Question about Kenmore Kitchen Ranges
My simmer select features works properly, but when I turn the feature off my left front burner only works on high. I have no variable control on the left front burner.
  • Chris Edward Jan 02, 2011
    Will give that a try. Thanks.
  • 2,926 Answers
Replace the switch for this burner, it is also known as an infinity switch.
Posted on Jan 02, 2011
Frigidaire stove burner not working
There is an allen head adjustment screw under the burner so you can adjust your burner fuel. It is adjusted too far and is going back to the simmer level. Just find the right size allen wrench and turn it to the lefft and adjust it to the proper setting.
Mar 10, 2014 | Kitchen Ranges
Igniter switch on top burner will not shut off
try thoroughly cleaning the burners, particularly the holes in the ring that the gas come through. The gas come through to heat the ignitor so that the ignitor knows to stop trying to light the burner ; if the holes are clogged the ignitor doesn't heat.
The burner is easily disassembled from the top by removing a thin bolt, and you can clear the holes with a paper clip.
Sep 21, 2013 | DCS RGS-305 Professional Gas Kitchen Range
I have the star burner model, w/ extra-low simmer. The center burner will not light at all by itself. The right rear burner will self-ignite if you turn it to low, and then slowly rotate the knob clockwise...
Center burner won't light: If there is a bright spark (check all ignitor points at night with the lights out and look for consistent brightness of the sparks) then it's likely that the burner slots are dirty or the air/gas mix is wrong. If you can light with a match, but the spark won't light, then go for cleaning the entire burner assembly thoroughly with a brass bristle brush (available at most automotive stores). The proper air/gas mix has to flow over the spark to ignite. Weak spark, improper air/gas or misdirected gas flow that misses the spark can all cause this issue.
RR burner lights only on low setting. Again, check the air gas mix and clean all parts. Something like a small spider web inside the air mix chamber (area between the orifice and the burner can cause this and is difficult to see. Disassemble, clean thoroughly, reassemble and test. Extra low simmer burners (two on the left side) use their own control module with electric gas valves and variable electric control switches. The burner works on low, so these are not likely the problem.
Most folks want to find a bad part, and that can happen, but stove tops get dirty and cleaning usually helps. If not, you have a clean top to work on.
The indicator lens and/or the retainer are either broken or the retainer is missing. It's best to replace these as they are not expensive. When the top is off while cleaning is an perfect time to replace the lens.
Mar 30, 2017 | Thermador 37 in. SGSX365 Gas Cooktop
Kenmore Electric Range Model 790.96224406 I'm at my sister-in-laws for Christmas. This morning no burners would work. Cycled c/b and reset the clock. All burners now work except left front. (Left...
Same problem (and it started over xmas...what a coincidence). Replaced the switch and no luck. Bought another eye (used one on ebay) and no luck. I need to stop shotgunning and bring in a voltmeter. I'll let you know if I find anything. Have you figured it out?
Dec 26, 2010 | Kitchen Ranges
Thermador model RDF30RS burners won't light
Hi, there are two small circuit boards on those burner controls. They are called potentiometers. There was probably a boil over or spill at some point. They are notorious for failing. Hope that helps.
May 04, 2017 | Kitchen Ranges
Clogged burner on gas cooktop
lowly is it the left burners that won't lite? I only ask as depending on the model some of the Thermador cook tops had simmer control burners. This is a 3 part system on the burners. 1 a simmer control, 2 electric solenoid, 3 potentiors. When you turn on the burner the potentior tells the simmer control to send power to the gas solenoid. At the same time the unit will spark. If your unit has extra low on the left 2 burners then you have this system. The usual problem in the potentior. Hope this helps.
Aug 07, 2008 | Thermador SGS36GS Gas Cooktop
Help! burner on stove is dysfunctional
the elemnt is workin fine, its the control switch(infinite switch) thats having the problem, replace them both
Mar 02, 2008 | Kitchen Ranges
One of the Burners does not light.
I have the same problem and just took the cooktop apart to investigate. I disconnected the solenoid lines from the simmer controller (that is located under a metal guard to the right side under the burners) and checked them with an ohmmeter. It reads an open circuit, which suggest the solenoid is bad. When I turn the control knob on, I also read about 100V DC on the corresponding solenoid terminals of the simmer controller. I was surprised it was that high for a DC voltage, does anyone know if that is correct? I would hate to spend $90 on a replacement solenoid valve and then have it blow because the controller is putting out too much juice.
Dec 15, 2006 | Thermador RDDS30 Dual Fuel (Electric and...
Kitchen Ranges Logo
156 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
