Question about Maxtor Personal Storage 3100 (M01B080) 80 GB Hard Drive
I had a power surge. The green lite comes on and the disk is spinning but the computer does not recognize the PTE personal storage 3100 usb, external drive 80GB
    President:
  • 739 Answers
Hi free101
There are several reasons why external storage failure was detected on the computer
1> usb wire failure
2> usb port failure
3> connector on the external casing failed to detect the external storage (or connectors are damaged)
4> damaged hard disk (external storage that is damaged)
5> virus in external storage or a computer virus in it to prevent detection.
How to you identify the problem.
1> do a test using a computer that is 100% work at a maximum level to ensure that the computer system and the USB port on your computer is function
If it is successful it means that your computer have a problem
-if it fails, do the next process
2> use the usb wire that is 100% working. Then connect to your computer
3> if you have to change the usb wire but it still does not work
Posted on Jan 02, 2011
  • HTS Sri Aman
    HTS Sri Aman Jan 02, 2011
    - open the outer casing and remove your hard disk.
    - if you have other casing is 100% working, create a test using the casing, but if you do not have it, you can do further testing to your computer, connects data cable and sources of power from the hard disk into your computer's motherboard
    (provide data wire ( SATA or IDE cable ) and power connectors as the needs of your hard disk, then turn on your computer and see the results.
    -if it is successful it means that the external casing, but if you have any problems mean your hard drive fails or damage
    ********** If a hard disk failure is detected while connecting directly to a computer is very difficult to fix because not appear on the computer**************
My Maxtor Personal Storage 3100 back up hard drive is not working. I can hear the internal parts moving, but I cannot retrieve any of the backed up information. Any ideas on how I can fix this or where I...
An external storage-device has four major components:
* the USB cable
* the power-adapter
* the disk-drive inside the enclosure
* the USB-to-disk-drive adapter inside the enclosure.
One of these components has failed.
Try a different USB cable.
Try connecting to a different USB port on your computer.
Try connecting to a USB port on a different computer.
Take a "multi-meter" and measure both the voltage and amperage output from the AC adapter, and compare with the specifications on the label on the adapter.
Open the enclosure, and remove the disk-drive, and then connect it as a "slave" disk-drive in a desktop computer, to see if it works at all.
Purchase a new, compatible, disk-drive, and install it in the enclosure, to "revive" your external storage device.
Get the part-number and serial-number from the label on your disk-drive, and access the manufacturer's web-site, and use "check warranty status", to see if they will replace the device, at minimal cost to you.
There exist commercial "data recovery" services that can try to repair your device, just long-enough to rescue and copy your files.
For example, see: https://services.seagate.com/index.aspx?lng=en-US for a "no data - no charge guarantee".
Nov 13, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
Maxtor personal storage 3100 ext. HD (200 GB). When plug into electrical outlet, the on light does not come on, and when connected to my PC, it doesn't recognize it. I think the power cord is defective....
You can find a power cord for your Maxtor Personal Storage 3100 100 GB Hard Drive here:
http://lcdpayless.com/productpage.php?productId=2503
or
http://www.ecrater.com/p/6553550/ac-dc-power-adapter-maxtor-3100
Oct 31, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
I have a Maxtor Personal Storage 3100 80 GB Hard Drive which has always worked and listed as drive G. However, on eday it just stopped listing drive G. Everytime I connect it to my port hub or to the...
Try a different "data" cable between your computer and the external disk-drive.
If there is an external power-supply, borrow a "multimeter", and test that the power-supply is supplying power (correct voltage and correct amperage).
Try connecting it to another computer.
Disassemble it, and disconnect the disk-drive from the USB-to-disk-drive adapter. Connect the disk-drive as a "slave" disk-drive in a desktop computer, and see if the disk is working.
If it still is under warranty, either your local retail store, or Maxtor/Seagate will honour the warranty, and replace it.
Jun 15, 2010 | Maxtor Personal Storage 3100 (M01B080) 80...
My Maxtor personal storage 3100 clicking and not recognised
If you can hear mechanical sounds from the case the problem is in the hard disk and moving it to your laptop isn't the solution. In that case check for a data recovery company at your area as sooner as posible. If the sound is no mechanical I'll tell you the way to move the HD. Describe me the kind of sound.
Stelios
Feb 20, 2010 | Maxtor Personal Storage 3100 (M01E100) 100...
My Maxtor Personal Storage 3100 suddenly not
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Nov 07, 2009 | Maxtor Personal Storage 3100 (M01E100) 100...
We moved our computer and re-connected our external drive (maxtor personal storage 3100) and the computer won't recognize it. how do I get It to?
try reinstalling the drivers for it if its a usb which most are try using a different usb port to re initialize the usb communication to it
Sep 28, 2009 | Maxtor Personal Storage 3100 (M01B080) 80...
Missing external drive from computer
> replaced the usb card ..
Did you mean "replaced the USB cable" ??
Borrow a "multimeter", and check that the power-supply for the external drive is putting-out the correct voltage/amperage.
Try disassembling the external drive, and connecting the disk-drive as a "slave" drive in a desktop computer, to see if the disk-drive itself is OK,
i.e., the USB-to-disk-drive interface inside the casing might have failed, but your "data" could be OK.
Apr 11, 2009 | Maxtor Personal Storage 3100 (M01B080) 80...
Maxtor 3100 installation
It's Plug N Play. XP will see it (Found new hardware), and will install the drivers for you and assign it a drive letter and you will see it in MY Computer. However, there may be some other features and drive options you might like on the disk.
I have anexternal USB harddrive myself and am planning on gettng another very soon.
Mar 08, 2009 | Maxtor Personal Storage 3100 (M01B080) 80...
My computer will not recognize my maxtor personal storage suddenly when it has always worked before.
My Maxtor 3100 did work with my XP widow machine at one time. But suddently my computer doesn't recognize the USB connection. How do I fix this?
Proopt
Nov 09, 2008 | Maxtor Personal Storage 3100 (M01E100) 100...
Maxtor Personal Storage 3100 (M01B080) 80 GB Hard Drive Logo
59 people viewed this question
Top Maxtor Computers & Internet Experts
Computer Links
Rick Arnold
terminalcon
Are you a Maxtor Computer and Internet Expert? Answer questions, earn points and help others
