Question about JVC GR-DVL300 Mini DV Digital Camcorder
JVC Gr-DVL300 Won't playback
Help, my JVC camcorder will not play anything back. It does not seem to recognize tape anylonger. Even old tapes that have worked fine in the past will not playback in hte unit. Any suggestions.
  • 35 Answers
The heads are probably dirty. First you can try to let a tape run through from start to end and see if it cleans the head. then try running in reverse play scan. Next try a head cleaner tape if you have not yet. If these things do not get your picture back you should take it to a repair shop, I do not recomend taking camcorders apart for cleaning at home. Full size VCR's are ok to clean your self with instructions but not camcorders because they are vary easy to damage worse without experiance and proper tools.
Posted on Jul 31, 2008
I lost my cable for my camcorder JVC GR-DVL300. I want to play the mini DV cassettes on it and record them to my computer.
your best bet would be to find a frys electronics around where you live. They have a great selection of different cables for different devices. If that won't work just type in your camcorder model # on ebay and see what comes up. Good luck
Oct 09, 2015 | JVC GR-DVL300 Mini DV Digital Camcorder
How to switch from sp to lp mode when playing back?
Did you try setting the rec mode to SP in the playback menu?
a54f98a.jpg This is from the D250 manual.
Dec 18, 2007 | JVC GR-D250 Mini DV Digital Camcorder
JVC mini Dv GR-D720E has small squares on playback
Indeed it seems that there was a really stubborn bit of dirt on the heads. I had to use the cleaning tape several times to ultimately have a clear picture on record and playback.
thanks again ,but successive cleaning can help for an effective cleaning of the tape path and heads.
Feb 04, 2010 | JVC GR-D73E Mini DV Digital Camcorder
Gr-dvl-520u trying to record or playback tape it goes into safeguard mode within 5 seconds. alternatly pressing play and still every 3 seconds advanced the playback without it going into safeguard mod
According to,
"JVC notes that you are also given a malfunction code when the unit is placed into safeguard. If it displays code 01, 02, or 06 you should remove
the battery and powersupply and wait for a while. Code 03 and 04 indicate that you should eject and reinsert the tape.
If neither of these solutions work, your only alternative is to bring it to a shop or send it to JVC for diagnosis or repair. Unfortunately, there is no other way to clear the condition."
If you are getting E03 or E04 errors on every tape you try, it sounds like a servicing is required.
Apr 17, 2009 | JVC Cybercam GR-DV500US Mini DV Digital...
E04 Error
i had the same problem with my cam JVC GR-DVL309 and i solve it.
Eject the tape, reinsert it BUT while the tape is going down to read, push the door with your hand just a little bit to right side just a few seconds while is reading the tape and close the door, (i had done this 2 or 3 times) this way i have solve the E04 Error, now i can record and play with my cam.
Apr 10, 2008 | JVC GR-DVL300 Mini DV Digital Camcorder
JVC GR-DVL120 Playback
you should have the heads cleaning,
try to put a cleaning tape and run it for playback then try recording again
Nov 20, 2007 | JVC GR-DVL120 Mini DV Camcorder
No playback on JVC GR-D72
It souunds like the problem is in the Vid-PC connection. I suggest you start by downloading the latest version of whatever software you have used to capture and view.
Also - uninstall any hardware in the PC that is used to capture (just remove from system device list) and then restart the PC and let it detect and re-install.
If you don't know how to do these steps, then you'll need geek help.
Oct 28, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
GR-D72 Mini DV Digital Camcorder makes clicking sound when tape running
the clicking is from the capstain turning the tape -- and perhaps the metal cage holding the tape.. if it is bent then the movement of the capstain may be pushing it in an eccentric fashion.
send it in for repair.
Oct 15, 2007 | JVC Cybercam GR-D72 Mini DV Digital...
Jvc gr-dv500u
Dirty video head! Playback newly opened blank tape for five minutes, after that eject, reinsert, playback then eject again five times, these will serve as your video head cleaner, never use "video head cleaning cassette tape" for it will only damage your camera. Most camera has built in video head cleaner installed inside and activates only when you insert, initial play/rec, and ejects a tape. If the problem is still there you need pro fix then.[:0)
Sep 27, 2007 | JVC GR-D290 Mini DV Digital Camcorder
JVC GR-DVL300 Mini DV Digital Camcorder Logo
219 people viewed this question
Top JVC Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
