ASSIGNED NUMBER AUTHORITY(IANA) has reserved the private ip address in the range of 169.254.0.0 to 169.254.255.255 for automatic private addressing. So this addresses are not found on internet. That is the reason we cannot go online with this ip addresses normally.
TRY FOLLOWING STEPS
  • Power cycle the system
  • Make the BIOS default
  • Check in Safe Mode with networking it the computer is going online,Try system restore if computer was going online before
  • Release and Renew the IP address
  • Turn off the firewall (Click on start >Type Windows Firewall inthe instant search box>Click on Windows Firewall>Click Off on the Windows Firewall Screen>Click OK>Restartthe computer)
Run Network Diagnostics
Click on Start> Type Network in theinstant search box> Click on Network and Sharing Center> Click on Diagnoseand Repair on the right hand side
Reinstall Network Card
Go to device manager> UnderNetwork Adapters, right click on the network card> Clickon Uninstall> Restartthe computer
Disable any Wireless Card
Go to device manager> Under Network Adapters, right click on the Wireless Card> Click on Disable> Restart the computer
Disable IPV6 ADDRESS
Click on start> Type Network in the instant search box>Click on Network and Sharing Center> Click on Manage Network Connections> Right Click on Local Area Connection> Click on Properties> Uncheck Internet Protocol Version 6 (Ipv6)> Click OK> Restart the computer
RESET WINSOCK AND TCP/IP STACK
Click on run>type cmd>press enter>on the black screen type the following commands.
netsh winsock reset> netsh int ip reset log.txt> Restart the computer
Create a new connection Manually
Click on start> Type Network in the instant search box> Click on Network and Sharing Center> Click on Set up a connection or network> Select Connect to Internet and then click Next> Select No, Create a new connection and click Next> Click on Broadband> Type ISP User name and Password, Type the Connection Name then click on Connect
STILL IT IS NOT GOING ON LINE NEED TO PULL THE COMPUTER TO THE FACTORY DEFAULT SETTING
***(NOTE:- YOU WILL BE LOOSING ALL THE DATA FROM THE HARD DRIVE)
on Sep 30, 2010 | Computers & Internet
Why does my laptop lose Homegroup connection every few minutes then reconnects? the other computer in the Homegroup however does not lose connection. I am using windows 7 home premium.
Method 1:
Step 1: Start your computer in safe mode with networking and check the functionality.
Starts Windows in safe mode and includes the network drivers and services needed to access the Internet or other computers on your network.
Advanced startup options (including safe mode)
http://windows.microsoft.com/en-US/windows7/Advanced-startup-options-including-safe-mode
If it works fine in safe mode with networking, perform clean boot to find the root cause.
Step 2: If it works fine in safe mode with networking, perform clean boot to find the root cause.
To help troubleshoot error messages and other issues, you can start Windows Vista or Windows 7 by using a minimal set of drivers and startup programs. This kind of startup is known as a "clean boot." A clean boot helps eliminate software conflicts.
http://support.microsoft.com/kb/929135
NOTE: After you check the functionality in clean boot configure Windows to use Normal startup using the step 7 suggested in the link mentioned above.
Note: Do Not disable wireless services, if any.
Method 2:
You may try the steps from the following link and check:
How to reset Internet Protocol (TCP/IP)
http://support.microsoft.com/kb/299357
Oct 12, 2014 | Computers & Internet
When i open my laptop ( toshiba satellite pro 4600 ) suddenly off in low battery. After charge when i open it saw massage in display (safe mode, safe mode with networking, safe mode with command prompt,...
When the System comes back on in Safe Mode, all unnecessary utilities are shut down or do not work, such as your speakers or the sound. If you open Safe Mode with Networking, than you are connected to a Network, but you still can only do a few tasks that Safe Mode allows. After you restart your computer and run it normally, than all functions will return to their normal operations, including your speakers and sound.
Oct 23, 2017 | Computers & Internet
My laptop only connects to the internet in safe mode
Boot into safe mode with networking. Download malware-bytes Run a full malware scan, remove any malware and reboot into normal mode. This may have fixed the issue. Failing this download super anti spyware and do the same with that tool. If both these tools come back virus free / do not fix the issue click on start, run. Type 'msconfig' into the box, hit enter. Half the startup items and reboot into normal mode. If you can access the Internet the software causing the problem is in the half of the startup items not running. Keep halving this half until you find the suspect software and remove it. ( no matter how big the number of startup items it will always take the same amount if halfing to narrow it down to one.
Apr 17, 2013 | HP Compaq Presario V2000 Notebook
My internet keeps connecting and disconnecting whenever I try and get online?
Thank you for posting your question here.
I suggest that you go to safe mode with networking to test your internet connection there. Safe mode is the basic operating system interface of your computer thus disabling any advance softwares which might be affecting your connection now.
To go to safe mode, do the following:
Restart your computer and keep tapping F8 until you see the options to go to "Safe Mode with Networking".
Highlight safe mode with networking by using your arrow keys. Press enter.
Once you are in safe mode, try connecting to your internet and observe if the problem is gone. If internet is good, then there's an update or software change that affected your connection.
You can fix that by doing a system restore. Think about the date when you had no problem with your internet. and do the system restore.
Start > Programs > Accessories > system tools > system restore
Select the date when you had no issue yet and let it restart. Check.
Another possible reason is an outdated network adapter driver. This happens when there are changes in the software. You can update it manually which takes time maybe 15 minutes or more or you can install Radarsync and let it update all the outdated drivers in your computer. You won't have to do anything at all. All driver updates will be taken care of.
Another possible issue is your internet service. If all of the above possible problems are covered with no fix at all, then you better contact your Internet service provider.
I hope this helps!
If you have any questions, please drop me a line and I'll get back to you as soon as I can.
Carlo
Dec 20, 2012 | Samsung Series 3 300E4C - 14" - Core i3...
Keyboard wont work in windows
Why won't it? What is it doing? Maybe the Keyboard is hijacked, had a loose connection or is broken. Try booting up in Safe Mode and see if it works.
Go to www.google.com and in the search box type:"download.cnet.com" (without the quotes). Click the link to goto the site and look on the left side when the site opens up and you will see agray area that says FIND SOFTWARE. In the white search box under FindSoftware type: "Virtual Keyboard" (without the quotes) and click themirror to search. When the search results come back look for FREE VIRTUALKEYBOARD. Download and Install it. It's totally FREE. Alsouncheck anything that pops up other than the license agreement during thedownload and installation. You only want the Free Keyboard and not theother junk.
You can use it to solve your keyboard problem. Just open up whatever it is youwant to type on such as the web address in an browser, a word document, etc.,then open the Free Virtual Keyboard and it will sit on top of whatever you weredoing. You can move it around so that it is not in your way also.
Apr 07, 2012 | Computers & Internet
I just bought the Acer 17.3" Aspire AS7741Z-5731. My problem is that the computer keeps freezing while connecting on the wireless to the internet. The network is set up right. I went into safe mode to...
Connect to the internet router using a patch cable. Goto support pages of Acer and search for an updated driver for the network card. Download and install. Now try again.
Oct 15, 2017 | Acer Aspire AS7741Z5731 Netbook
Internet explorer
Hi
It seems that your computer is infected with a spyware. I will give you some steps to try and resolve this.
Step - ( This will remove spy wares from the computer )
Open this link and download Free superantispyware
http://www.superantispyware.com/
Scan your computer with this and clean it.
If it does not let you download this, you need to try this in the "Safe mode with Networking"
Step to go to "Safe mode with Networking"
Turn off the computer. As soon as you turn it on start tapping the key "F8" untill you get a black screen with options of "Safe mode" and "Safe mode with Networking", select the second one and than log on to the computer.
Your display will be big and distorted in safe mode, dont worry as its a diagnostics mode.
Once downloaded the software you might need to rung the software in normal mode as sometimes this software does not work in the safe mode.
To get back to the normal mode. Simply restart your computer.
Hope this should take care of your issue.
Sammy
Nov 28, 2007 | Acer Extensa 367D Notebook
Systemax (036052) PC Desktop Logo
Top Systemax Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Abhinandan  Patil
Abhinandan Patil
Mike
Are you a Systemax Computer and Internet Expert? Answer questions, earn points and help others
